4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
64 registered members (ad_infinitum, 4WD, 2010Civic, Agnosto, 5 invisible), 1,381 guests, and 71 spiders.
Topics286,042
Posts4,901,391
Members67,551
Most Online2,967
Mar 10th, 2019
2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard #4611754
12/23/17 12:50 AM
12/23/17 12:50 AM
Phoenix, Arizona - USA
SirTanon Offline OP
SirTanon  Offline OP
Well, this is the 3nd oil change I've done, following the valve job / top-end work I had done, and the 2nd of those that I ran out to ~ 7,500 miles, although I pulled the trigger a little early on this one due to the engine sounding noisier over most of the OCI. The red line indicates before/after the top-end work.
I'm having a hard time putting my finger on what exactly is making the engine seem noisier.. maybe it's an exhaust leak, perhaps an engine mount worn/wearing out.. dunno. I actually was concerned a bearing was going, which is why I pulled the trigger early, but the UOA doesn't seem to point to a bad bearing.. so I don't know.
Copper and aluminum are a bit higher than I'd like to see, but not at a level that I'd consider scary at this point.. Could they be from the new head gasket?
This fill had a full bottle of LubeGard BioTech engine oil additive in with it.. does anyone know if that has copper and/or aluminum in it? Does anyone else have experience with it, in general?
All in all, I do feel better about the engine.. at least I'm not worried about bearing failure at this point.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 271,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 62,000mi
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4611802
12/23/17 06:05 AM
12/23/17 06:05 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
The reason I don't put additives in my engine. You don't know what is in it to get an honest analysis.
The "thinking" man's friend.
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4611809
12/23/17 06:14 AM
12/23/17 06:14 AM
Georgia
MParr Offline
MParr  Offline
Georgia
SirTanon
Typical numbers after having the cylinder head worked. This engine has served you well. As far as noise, there should be more noise after .25 million miles.
2013 KIA Optima EX 2.4L. Now: Unknown &OE filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4611826
12/23/17 06:40 AM
12/23/17 06:40 AM
NY
demarpaint Offline
demarpaint  Offline
NY
AFAIK there is no copper or aluminum in LG Bio EP. Shoot them an email with your concerns, they're usually pretty good at getting back to you.
God Bless Our Troops
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4611926
12/23/17 09:26 AM
12/23/17 09:26 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
You can try some Castrol Magnatec 5w30 in it to see if that quiets it down any. Not sure I'd mix anything else into the oil as far as additives go.
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4611929
12/23/17 09:30 AM
12/23/17 09:30 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Skip the additive. My 2.3 Fusion has only had 20 wt oils and most of that 0-20. No more noise in this engine now than when purchased, although these engines are prone to be slightly noisy but long lasting.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 65K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4612162
12/23/17 12:56 PM
12/23/17 12:56 PM
PimTac Offline
PimTac  Offline
Are you sure the noise is internal?
Cannot see signatures any longer so it doesn’t matter.
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4612252
12/23/17 02:42 PM
12/23/17 02:42 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
Accessories driven by the belt can be very noisy. If you take the belt off and run the engine for a few seconds only, you will understand.
2004 Ford Ranger 4.0L V6
Valvoline Advanced Full Synthetic HM 5W30 + WIX 51372
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4612313
12/23/17 04:40 PM
12/23/17 04:40 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
I thinks it looks OK to me.
Is this the full synthetic or semi-synthetic MaxLife ?
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4612363
12/23/17 05:49 PM
12/23/17 05:49 PM
WA
John_Dude Offline
John_Dude  Offline
WA
Wear metals look good. Viscosity is still well within grade. If you're having noise issues, I would try running magnatec next time. It really quieted my escort zx2 which ha flat tappet cams, at 150k miles of wear.
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4612395
12/23/17 06:37 PM
12/23/17 06:37 PM
SirTanon Offline OP
SirTanon  Offline OP
Originally Posted By: tig1
Skip the additive.
Yeah. I bought some LubeGard Red to put in my transmission, and the engine stuff seemed to have good feedback too, so I figured I'd give it a go.. Of course, after I put it in, I thought to myself "now why did I feel I needed to add this to my oil?".. but it was already in, so I left it.
Yeah, I have observed many times previously that this engine tends to be kind of noisy.. even fully warmed up, it sounds like a sewing machine on steroids. Maybe it's just my imagination, or maybe I'm being hyper vigilant, but it just seems to sound different. Probably something to do with how it was all put back together after the top-end work was done. Not sure. At highway speeds, it seems pretty smooth, although there is some of what I think may be wheel bearing noise/vibration.. other than that, it winds up fine on the onramps, etc..
And yeah, I'd say the engine has done well, considering that it's already made it to the moon and is on its way back. I know I've heard this 2.5 liter referred to as 'bulletproof' before too.
Standard red jug MaxLife.. so semi-syn. I do have some jugs of the full-syn stuff too.
No.. I'm not. Sometimes it sounds like it might be, and other times, it doesn't. If anything it might be piston slap, but I doubt that, based on the wear metals in this UOA. Could very well just be normal vibration transmitted through worn-out engine mount, or dog-bone strut mount. Heck, it could even be an odd exhaust leak that just sounds metallic.
I don't plan to add any additives to my oil going forward... although I do have a very light dose of mos2 in with the current fill.. I'll be going with just straight oil on my future fills.
Funny that you both mention magnatec.. must be something to it. If I didn't already have something like 65 quarts of oil on hand, I'd probably get some magnatec and try it..
While we're on the subject, this is what I have in my stash currently.. which would you say should be my next fill:
Mobil Super Synthetic 5w30
Valvoline MaxLife Synthetic 5w30
Havoline Conventional 5w20
Havoline High Mileage 5w20
Kendall GT-1 (Titanium) 5w30
Rotella T4 10w30
Rotella T5 10w30
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4612419
12/23/17 07:10 PM
12/23/17 07:10 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Maxlife Synthetic
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4612483
12/23/17 08:35 PM
12/23/17 08:35 PM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
I think things are looking OK. This engine is fairly "new" on the top, so let's give it a little time to settle down. This is only the third OCI on the new head work. Let's give it a chance to show how well things can run for another 250k!
I don't understand why folks recommend different brands of lubes, as if one brand is going to magically make something quieter? Bah-humbug!
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4612490
12/23/17 08:44 PM
12/23/17 08:44 PM
WA
John_Dude Offline
John_Dude  Offline
WA
Magnatec helps with valve train noise due to the same principle that having more zddp helps. I've ran mobil 1 0w-30 with rislone zddp additive (boosts zddp to 1600-1800ppm) to achieve the same effect. I believe magnatec just has some esters that stick to the lifter buckets and cam lobes better than your typical low-zddp add pack of current sn oil formulations.
The difference is cold-start valve train noise is pretty dramatic. Once warmed up it's a smaller difference, but still noticable.
The zx2 has solid tappets, so to do a valve lash adjustment you have to change the whole tappet which are not available anymore.
I wonder if his noise is from an incorrectly set clearance...
Next oci I'm going to try Castrol edge HM to see if it has the same esters as magnatec
Re: 2010 Fusion 2.5 - 6865 mi - Valv ML 5w30+LubeGard [Re: SirTanon] #4612498
12/23/17 08:59 PM
12/23/17 08:59 PM
WA
John_Dude Offline
John_Dude  Offline
WA
Of the oil you have to choose from, definitely the maxlife.
