Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
72 registered members (Anduril, badduxx, bmwpowere36m3, ARCOgraphite, biodiesel, bbslider001, 8 invisible), 1,775 guests, and 55 spiders.
Topics296,775
Posts4,958,671
Members66,969
Most Online2,577
Jan 14th, 2019
GM block heater therostat bypass #4609529
12/20/17 05:58 PM
12/20/17 05:58 PM
Alberta
BigJakeChevy Offline OP
Alberta
Does anyone have experience cutting the thermostat end off their block heater cord? Will it cause any check engine light? Any other issues that could happen here? Info online is inconsistent. Thanks!
2007 Silverado Classic 1500 Crewcab 5.3L 460,000kms
Engine oil Mobil 1 0w40fs
Oil Filter Fram Ultra 10575
Trans Oil Amsoil Torque Drive
Front Diff Amsoil SG75w90
T-Case Autotrak II
Rear Diff Amsoil SG75w140
Re: GM block heater therostat bypass [Re: BigJakeChevy] #4609558
12/20/17 06:31 PM
12/20/17 06:31 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
I can't see this causing any problems. I don't understand why they would make it so the heater does not come on when the temp is above 0 degrees F. I would cut off the end and replace it.
Re: GM block heater therostat bypass [Re: BigJakeChevy] #4609563
12/20/17 06:35 PM
12/20/17 06:35 PM
Alberta
carviewsonic Offline
Alberta
Could set p0116 code if difference between coolant temp and intake air (ambient) temp is 30 deg C or more. If you use a timer so block heater is on for no more than 2-3 hrs that wouldn't be a problem. If you leave it plugged in all night it could set the code. The ECM assumes the engine temp sensor is faulty, and sets fuel map for 80 deg C. Also runs cooling fans (if your truck has electric cooling fans). Happened on my 2005 Buick, I erased the p0116 code with a code reader, and am now more careful not to plug in more than necessary.
'18 Impala
'05 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: GM block heater therostat bypass [Re: BigJakeChevy] #4609819
12/21/17 01:16 AM
12/21/17 01:16 AM
Alberta
Alberta
Thank you for the info.
T-Case Autotrak II
