Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
76 registered members (94astro, 2002 Maxima SE, 2004tdigls, 92saturnsl2, 4WD, 9 invisible), 2,077 guests, and 39 spiders.
Topics295,105
Posts4,927,867
Members66,688
Most Online2,553
Oct 27th, 2018
Motorcraft filter ... Miles and or time #4609168
12/20/17 09:38 AM
12/20/17 09:38 AM
MI
blastoff Offline OP
blastoff  Offline OP
MI
Hi all.
Posted in oil forum but realize my question may be more about filters
I don't drive a lot. 7-10k a year.
How long would you run a motorcraft (fl2017b ifit matters) filter? Time and or miles! 8k in 6mo fine? What about 5k in a year? 2k in 3 years?
There is some interaction between miles and distance and I'm just not sure what is a good and bad idea.
I think I'd be comfortable going a little longer (time) oci if I knew filter should be good. I have read motorcraft filters are quality.
Re: Motorcraft filter ... Miles and or time [Re: blastoff] #4609177
12/20/17 09:50 AM
12/20/17 09:50 AM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
It would be good for the manufacturer's recommended OCI for your vehicle, either time or miles (or both).
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: Motorcraft filter ... Miles and or time [Re: kschachn] #4609185
12/20/17 09:55 AM
12/20/17 09:55 AM
MI
blastoff Offline OP
blastoff  Offline OP
MI
I guess that's the question.
Manufacturer normal use is 6mo/7.5k
Severe use says 4mo/5k.
What if you drove 2k in 6 months?
Re: Motorcraft filter ... Miles and or time [Re: blastoff] #4609227
12/20/17 10:59 AM
12/20/17 10:59 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
The filter should be fine for 10k miles. The oil would be a different story, unless you are using a synthetic.
10,000 miles of short trips per year where the vehicle barely reaches operating temperature is different than say 10,000 miles of highway travel each year where the vehicle reaches full operating temperature.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (36k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Motorcraft filter ... Miles and or time [Re: blastoff] #4609231
12/20/17 11:01 AM
12/20/17 11:01 AM
MI
blastoff Offline OP
blastoff  Offline OP
MI
My Driving can be variable. I try to stick to 6months if more shorter trips.
But I don't drive to work, and half my miles are long highway drives.
I have been running motorcraft synblend.
I think I will consider going longer than 6mo if not more than 5k miles, but not push it past 9mo or so. If a lot of short trips, I will change based on time.
Re: Motorcraft filter ... Miles and or time [Re: blastoff] #4609238
12/20/17 11:10 AM
12/20/17 11:10 AM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
Change the oil and filter every 6 months regardless and don't worry about it. While the fulter and oil could go longer, all those short trips will mean moisture to deal with.
HDEO in Diesel Engines. No spark plugs here.
Re: Motorcraft filter ... Miles and or time [Re: blastoff] #4609265
12/20/17 11:47 AM
12/20/17 11:47 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
10K /1 year on your combo if mostly highway miles.
I'd shorten it to 7-8 months if you have lots of short trips or lots of cold weather starts.
Re: Motorcraft filter ... Miles and or time [Re: blastoff] #4609337
12/20/17 01:33 PM
12/20/17 01:33 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Filters accumulate by volume of oil passed through. So, if there has been little use, they don't "wear out" just sitting there ...
It's not like tires and ozone/UV degradation. It's purely a volume pass through function smile
The best way to manage filters is a gauge before the filter and one after. If the differential reaches a set limit they get changed. Until then, they stay in place. maybe for years ...
Re: Motorcraft filter ... Miles and or time [Re: blastoff] #4609469
12/20/17 04:31 PM
12/20/17 04:31 PM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
Filters do accumulate with flow. However, moisture from short trips attacks over time.
Re: Motorcraft filter ... Miles and or time [Re: blastoff] #4609481
12/20/17 04:52 PM
12/20/17 04:52 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
I have been using the MC FL2017B for years now with great results at 10K OCIs in my 2007 Ford Fusion. As for time, anywhere from 6-9 months. The 2017 always looked very good compared to other filters I tried early own. Filters like Fram, M1, etc always twisted when removed. The 2017 never does.
2007 Ford Fusion 235,000 miles
M1 0-20 EP
2017 Ford Fusion 60K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Motorcraft filter ... Miles and or time [Re: tig1] #4613008
12/24/17 11:49 AM
12/24/17 11:49 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Here is a pic of the new and old MC FL 2017B with 10K miles. This is the only cartridge filter I have tried that doesn't twist while in use.
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
