I have sinned
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
Help Soldering 3.5mm mono microphone plug
by Brybo86. 12/15/18 01:02 PM
Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
73 registered members (901Memphis, AandPDan, ammowaster, 4WD, Aero540T, 10 invisible), 1,973 guests, and 40 spiders.
Topics295,112
Posts4,927,975
Members66,688
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil #4608214
12/19/17 12:12 PM
12/19/17 12:12 PM
Alabama, United States
Red91 Offline OP
Red91  Offline OP
I can get Kendall GT-1 synthetic 5W-30 for $3.58/qt everyday from one of my wholesale contacts. I've been considering just putting it in as our shop oil. We work on small block Chevrolets, fords, and Chryslers of all ages; big block Chevrolets, Fords and Chryslers of all ages; Ford vulcans, GM3800's, Chrysler V6's, and assorted domestic four cylinders. Occasionally we'll see a Honda, Toyota or Nissan in the shop. I was just wondering what the group thought about using this oil across the board.
'89 Chevy 1500
Supertech 20/50
'15 Chevy Cruze
AcDelco syn dexos 5/30
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: Red91] #4608220
12/19/17 12:17 PM
12/19/17 12:17 PM
CA
The Critic Offline
The Critic  Offline
CA
Is the $3.58/qt price for bulk or cases?
One of my wholesale vendors is offering a price that is significantly lower than yours for Dexos1 approved Quantum synthetic, but it is a generic brand and I have no idea how well it will perform on longer drains.
$3.58/qt is a decent price for a semi name brand full synthetic if it is Dexos1 approved, but it is still a bit pricey for professional use.
2011 Toyota Prius - 178k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 133K - Mobil 1 EP HM 5W-30
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: Red91] #4608227
12/19/17 12:21 PM
12/19/17 12:21 PM
Red91 Offline OP
Red91  Offline OP
I forgot to mention we work on a lot of ls V8's and Ford modulars too.
$3.58/qt is case price. I could get by with only having to have two or three cases on hand at a time.
'89 Chevy 1500
Supertech 20/50
'15 Chevy Cruze
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: Red91] #4608229
12/19/17 12:22 PM
12/19/17 12:22 PM
Kalifornia Kollective
BrocLuno Online content
BrocLuno  Online Content
No problems with Kendall oil. If that's the best price you can get - go for it smile
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: Red91] #4608232
12/19/17 12:24 PM
12/19/17 12:24 PM
CA
The Critic Offline
The Critic  Offline
CA
That is pretty good- the vendor I spoke with has a 10 case minimum.
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: Red91] #4608241
12/19/17 12:27 PM
12/19/17 12:27 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I can get Harvest King full synth (Meets DEXOS) for $10 a gallon here.
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: Linctex] #4608313
12/19/17 01:45 PM
12/19/17 01:45 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
+1, here as well in northern Ohio. Plus $6.99/gallon for their conventional.
Shops around here, prob even Walmart charge $50 for a full syn oil change. Seems like a decent price. Can't even get MC syn-blend at Walmart for the price Red mentioned.
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: Red91] #4608374
12/19/17 02:50 PM
12/19/17 02:50 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Do it right or don't do it. Market to your customers that you use the correct oil for each application
and don't skimp on quality. Your not going to do that with one flavor and viscosity across the board.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: Red91] #4608424
12/19/17 03:46 PM
12/19/17 03:46 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Red91, I thiink the full synthetic Kendall GT-1 is a good oil. The 5W30 comes in two flavours either Dexos1 or with Titanium. You can't get both Dexos & Titanium in the same oil from Kendall, they are two different products and both are good.
Which one are you going for ?
I almost ordered a case of Kendall GT-1 10W30 with Titanium for myself, as I found a local importer here. But in the end the price was a bit too much for me. It was fairly expensive in Oz. My interest in the 10W30 was my belief that a full synthetic in this viscosity grade should be fairly close to a monograde and all the good stuff that went along with that: low volatility and shear stability. In the end Castrol Australia released their Edge 10W30 which was an easier and less expensive option for me. Not many full synthetic 10W30s in Oz.
Anyway I looked into Kendall GT-1 and I thought it was a good oil. According to the Kendall web site the Dexos1 oil is Gen2, so up to date.
You know what your customers want and need. I trust your call.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: Red91] #4608531
12/19/17 05:34 PM
12/19/17 05:34 PM
Red91 Offline OP
Red91  Offline OP
I'll just keep Havoline. The more I think about it the more I don't even want to bother with synthetic and/or dexos apps. Havoline in 5W-20, 5W-30 and 10W-40 covers every conceivable oil change I can see us doing.
'89 Chevy 1500
Supertech 20/50
'15 Chevy Cruze
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: Red91] #4608833
12/19/17 09:48 PM
12/19/17 09:48 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Chevron Havoline make good stuff, here is the PDF of their product line, which you probably already have. But just to throw it out there (Link)
The three grades you listed would be my pick too. Plus some SAE 30 for yourself.
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: Red91] #4608973
12/20/17 05:26 AM
12/20/17 05:26 AM
South OZ
KL31 Offline
KL31  Offline
South OZ
My Subaru dealership seems to use Havoline oil. Or I should say "Quality Havoline oil" as per the invoice.
What about VW engines or anything requiring euro specs though?
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: KL31] #4609038
12/20/17 07:13 AM
12/20/17 07:13 AM
Red91 Offline OP
Red91  Offline OP
We don't work on European cars. We also stay away from diesels for the most part. In the event that a European car, diesel or dexos app rolls through the shop I can get an appropriate oil. I just can't justify keeping those oils in stock for months at a time. It's money spent with no return, and I'm frugal with what I spend.
'89 Chevy 1500
Supertech 20/50
'15 Chevy Cruze
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: Red91] #4609043
12/20/17 07:18 AM
12/20/17 07:18 AM
central ga
urrlord Offline
urrlord  Offline
central ga
I used Kendall Titanium in my room mates Saturn Vue 4 cyl and one of my slant six D100's seemed to run pretty smooth.
Re: Kendall GT-1 Max Full Synthetic 5W-30 For Shop Oil [Re: SR5] #4609044
12/20/17 07:19 AM
12/20/17 07:19 AM
Red91 Offline OP
Red91  Offline OP
I really like Chevron products. The Havoline I stock is $35.50/case ($2.96/qt) from my other wholesaler. I can also get Delo, Rotella, Lubriguard, Lubrigold and Warren branded products from them. I don't like having much more than two cases of a given grade on hand at a time. We don't do many oil changes compared to other shops. Honestly 10W-40 covers more of what we work on than anything else.
'89 Chevy 1500
Supertech 20/50
'15 Chevy Cruze
Page 1 of 3 1 2 3
