Milesyn 5w30 5 gal pails $50.94 w/prime
by Samrsnow
06/24/18 01:20 PM
Removing Broken Bathtub Drain
by Warstud
06/24/18 01:15 PM
Buffer Pads
by TheLawnRanger
06/24/18 01:10 PM
Recommend an oil to me... Pennz, M1, Castrol...?
by chinee
06/24/18 12:39 PM
Filter for Hydro Gear ZT2800 - Toyota???
by Lancruza
06/24/18 12:39 PM
Motul 5W30, 3000KM/12 mo, 06 Acura RSX-S 161K KM
by lemaitrix
06/24/18 12:38 PM
DeWalt dcf887b 3spd impact driver
by JC1
06/24/18 12:34 PM
Grit guard wash board
by JC1
06/24/18 12:22 PM
Truck Lug Nut Spikes
by ET16
06/24/18 12:12 PM
Tier III fuel is on the way
by ZZman
06/24/18 11:53 AM
ACDelco Dexos 0W20 UOA
by DanMiller
06/24/18 10:44 AM
Mopar window regulator (some assy. rqd.)
by dlundblad
06/24/18 10:27 AM
5.3L Silverado Water Pump Torque Specs
by Gito
06/24/18 10:25 AM
Rhino Ramps at Canadian Tire 50% off
by Snagglefoot
06/24/18 10:18 AM
What to do when your Glock jams
by bigj_16
06/24/18 10:13 AM
Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
06/24/18 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
06/24/18 09:03 AM
Brisket flat on charcoal
by 04SE
06/24/18 08:45 AM
Weird Oil level question
by audia6
06/24/18 08:27 AM
DNA test and opening a can of worms
by WhyMe
06/24/18 08:11 AM
crrider, EdDmax, 2018matto, Lancruza, IanSampson
65312 Registered Users
93 registered (alphadog, AnthemBassMan, 330indy, andyd, aquariuscsm, 9 invisible), 1605 Guests and 35 Spiders online.
65312 Members
67 Forums
285913 Topics
#4603955 - 12/14/17 10:01 PM 2006 Nissan Xterra: Best Aftermarket Radiator
Phishin Offline
Loc: Indiana
I can get a good deal on this SUV. It has 112k miles on it. But these cars have a known problem with a leak in the radiator causing the ATF and antifreeze coolant to mix, thus destroying the tranny.
Many folks just perform a bypass of the radiator, but as preventative maintenance, I figured I'd change the radiator, hoses, clamps, and coolant.
Can anyone recommend a great aftermarket radiator?? In the past, buying replacements has always been hit and miss.
Are Griffith radiators highly regarded here? A quick search of some forums, I've seen them mentioned. But I hear they can be pricey.
2018 Chevy Silerado 3500HD 6.0L Gas: Undecided
2010 Accord-LX K24: VSP 0w20/MaxLife 10w30 + LG BioTech HD
2014 CR-V LX K24: M1 0w30
#4603962 - 12/14/17 10:09 PM Re: 2006 Nissan Xterra: Best Aftermarket Radiator [Re: Phishin]
maxdustington Offline
Loc: Toronna
Mishimoto
If you are that concerned, change the rad, leave everything else and spend the money
on a new trans cooler. It's not 1985 anymore and hoses can last the life of the car.
03 Jetta AWP/09A 200k kms
Edge 0W40 + Mann 719/30
#4603965 - 12/14/17 10:11 PM Re: 2006 Nissan Xterra: Best Aftermarket Radiator [Re: Phishin]
HoosierJeeper Offline
Loc: WI
I would stick with OEM. I don't have specific Nissan experience but with my Liberty, I had a shop put an aftermarket one about 4 years ago, and it's beginning to weep now. Putting an OEM one in. It isn't even the in-radiator tranny cooler type, I wouldn't trust Chinese stuff to keep those separate.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
#4603979 - 12/14/17 10:28 PM Re: 2006 Nissan Xterra: Best Aftermarket Radiator [Re: Phishin]
FowVay Offline
Loc: Southeastern USA
The OEM p/n for this product is 21460-9CAOE and costs nearly $500. If I were in your shoes I'd go to RockAuto and get a Denso replacement for about $97.
The only problem I've had with Denso radiators is that once I had one that was slightly dented when I received it.
Quaker State across the board.
#4603989 - 12/14/17 10:51 PM Re: 2006 Nissan Xterra: Best Aftermarket Radiator [Re: Phishin]
aquariuscsm Online   content
Loc: Dallas,Tx USA
OEM only. There's a reason aftermarket parts are cheap,you get what you pay for. Go online and find a wholesale Nissan OEM parts source.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 0W20
#4604042 - 12/15/17 12:50 AM Re: 2006 Nissan Xterra: Best Aftermarket Radiator [Re: Phishin]
boom10ful Offline
Loc: California
I've had issues buying OEM radiators. They end up stuck in a warehouse and by the time you use them the seals under the caps fail. The one I installed on my Hyundai lasted approximately 1 day before leaking worse than the one it replaced.
#4604070 - 12/15/17 03:18 AM Re: 2006 Nissan Xterra: Best Aftermarket Radiator [Re: Phishin]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
Aftermarket Denso.
One way or another, get rid of that trans oil going into the radiator.
#4604120 - 12/15/17 06:52 AM Re: 2006 Nissan Xterra: Best Aftermarket Radiator [Re: Phishin]
Sayjac Offline
Loc: The Old North State
I don't know what the "best' aftermarket radiator is. That said, having replaced an 01 Civic radiator a few years ago I first looked at Rock Auto options. TYC was a heart/most popular choice. I got it through Amazon, faster delivery for close to same price. It turned out to be a Koyorad, fit perfectly and has worked fine.
Anyway, looks like TYC and Denso are RA heart choices for the Xterra. I'd likely pay the ~$9 difference and go Denso for the name. Before buying, check Amazon price for same as RA Denso part #.
#4604695 - 12/15/17 04:30 PM Re: 2006 Nissan Xterra: Best Aftermarket Radiator [Re: Phishin]
slacktide_bitog Online   content
Loc: USA
Denso radiators are good. Their aftermarket radiators are made in Taiwan by their subsidiary Cryomax.
#4604699 - 12/15/17 04:38 PM Re: 2006 Nissan Xterra: Best Aftermarket Radiator [Re: Phishin]
UncleDave Offline
Loc: Ca.
Try Ron Davis.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
