'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
38 registered members (aleneros, alcyon, Bailes1992, berlyn, billt460, aba4430, 3 invisible), 513 guests, and 53 spiders.
Topics286,049
Posts4,901,479
Members67,551
Most Online2,967
Mar 10th, 2019
Rotella HD Tractor Fluid--OK for Log Splitter? #4597953
12/08/17 11:49 AM
12/08/17 11:49 AM
KY
pburchett Offline OP
KY
Is the Shell Rotella HD tractor fluid suitable for a MTD 27 ton log splitter requiring an 10 weight anti wear hydraulic oil. I called both shell and MTD but got someone that could only read a script from the back of the package or out of the manual. The HD tractor fluid is of 10W-30 weight but everyone I talked to now has me second guessing if this product is ok to use in my log splitter.
The following is from the container:
Shell ROTELLA® HD Tractor Fluid
Premium transmission-hydraulic-wet brake fluids for tractors
Shell ROTELLA® HD Tractor Fluid is a premium quality fluid for use in
transmissions, hydraulic systems, oil immersed brakes and other ancillary
systems fitted to agricultural tractors and off-road equipment. It is an
exceptional universal tractor fluid specially formulated for use where a
common fluid reservoir serves transmissions, final drives and hydraulic systems.
Performance Features and Benefits
• Incorporates a friction modifier for proper
noise-free operation of wet-brakes
• Excellent low temperature fluidity provides
good response at low temperatures
• Shell ROTELLA® HD Tractor Fluid provides
excellent service in virtually all makes of
construction and farm tractors
• Is frequently used as a single fluid to prevent
accidental contamination or misapplication and
to eliminate the need to purchase and keep in
inventory several products for most farm and
construction equipment
Main Applications
• Tractors and other equipment using a common
fluid to lubricate the transmission, differential
Re: Rotella HD Tractor Fluid--OK for Log Splitter? [Re: pburchett] #4598024
12/08/17 01:06 PM
12/08/17 01:06 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Hyd log splitters are the "Lowest stress" form of hydraulic powered equipment anywhere.
Almost ANY oil that *resembles* hydraulic fluid will work fine in a log splitter.
I run used ATF in mine... been doing it for 26 years.
Re: Rotella HD Tractor Fluid--OK for Log Splitter? [Re: pburchett] #4598025
12/08/17 01:08 PM
12/08/17 01:08 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
• Incorporates a friction modifier for proper noise-free operation of wet-brakes
This is expensive stuff, if it has this feature.
WAAAAAAAY overkill for what a log splitter needs.
Re: Rotella HD Tractor Fluid--OK for Log Splitter? [Re: pburchett] #4598026
12/08/17 01:09 PM
12/08/17 01:09 PM
Kentucky
Ramblejam Offline
Ramblejam  Offline
Kentucky
For your specific splitter:
ISO 32 or SAE 10W are equivalent; around 30 cSt at 40°C, and 5 cSt at 100°C.
Rotella HD Tractor is double that; 65 cSt at 40°C, and 10 cSt at 100°C.
In other words, the Rotella is too thick.
Re: Rotella HD Tractor Fluid--OK for Log Splitter? [Re: Ramblejam] #4598048
12/08/17 01:34 PM
12/08/17 01:34 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
That's what I use in my splitter, AW32 in cold weather, AW46 in hot weather, seems to work just fine. Cheaper than the Rotella, too.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Rotella HD Tractor Fluid--OK for Log Splitter? [Re: pburchett] #4598552
12/08/17 09:45 PM
12/08/17 09:45 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
A viscosity grade or two higher than recommended is always not an issue, so is in OP's application.
Re: Rotella HD Tractor Fluid--OK for Log Splitter? [Re: pburchett] #4599172
12/09/17 05:50 PM
12/09/17 05:50 PM
KY
KY
I did not know the Rotella was so thick. I stopped at Tractor Supply and they had the Rotella for $50 and the description sounded good, but I thought I would ask here first.
Tractor Supply also had Traveller AW32 for $30, but I was worried about the quality. I looked at the local parts store and all they had was their store brands which equated to a rebranded Costal or Peak/Shield/Old World Industries AW32 for $45.
I guess I will go with the Traveller brand and change it out sooner than I have previously done.
