One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
41 registered (Atesz792, BigJakeChevy, AVB, bbhero, 2strokeNorthstar, Aero540T, 3 invisible), 983 Guests and 38 Spiders online.
65265 Members
67 Forums
285570 Topics
#4597057 - 12/07/17 11:26 AM Denso designer wiper refill from Toyota?
wing0 Offline
Loc: Ontario, Canada
Car's RX300 and I bought Denso designer(hybrid) wipers for the windshield.
I want to replace just the inserts now, but not sure how I am going to match up with the part number from Toyota since these are not OEM wipers.
However, I think Toyota uses mostly Denso for wipers? Both inserts are from NWB.
http://www.denso-am.com/products/automotive-aftermarket/wiper-blades/wiper-blades/
I took down the numbers and length off the current inserts, but google search doesn't return much.
Driver side: 2177 RC 600mm
Passenger side: 2244 RC 525mm
I want the Toyota part numbers, but not sure if it can use same inserts from the OEM pair(I misplaced those)
#4597077 - 12/07/17 11:49 AM Re: Denso designer wiper refill from Toyota? [Re: wing0]
kschachn Offline
Loc: Upper Midwest
On my Toyota cars the OEM dealer inserts will not fit Denso wiper blades, in fact they won't fit the blades that are sold in the marketing section at the dealer. They only fit the blades ordered out of the catalog (or were original to the car).
The Toyota Fast Moving Parts Catalog (search online for it) lists the part numbers for the refill inserts, but like I mentioned they may not fit.
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
#4597089 - 12/07/17 12:11 PM Re: Denso designer wiper refill from Toyota? [Re: wing0]
PimTac Online   content
Loc: Soviet State of Washington
I get the impression that many of the automakers are getting particular on replacement parts, most likely to get the customer to stop by the dealer. My Mazda has very specific wiper blades and inserts. I believe they are also made by Denso.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
#4597345 - 12/07/17 05:39 PM Re: Denso designer wiper refill from Toyota? [Re: PimTac]
raytseng Offline
Loc: CA
Yes and no. Yes to the first part, no to the second. There's this thing called the internet and ebay. There will always be a few dealers parts dept that want to do the volume thing and sell on ebay and move those parts.
Especially for something highly replaceable like a wiper blade or oil filters, the oem will be no more than an aftermarket part and competitively priced on ebay. Even more so if you buy several sets to save on shipping
Edited by raytseng (12/07/17 05:41 PM)
#4597458 - 12/07/17 07:30 PM Re: Denso designer wiper refill from Toyota? [Re: wing0]
slacktide_bitog Online   content
Loc: USA
Consider the US-made Trico Ultra smile
If you don't want to spend that much, the Trico Flex (made in Mexico) is a very good mid-priced alternative
#4598138 - 12/08/17 02:15 PM Re: Denso designer wiper refill from Toyota? [Re: kschachn]
nthach Offline
Loc: California
I installed Denso FTF blades on my Prius and used dealer inserts. The passenger side fit fine, the driver side I had to snip off the notch that positions the steel spines to get it to fit.
The Miata guys have figured out the Denso blades, and I had a friend get them for his Subaru - I'll experiment with Toyota or Honda refills on that.
https://forum.miata.net/vb/showthread.php?t=485035
#4598173 - 12/08/17 02:47 PM Re: Denso designer wiper refill from Toyota? [Re: nthach]
kschachn Offline
Loc: Upper Midwest
The ones I had (either Toyota "OEM aftermarket" or whatever they were) didn't have a retention notch at all, they just had both ends bent over to retain the rubber strip. I didn't feel like messing with it to be honest.
FWIW, based on some recommendations here on BITOG I've been buying PIAA silicone wipers for a while now. Those are pretty awesome in my opinion and I haven't had to replace one yet.
1994 BMW 530i, 227K
#4598359 - 12/08/17 05:50 PM Re: Denso designer wiper refill from Toyota? [Re: wing0]
Traction Offline
Loc: iowa
After using OEM inserts on my last 3 Camry's I would never consider anything else. They usually last for 2-3 years, cost less than $15, and work perfect in any weather!
Tire Industry Association Certified Tire Service Instructor since 2009
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
12 Camry
81 Camaro
55 Chevy C4
#4598629 - 12/08/17 10:42 PM Re: Denso designer wiper refill from Toyota? [Re: nthach]
wing0 Offline
Thank you for the link.
160-3124 - 2009-12 Acura TSX driver side or 2012-15 Civic 2dr passenger side refill 76622-SLN-A12
160-3121 - 2011-2016 Honda CR-Z passenger side refill 76622-SZT-A01
I will pass by a Honda dealership and get a pair.
