Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
18 registered (hpb, dervdave, Falcon_LS, Deltona_Dave, car51, CleverUserName, 1 invisible), 764 Guests and 40 Spiders online.
65265 Members
67 Forums
285574 Topics
#4594294 - 12/04/17 06:32 PM 1996 4runner 3.4 w/ 236,000 miles results
etc. Offline
Loc: Michigan
I just received my oil analysis back from Black Stone.
I don't know the oil change history. When I bought it, I changed the oil and here are the results from the first 5,500 miles.
I am using Mobil 1 10w-30 High Mileage Synthetic in conjunction with a Fram Ultra filter. The oil has 5,500 miles on it. One 1600 mile trip towing a 5,000lbs trailer. The rest was highway and very short commutes (<10 miles round trip). During my 1600 mile trip I found a large hole rotted in my air intake where the crank case vent connects. I just recently fixed it.
I should mention I have a loud tick/knock that I have narrowed down to the valve train on the driver's side. No other issues like codes, power loss, smoke, etc. Actually, from my reading this has become a common issue with the 3.4.
#4594362 - 12/04/17 07:35 PM Re: 1996 4runner 3.4 w/ 236,000 miles results [Re: etc.]
John_Dude Offline
Loc: WA
Iron seems a tad bit high for a 5.5k mile run, though it could be from the towing. Lead and tin are good. I would really recommend running mobil 1 hm 5w30. My 99 4runner owners manual says that using 10w30 could cause the engine to not start at very low temps. 5w flows better when cold, but ultimately thins out to a 30 weight when heated up like 10w30. This will reduce bearing wear on cold starts. It's a win-win situation. 10w30 oils used to be more resistant to shearing down in viscosity, but since they've gone to higher quality base stocks, like group 3+, 5w30 are just as sturdy.
Edited by John_Dude (12/04/17 07:38 PM)
#4594376 - 12/04/17 07:52 PM Re: 1996 4runner 3.4 w/ 236,000 miles results [Re: etc.]
etc. Offline
Loc: Michigan
I have 300 miles on the oil since the oil change. It's my winter vehicle, so if I should change it out, I will. I don't foresee changing it out until next fall otherwise.
#4594463 - 12/04/17 09:28 PM Re: 1996 4runner 3.4 w/ 236,000 miles results [Re: etc.]
3800Series Offline
Loc: Gulf Coast, MS
Silicon is rather high for my liking, I would look for a air leak by the air box/hose leading to the motor. It could very well be why the iron is high as silicon and wear go hand in hand.
On a unrelated note I've always ran several short OCI after I get a new vehicle. Never know what the previous owner did or how often they changed it and the frequent changes can help clean anything up that may be inside. Granted I change my oil myself so it can be a lot cheaper.
--and this is why I should read the whole post before I comment lol--
Edited by 3800Series (12/04/17 09:29 PM)
#4594490 - 12/04/17 10:12 PM Re: 1996 4runner 3.4 w/ 236,000 miles results [Re: etc.]
John_Dude Offline
Loc: WA
I wouldn't bother draining it to go for 5w30, just use 5w30 next time. If you notice it cranking slow when it's really cold, your engine could benefit from a 5w oil. (As long as it's not the battery.. .)
Edited by John_Dude (12/04/17 10:18 PM)
#4594518 - 12/04/17 10:54 PM Re: 1996 4runner 3.4 w/ 236,000 miles results [Re: etc.]
BrocLuno Offline
Loc: Kalifornia Kollective
Or the cables... 20 years old in the salt road region - I'd install some extra new crimped and soldered lug grounds.
One from the Bat (-) to the alternator bracket (any bolt), and one to the firewall. I like hood hinge bolts for that. Usually cures all the cold start issues.
5W should be OK as long as it's above -10 ...
Edited by BrocLuno (12/04/17 10:54 PM)
#4594578 - 12/05/17 02:38 AM Re: 1996 4runner 3.4 w/ 236,000 miles results [Re: etc.]
Merkava_4 Offline
Loc: Clovis, CA
I looked at the Iron before I looked at the oil brand.
As soon as I saw the Iron, I knew which oil brand it was. grin2
#4594596 - 12/05/17 03:20 AM Re: 1996 4runner 3.4 w/ 236,000 miles results [Re: etc.]
CleverUserName Online   content
Loc: California
The 5VZ-FE is known to have head failures at around 250K. The castings between the valves are thin and will crack due to age and repeated heat cycles. I looked to purchase a '00 tacoma w/ 240K and it had low compression on CYl #3, most likely due to said cracking. There were no codes and issue wasn't discovered until a compression test was performed. I walked away from the deal because I knew that it needed a new head and the seller wasn't willing to negotiate on the price. Somebody else bought it.
Edited by CleverUserName (12/05/17 03:20 AM)
#4594690 - 12/05/17 07:33 AM Re: 1996 4runner 3.4 w/ 236,000 miles results [Re: BrocLuno]
etc. Offline
Loc: Michigan
Upon purchasing the vehicle, I replaced all of the battery cables with 2gauge welding cable with soldered lugs. I still need to replace a few body grounds near the intake, but they're still not corroded.
#4595010 - 12/05/17 01:32 PM Re: 1996 4runner 3.4 w/ 236,000 miles results [Re: etc.]
John_Dude Offline
Loc: WA
You could try rislone zddp additive for the top end noise. It's not an oil thickener like Lucas, but the zinc/phosphorus is very good for coating moving parts. At the very least it will reduce wear wherever the clearances have grown enough to make noise, and lessen valve train wear overall.
https://www.walmart.com/ip/Rislone-3X-Co...13=&veh=sem
Edited by John_Dude (12/05/17 01:33 PM)
