At least your viscosity of 7.3 cSt is within range for a 20-weight, but I guess your 2.7 Ecoboost is supposed to take 5W-30. For whatever reason, my 1.0 Ecoboost is supposed to take 5W-20, or 0W-20 in cold climates. That's what the book says, so that's what it is getting as long as I have a powertrain warranty. I will be doing UOAs, though.
My guess is that some of that has to do with the sump capacity vs. displacement.
I am not quite making the connection. Does it have something to do with oil temperature?
More oil, relatively, doesn't break down/dilute as quickly.
Ah, that makes sense. My 1.0 takes 5-quarts of oil, and the 2.7 Ecoboost only takes one more quart. So per displacement vs capacity, the 2.7's oil is doing 2.25X more work. Maybe this is what Ford had in mind when they specified 5W-30 for the 2.7. That is, they may expect a 5W-30 of typical quality will break down to the equivalent to a 5W-20. Regardless, if I had a 2.7, I would be looking for a better oil, and maybe shorter change intervals.
For the 2.7, you might start with a 5W-30 with a higher initial viscosity @ 100°C.
The Citgo Supergard 5W-30 starts at 9.8cSt
Pennzoil Platinum 5W-30 starts at 10.3 cSt
Valvoline Synpower 5W-30 starts at 10.2 cSt
http://www.docs.citgo.com/msds_pi/C10002.pdf
http://www.pennzoil.com/en_us/products/f...c-Motor-Oil.pdf
https://sharena21.springcm.com/Public/Do...12-ac162d889bd1
Aside from the viscosity breakdown, other concern with these Ecoboost engines is coking due to heat and intake valve deposits. Upon examining some different oil specs and prices, I decided to go with Valvoline Synpower 5W-20. It meeds Ford WSS-M2C945-A, and the NOACK of 7.6% loss suggests a low potential for intake deposits. (5W-30's NOACK is 9.3%). However, it is hard to find current specs to examine coking potential. And finally, I may have no idea what I am talking about. I am a mechanic, but not an oil expert.
