Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
All Mazda 3’s have bad OCV’s?
by buster. 12/14/18 03:44 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
74 registered members (AdditiveOCD, AndyB, Ag76, 69GTX, 4WD, andyd, 11 invisible), 1,256 guests, and 38 spiders.
Topics295,090
Posts4,927,579
Members66,684
Most Online2,553
Oct 27th, 2018
2012 Toyota 3.5L oil question #4588585
11/29/17 09:54 AM
11/29/17 09:54 AM
McGregor TX
mrdctaylor Offline OP
McGregor TX
I have an extended warranty on my 2012 Toyota Highlander with a 3.5L V6. The warranty runs until 100K miles. I'm using 0W20 and have used that weight since I got it. I have a few more OCIs before my warranty runs out and have enough 0W20 stashed to get well past 100K miles on my existing supply of oil. I'm just wondering about down the road if it would be suitable to run it on 5W30 synthetic like I use for my other vehicles. I'm assuming it would since this engine USED to be spec'd for 5W30. Essentially, I'm just curious if anyone has switched from 0W20 to 5W30 on this specific engine and if they are happy with their decision. I don't have a problem using 0W20, but using the same weight across the board would be nice. I'm also wondering if using a thicker oil as the engine ages would be beneficial.
Thanks!
02 Tacoma 3.4L, 222K, Magnatec 10W30
12 Highlander 3.5L, 101K, Napa Syn 0W20
17 Escape 2.0L, 37K, Hav ProDS 5W30
02 Trailblazer 4.2L, 182K, Edge HM 10W40
Re: 2012 Toyota 3.5L oil question [Re: mrdctaylor] #4588597
11/29/17 10:08 AM
11/29/17 10:08 AM
Canada
Broo Offline
Broo  Offline
Canada
I am no authority on this subject as I don't know this specific engine, but it it was rated for 5W30, then the "upgrade" to 0W20 is likely to achieve slightly better MPGs to lower Toyota's CAFE.
Kinda like the old Ford 3.0 Vulcan which started at 5W30 then "upgraded" to 5W20 along the way with no design change. Since both my oil cap and the manual call for 5W20, that's what I use, even though it's the only one in my fleet to use this grade.
If everything is fine for you with 0W20 and that 's what Toyota specifies, I'd play it safe and keep using this grade.
Re: 2012 Toyota 3.5L oil question [Re: mrdctaylor] #4588610
11/29/17 10:17 AM
11/29/17 10:17 AM
Ontario, Canada
GSCJR Offline
GSCJR  Offline
Ontario, Canada
A thread was started recently about the 2GR-FE (Toyota 3.5L you have) and which oil to use. If you can find it (I cant't) it started off pretty good. From the little bit that I can remember, the engine is not picky about oil. I have used from 0w-20 to 5w-30 in them so far. Maybe another member is better at linking it for us because I was curious about it also.
03 3.0L 1MZ-FE QSGB 5w-30 ProSelect 21348 256KM
10 3.5L 2GR-FE CEB 0w-20 Defense DL9972 156KM
Re: 2012 Toyota 3.5L oil question [Re: mrdctaylor] #4588611
11/29/17 10:19 AM
11/29/17 10:19 AM
McGregor TX
McGregor TX
Thanks. I have a hard time with the search on this site, but I'll give it a go. Sometimes using Google to search the site works better than the site's search function.
Re: 2012 Toyota 3.5L oil question [Re: mrdctaylor] #4588617
11/29/17 10:21 AM
11/29/17 10:21 AM
McGregor TX
McGregor TX
No luck... :-(
Re: 2012 Toyota 3.5L oil question [Re: mrdctaylor] #4588620
11/29/17 10:25 AM
11/29/17 10:25 AM
PimTac Offline
PimTac  Offline
Is the engine burning or leaking oil? If not, why not just stick with the 0w-20? A typical reason to go thicker would be worn rings but I doubt you have that issue.
Cannot see signatures any longer so it doesn’t matter.
Re: 2012 Toyota 3.5L oil question [Re: mrdctaylor] #4588623
11/29/17 10:26 AM
11/29/17 10:26 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
You always stay on the designated oil until after your warranty. Not that they'll help you but at least they may help you if you have a decent dealer that will go to bat for you.
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2012 Toyota 3.5L oil question [Re: mrdctaylor] #4588627
11/29/17 10:29 AM
11/29/17 10:29 AM
McGregor TX
McGregor TX
Yeah, I'm sticking with the 0W20 until the warranty is over. And my car doesn't use/burn oil or have any issues that I'm aware of. It is more of a convenience thing to have the same weight across all 4 cars I maintain, but it is certainly not that big of a deal. Honestly, I just wonder if a thicker oil would be better as the engine ages. Maybe not. I suspect it wouldn't make much of a difference either way.
Re: 2012 Toyota 3.5L oil question [Re: mrdctaylor] #4588687
11/29/17 11:12 AM
11/29/17 11:12 AM
Canton, Ohio
Throt Offline
Throt  Offline
Canton, Ohio
I bought the 2017 Sonata in my signature in July. Oil cap calls for 0w20, I've done two changes on it so far and both times used M1 AFE 0w30. With the fuel dilution from the GDI it'll thin out so I don't see the problem. Plus, the owners manual even says that you can use 5w30 but that 0w20 will provide better MPG. So I can't see a warranty dispute happening over this if I ever had a problem. Running a 20 weight with the GDI makes me a nervous of what'll thin out to before it's changed.
'18 Honda Accord Touring, 1.5T, Factory Fill/Filter
'17 Elantra, 2.0L, 22,500, QS Ult. 0w20 w/ FU, hers (lease)
