New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
107 registered members (2004tdigls, addyguy, arowbat, 2002 Maxima SE, Astro14, 11 invisible), 2,222 guests, and 65 spiders.
Topics286,351
Posts4,906,907
Members67,608
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Drilled/Slotted Rotors with which pads #4588385
11/29/17 06:56 AM
11/29/17 06:56 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
So I think I'm going to get drilled/slotted rotors for the Journey as the brakes are coming due.
Having never used this type of rotor before I wanted to know from your experiences what the best pads to go with are. Keep in mind I operate this vehicle like a fleet vehicle and it's on the road daily for lots of miles.
I can get Fleet Rated Extreme Duty pads that are semi-metalic or I can get ceramic pads or I can get standards daily driver rated semi-metalic pads.
Thoughts?
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Drilled/Slotted Rotors with which pads [Re: StevieC] #4588391
11/29/17 07:06 AM
11/29/17 07:06 AM
SW Florida
Taildragger Offline
Taildragger  Offline
SW Florida
They look nice but is there any advantage to using drilled/slotted rotors on the street?
04 F-150 5.4
73 Big Block, 4sp Corvette
15 Mazda 3
Couple of airplanes
Re: Drilled/Slotted Rotors with which pads [Re: StevieC] #4588399
11/29/17 07:18 AM
11/29/17 07:18 AM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
Word of advice - DON'T.
I have them on my SHO - the Powerstop set. Mainly got them for a possible slight increase in the brakes, which in the 2010 model were simply adequate.
Never again - put them on at 75k and now at 120k They are noisy under hard braking, have a slight warp to them which nobody will machine out and all in all are not anywhere near as good as I hoped. Hoping to get them off in the Spring.
Re: Drilled/Slotted Rotors with which pads [Re: StevieC] #4588401
11/29/17 07:20 AM
11/29/17 07:20 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
Thanks itguy08. thumbsup
Re: Drilled/Slotted Rotors with which pads [Re: StevieC] #4588409
11/29/17 07:44 AM
11/29/17 07:44 AM
Northern Ontario, Canada
Danno Offline
Danno  Offline
Nope, don't do slotted or drilled Stevie.
I usually get my rotors/pads off eBay.ca from well rated vendors. Bought the last set this spring, was anti-corrosion coated "normal" rotor with ceramic pads - for 4 wheels. $180 delivered.
My best price was for a 2005 Uplander - 4 rotors and matching pads - $132 out the door in Toronto local pickup. They still worked fine after 2 years and 45,000kms, and I disposed of the vehicle.
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: Drilled/Slotted Rotors with which pads [Re: StevieC] #4588416
11/29/17 07:54 AM
11/29/17 07:54 AM
Fairfax, VA
TinyVoices Offline
TinyVoices  Offline
Fairfax, VA
Do not bother with drilled or slotted rotors on the street. Will give no braking improvement and will just wear pads faster. Those kinds of rotors are meant to reduce brake fade by managing heat better than a solid rotor. You are not going to experience brake fade on the street in a minivan.
If you want better brakes, get a quality solid rotor like a centric blank and a quality high performance pad.
2010 Mazda RX8 Sport - 37k miles - ????
2006 Toyota Matrix XR AWD (Wife) - 130k miles - Valvoline Max Life 5w30
Re: Drilled/Slotted Rotors with which pads [Re: StevieC] #4588421
11/29/17 07:58 AM
11/29/17 07:58 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
I was just after longer lasting rotors and I thought I would give the drilled/slotted a try only because I operate like a fleet vehicle and they are well used.
I guess I will go with a quality vented rotor that is corrosion treated and ceramic pads then...
Re: Drilled/Slotted Rotors with which pads [Re: StevieC] #4588435
11/29/17 08:13 AM
11/29/17 08:13 AM
Fairfax, VA
TinyVoices Offline
TinyVoices  Offline
Fairfax, VA
What do you mean when you say longer rotor life? Longer until they are too worn down to use or longer until they become "warped"?
Re: Drilled/Slotted Rotors with which pads [Re: StevieC] #4588436
11/29/17 08:14 AM
11/29/17 08:14 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
Longer because of warping. The Journey has insanely large pads so they last forever. I'm approaching 100,000km (60K miles) on original front/rear pads in frequent stop/go driving and have about 30% left! crzy
Re: Drilled/Slotted Rotors with which pads [Re: StevieC] #4588458
11/29/17 08:39 AM
11/29/17 08:39 AM
Toronto Canada
WobblyElvis Online content
WobblyElvis  Online Content
Toronto Canada
I had slotted/drilled rotors once. They under performed and fell apart [rusted] surprisingly quickly. Never again.
Re: Drilled/Slotted Rotors with which pads [Re: StevieC] #4588465
11/29/17 08:44 AM
11/29/17 08:44 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Get high carbon rotors they last a lot longer. Napa's ultra premium rotors fit the bill.
Re: Drilled/Slotted Rotors with which pads [Re: Trav] #4588467
11/29/17 08:45 AM
11/29/17 08:45 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
Napa anything here is usually gangster expensive but I will check into high carbon. Thanks! thumbsup
Re: Drilled/Slotted Rotors with which pads [Re: StevieC] #4588490
11/29/17 09:02 AM
11/29/17 09:02 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Or cryo-treated rotors.
Re: Drilled/Slotted Rotors with which pads [Re: Bottom_Feeder] #4588494
11/29/17 09:05 AM
11/29/17 09:05 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
Interesting... Hadn't heard about this...
http://www.stoptech.com/products/rotors/cryogenic-treated-rotors
Re: Drilled/Slotted Rotors with which pads [Re: Trav] #4588495
11/29/17 09:06 AM
11/29/17 09:06 AM
Texas
4WD Offline
4WD  Offline
Texas
High carbon should be coated, right?
Also, I see no connection between drilled/slotted and rust … I have a set that’s a year old and a “Drivers Side” decal is still stuck to the rust free finish …
Page 1 of 3 1 2 3
