Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
27 registered members (BigShug681, bmod305, 08z06, A1O, 53' Stude, billt460, 3 invisible), 529 guests, and 51 spiders.
Topics286,220
Posts4,904,513
Members67,579
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
How full is full? Settle a debate #4587381
11/28/17 11:10 AM
11/28/17 11:10 AM
IL
jcartwright99 Offline OP
IL
Recently, after changing my oil in my Ford Fusion a buddy of mine said my oil was low. I assured him it wasn't. The owners manual said 5.7 quarts (with the filter). I ended up putting in 6. After measuring several times in a few different days, it's just above the crosshatched section of the dipstick and a little below the top (max) hole.
My friend and I got into a spirited discussion on how much oil you should have in there. He claims it should always be right at the top Max hole and you if you aren't, are low on oil. I say as long as it is either in the crosshatched section or a little above you should be fine. I told him you never want to overfill or be at that over or into that top hole because then you are overfilling it (and that can be bad). He doesn't change his oil and has always gone to Jiffy Lube type places. His rationale is that they always show him his dipstick at the max level.
I am not messing around, so I came here to the oil experts. Who is right on this?
Re: How full is full? Settle a debate [Re: jcartwright99] #4587384
11/28/17 11:15 AM
11/28/17 11:15 AM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
From an OCD point of view, I would guess to be FULL, the oil would need to be EXACTLY at the maximum line on the dipstick--IF that is what the manufacturer intended. With that said, within the crosshatches is operationally fine and I would not add until the oil hit the add line on the dipstick (but that is just me).
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: How full is full? Settle a debate [Re: jcartwright99] #4587385
11/28/17 11:15 AM
11/28/17 11:15 AM
US
TheOilWizard Offline
US
You are correct in this instance. Anywhere on the crosshatch is a safe operating level.
It's probably smart to keep the oil near the max line simply so you have extra capacity in case of a leak.
Also, don't exceed the max fill line. More is not better in that scenario.
Don't take our word for it, check your owners manual!
Re: How full is full? Settle a debate [Re: jcartwright99] #4587386
11/28/17 11:17 AM
11/28/17 11:17 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Never listen to anyone to lazy to do their own oil..
This sounds like many people I've ran into in life that always have the answer for everyone but their own life is a total wreck.
2004 Corolla 130005
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: How full is full? Settle a debate [Re: jcartwright99] #4587400
11/28/17 11:28 AM
11/28/17 11:28 AM
NC
fenixguy Offline
fenixguy  Offline
NC
I like to get it as close as I can to the top mark when changing but I don't add any throughout the interval unless it's at the bottom mark (I don't have to add any to any of my vehicles). I've overfilled enough times that I take it slow until I get it close to the top. Usually start with a quart less than total capacity and run the car a few minutes. Then add accordingly.
And don't take an internet forum's word for it. Read the owner's manual and see what it says.
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
Re: How full is full? Settle a debate [Re: JohnnyJohnson] #4587403
11/28/17 11:30 AM
11/28/17 11:30 AM
Utah, USA
28oz Offline
28oz  Offline
Utah, USA
Isn't that the truth! Just like parenting advice from the relative/friend who doesn't have kids, or financial advice from someone who is always broke or in debt.
1990 Nissan 300zx VG30DE - PP Euro 0W-40
2004 Nissan Quest VQ35DE - PP Euro 0W-40
2003 Ford Excursion 7.3 PSD - Rotella T6 5W-40
2005 Ford Taurus 3.0 Vulcan - Havoline HM 5W-20
Re: How full is full? Settle a debate [Re: jcartwright99] #4587405
11/28/17 11:31 AM
11/28/17 11:31 AM
Regina, Saskatchewan
sir1900 Offline
sir1900  Offline
1. Add the required quantity according to the manual.
2. Run the engine for a minute or so.
3. Check the dipstick. Use the level shown as a guide of where you should be level-wise.
Dipsticks are not always accurate, so if you put in 5.7 qts and it "appears" low, then you are in some respects, overfilling when you add enough to reach the max line. Having said that, if you added a small amount (0.1-0.25 qts), you likely aren't doing any harm.
2015 Infiniti Q50
VAS 5W-30 + FRAM PH6607
2015 Nissan Murano
Mobil1 AFE 0W-20 + FRAM XG6607
Re: How full is full? Settle a debate [Re: jcartwright99] #4587411
11/28/17 11:32 AM
11/28/17 11:32 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
My Cessna 177RG aircraft has a Lycoming engine. The sump holds 8 quarts. The filter and oil cooler hold exactly 1 additional quart.
When it's full, after a proper oil and filter change using 9 quarts, the dipstick reads 8 quarts.
Lycoming allows the engine to run, in flight, as low as 4 quarts. Testing shows that the engine will not suffer oil pressure problems in any aspect of flight until it's at 3 quarts on the dipstick.
There is nothing special about the engine. It has an oil pan and pickup much like a car.
For years, racers have improved power and economy by running the engine with less oil. As there is less oil to whip around inside the crankcase.
The bottom line is that every engine has a significant safety margin built in. At some point, under normal driving conditions, the oil pump pickup will be uncovered, say on a hill. Prob about 2 quarts total.
Re: How full is full? Settle a debate [Re: jcartwright99] #4587413
11/28/17 11:33 AM
11/28/17 11:33 AM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
Isn't this more of a philosophical debate? Is it a half quart above the low mark, or a half quart below the full mark?
Re: How full is full? Settle a debate [Re: jcartwright99] #4587415
11/28/17 11:34 AM
11/28/17 11:34 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I always keep it to the top of the fullest allowable mark that is not considered "Over Filled". This allows, in the case of a leak or if the engine decides to burn some oil, a safe reserve for me to notice it. If it's at the bottom of the "Safe" area and this happens you could be starving the engine for oil in some cases.
Also my OCD wouldn't let me do it any other way anyway. wink
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: How full is full? Settle a debate [Re: Cujet] #4587418
11/28/17 11:37 AM
11/28/17 11:37 AM
Texas
mpersell Offline
mpersell  Offline
Texas
Dyno guys will often drop a quart out of an engine to get a higher hp rating for their clients, it only helps a little like around 5hp.
2016 Kia Soul - Amsoil
2017 Tundra - Amsoil
Making a living with free software
Re: How full is full? Settle a debate [Re: jcartwright99] #4587419
11/28/17 11:37 AM
11/28/17 11:37 AM
Texas
JustinH Offline
JustinH  Offline
Texas
I'm OCD about it.
I measure oil down to the ounce, I think my hyundai takes 5.23 quarts.
I try to get it as close to 5.25 as possible.
'11 Hyundai Sonata GLS
'11 Scion XB
Re: How full is full? Settle a debate [Re: jcartwright99] #4587420
11/28/17 11:39 AM
11/28/17 11:39 AM
Texas
4WD Offline
4WD  Offline
Texas
You got him … how much did you win ? wink
Re: How full is full? Settle a debate [Re: jcartwright99] #4587426
11/28/17 11:45 AM
11/28/17 11:45 AM
PimTac Offline
PimTac  Offline
There is a difference between full and enough. Full requires a reference. For most of us that is the dipstick where Full is clearly marked.
You may have enough oil in the sump to run the engine safely but that doesn’t mean it’s full.
Cannot see signatures any longer so it doesn’t matter.
Re: How full is full? Settle a debate [Re: jcartwright99] #4587427
11/28/17 11:47 AM
11/28/17 11:47 AM
Texas, USA
WylieCoyote Offline
WylieCoyote  Offline
Texas, USA
I like it to land somewhere between the crosshatches and the hole on oil changes. If it ventures below the top of the crosshatch during the interval, I add.
Page 1 of 4 1 2 3 4
