This is in my Infiniti. I ran 10w40 in the summer and this Castrol seemed like a good choice for the winter. So far, it's smooth and quiet, just like the VML 10w40 was.
Got it at AZ for $26.99 along with an STP XL filter.
You must do predominant, majority, highway driving to the exclusion of city unless it is to only to exit highways, amIrighhhhhttt? Hiel, this time of the year, I figure everyone is on that 0 weight something juice and concoction.
I'm pretty much a Castrol guy and have used their 5W-40 in my son's 50K mile old 2005 Ford F-150 4.8 liter V8. It was noticeably quieter on that stuff than it was the 5w-30 Mobil 1 he had in it. FWIW, YMMV.
For some reason that Castrol 5W-40 gets a bad rap here on BITOG, but I think you will be fine using it in your 125K mile old Infiniti. Whether or not you're using 5W-40, don't excessively rev cold motors. I've taught my wife and boys this from the very beginning.
I wouldn't say that Castrol 5W-40 necessary has a bad rep around here, it's just that Castrol's own 0W-40 "Edges" it out (get it? get it?) for less money.
It's still a fine oil and should be great in your VQ.
5W-30 called for in my car except where it's real hot so 10W-30 gets an OK.
I use Mobil1 0W-40 now 'cause it's, "...closer to a 30..."
My car seems to like it. Quiet is good.
Your Infinity is supposed to be running with 5W-30. What do you have to say for that ?
Probably the same thing I do, Merk: pffft. I'd have recommended he go with the Castrol A3/B4 0w-40, since it is a bit better oil for the money, but that's another matter.
2002 INFINITI I35 3.5L 6 -cyl Engine VQ35DE
VISCOSITIES:
All TEMPS....5W-30 SAE 5W-30 is preferred.
Above 0 F....10W-30
CAPACITIES: With filter 4.2 quarts After refill check oil level.
TORQUES: Oil Drain Plug...22-29 ft/lbs
Source: Amsoil
A lot of cars recommending 5W30 were built before 0W40 was conceived, the only remote concern I'd have is if the passages were a bit too narrow for a 40 weight oil, but as I said I'm not sure if that is a valid concern. I'd say go for it.
