Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
Practice CLS material
by RDY4WAR. 12/17/18 01:52 PM
2005 Chevy Silverado 5.3 vortex
by MSpeer. 12/17/18 12:01 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
28 registered members (dlundblad, 53' Stude, Char Baby, ARB1977, D0nat, biron, 1 invisible), 829 guests, and 33 spiders.
Topics295,205
Posts4,929,884
Members66,711
Most Online2,553
Oct 27th, 2018
Replaced bulbs in Mag Lites #4583770
11/24/17 03:16 PM
11/24/17 03:16 PM
Illinois
tig1 Offline OP
tig1  Offline OP
Illinois
I have two Mag Lite D cell flashlights that are several years old. Replaced both old conventional bulbs for LED bulbs and noticed a hugh difference in brightness. I know I could have bought new flashlights, but why throw away perfectly good equipment when they still perform very well with the upgrade.
2007 Ford Fusion 235,000 miles
M1 0-20 EP
2017 Ford Fusion 61K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Replaced bulbs in Mag Lites [Re: tig1] #4583776
11/24/17 03:34 PM
11/24/17 03:34 PM
Grand Rapids, Michigan
Toto Offline
Toto  Offline
I have 4 different sizes of Maglites and the larger one with 2 D Cell battery has a bulb and was trying to decide if I should convert it or not, know I know what to do! Thanks.
TOTO.
AMSOIL-OE 0W 20-XL 10W 30-AGL 80W 90
NAPA GOLD
Re: Replaced bulbs in Mag Lites [Re: Toto] #4583778
11/24/17 03:36 PM
11/24/17 03:36 PM
Illinois
tig1 Offline OP
tig1  Offline OP
Illinois
TOTO.
Your welcome. Glad I bought the bulbs.
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
Re: Replaced bulbs in Mag Lites [Re: tig1] #4583782
11/24/17 03:51 PM
11/24/17 03:51 PM
MI
HorseThief Offline
HorseThief  Offline
MI
I used to be an authorized service agent for Maglite before they pulled all of their service center contracts - the biggest issue with the old-style maglites is heat dissipation along with reflector design. The original mags were designed for incandescent bulbs and there's not a lot of places for the heat to go. The original maglite LED retrofit bulbs had to have a thermistor that would back off the current when they started cooking themselves and had poor reliability. As a result, maglite re-engineered their switch and bulb assembly along with a new reflector that has been optimized for LED's.
Just be aware of this when choosing LED retrofits - simple bulb-size drop-ins will have a poorer beam pattern with a donut shaped hole in the middle or have poorer reliability.
The LED retrofits can make an old light usable again, however just be aware of the limitations before spending too much money on them. $32 gets you a new maglite, but they're still under 200 lumens. Modern Fixed-focus lights typically beat out maglite in terms of brightness, and the focusing function is no longer needed because there's at least 5-10X the amount of light.
I saw a brown dog
Re: Replaced bulbs in Mag Lites [Re: tig1] #4583786
11/24/17 04:04 PM
11/24/17 04:04 PM
PimTac Offline
PimTac  Offline
I upgraded a 3D Maglite that I purchased back in the 80’s. This was about 5 years ago and it was a cheap led upgrade kit. I do like the light much better now though it cannot be compared to some of these new led torches they have. The flashlight is coming up on being 30 years old so I think anything you do to keep it running is well worth it. I also have noticed much better battery life as well.
I’m a big fan of LEDs. Every bulb in and around the house is slowly being changed over. I have a mix of old incandescent and cfl. The led light is much easier on the eyes and longer lasting as well as being cheaper to run.
Cannot see signatures any longer so it doesn’t matter.
Re: Replaced bulbs in Mag Lites [Re: HorseThief] #4583787
11/24/17 04:04 PM
11/24/17 04:04 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
My 6D LED Maglite is 694 lumens actually
Re: Replaced bulbs in Mag Lites [Re: PimTac] #4583799
11/24/17 04:24 PM
11/24/17 04:24 PM
Illinois
tig1 Offline OP
tig1  Offline OP
Illinois
My Maglites are around 15 years old. I ain't throwin them away for the latest super dupper lite. approved
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
Re: Replaced bulbs in Mag Lites [Re: tig1] #4583815
11/24/17 04:38 PM
11/24/17 04:38 PM
PimTac Offline
PimTac  Offline
I agree. They are made well and can be a good club if that kind of situation arose. The new lights are strong and small but battery life is limited.
@Ethan1, a 6D, that’s like a small baseball bat. Great light.
Re: Replaced bulbs in Mag Lites [Re: tig1] #4583826
11/24/17 04:51 PM
11/24/17 04:51 PM
New Jersey
Rock_Hudstone Offline
New Jersey
I picked up a few of the Rayovac LED replacement bulbs at Walmart a few years ago, too cheap the pass up, around $2.98 at the time.
Retrofitted a 4D and 3D Maglite. Bumped up the lumen output I think, although color rendition suffers somewhat from a bluish cast.
Have yet to have one fail, No complaints with the beam pattern, which was nothing great anyway even with the original incandescents.
Overall, a nice upgrade but nowhere near the power of an LED Maglite.
https://www.walmart.com/ip/Rayovac-LED-U...13=&veh=sem
Re: Replaced bulbs in Mag Lites [Re: tig1] #4583877
11/24/17 05:50 PM
11/24/17 05:50 PM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
Did a couple of LED upgrades on AA and D Maglites, bulb brands unknown. Noticed you can't focus the beam down like with the OEM bulb and the light is whiter but the supposed longer battery life is worth it. Also have a newer LED D cell Maglite and it's great.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Replaced bulbs in Mag Lites [Re: tig1] #4584018
11/24/17 08:53 PM
11/24/17 08:53 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
What did it cost? Ive got a few d cell lites that could use this!
Re: Replaced bulbs in Mag Lites [Re: Ethan1] #4584038
11/24/17 09:14 PM
11/24/17 09:14 PM
Canada
i_hate_autofraud Offline
Canada
Are those 694 lumens "chinese sized lumens" or American actual lumens? LOL wink
Re: Replaced bulbs in Mag Lites [Re: tig1] #4584045
11/24/17 09:22 PM
11/24/17 09:22 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
They're made in America so......
Re: Replaced bulbs in Mag Lites [Re: JHZR2] #4584049
11/24/17 09:26 PM
11/24/17 09:26 PM
Illinois
tig1 Offline OP
tig1  Offline OP
Illinois
With my military discount, $13 at Lowes. You might find them cheaper elsewhere.
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
Re: Replaced bulbs in Mag Lites [Re: tig1] #4584090
11/24/17 10:28 PM
11/24/17 10:28 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Had no idea you could swap to LEDs. Love maglights! I have 2 that are already LED. Great flashlights.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
