Thoughts on new AMAZON branded oil...?
by PantherFan88. 09/25/18 10:47 PM
Clutch kit?
by andrewp1998. 09/25/18 10:34 PM
Galaxy S8+ weird app when clearing storage
by KrisZ. 09/25/18 10:18 PM
Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
FRAM ULTRA XG 3593A CUT OPEN
by 53' Stude. 09/25/18 04:51 PM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
43 registered members (bdcardinal, Bailes1992, AndyB, bernau, 10WSmuckers, 5 invisible), 720 guests, and 38 spiders.
Topics291,026
Posts4,854,647
Members66,070
Most Online3,590
Jan 24th, 2017
1998 Bayou 220 wont stay running #4582381
11/22/17 09:39 PM
11/22/17 09:39 PM
louisiana
kenwin30 Offline OP
kenwin30  Offline OP
louisiana
hey guys, just got a new coil, and now it will start and run for about 5 mins and die, buddy of mine said its now either cdi box or the stator, what do you guys think ?
Re: 1998 Bayou 220 wont stay running [Re: kenwin30] #4582402
11/22/17 09:53 PM
11/22/17 09:53 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Too little info.
It could be fuel related.
Re: 1998 Bayou 220 wont stay running [Re: kenwin30] #4582483
11/22/17 11:34 PM
11/22/17 11:34 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
When the cdi failed on my bikes it would not run at all.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 1998 Bayou 220 wont stay running [Re: kenwin30] #4582514
11/23/17 12:12 AM
11/23/17 12:12 AM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
Have you verified no spark after it dies?
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: 1998 Bayou 220 wont stay running [Re: kenwin30] #4582600
11/23/17 06:25 AM
11/23/17 06:25 AM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
It sounds fuel related. Most electrical parts work or they do not. Does it have fuses or breaker circuts? Still I doubt it's electrical. Coils sometimes fail when they warm up but you changed that.
What does the spark look like?
If it's nice and blue your stator and trigger is good.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: 1998 Bayou 220 wont stay running [Re: Panzerman] #4582632
11/23/17 08:02 AM
11/23/17 08:02 AM
wv
krismoriah72 Offline
wv
20 years old..
My guess is that its ethanol related in the carb.
I have 'fixed' a few sputtering and non-running ope with B12 Chemtool Carb cleaner..all had nasty ethanol boogers in the carbs.
Re: 1998 Bayou 220 wont stay running [Re: kenwin30] #4582657
11/23/17 08:45 AM
11/23/17 08:45 AM
USA
mk378 Online content
mk378  Online Content
USA
First thing is to check spark when it won't run. If that is OK, very likely fuel related. You can verify with a hit of starting fluid, if it fires that, it isn't getting fuel. Check that you get a good flow of clean fuel from the tank through the carb inlet hose with it disconnected from the carb.
Engines with adjustable valves can idle poorly or not at all if the valves are too tight, and they get tighter when warmed up. I don't know if that is the case with that engine.
Re: 1998 Bayou 220 wont stay running [Re: kenwin30] #4582669
11/23/17 09:01 AM
11/23/17 09:01 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Many motorcycles and ATV's have a vacuum operated fuel shut off valve. And a fuel filter in the valve. You might want to ensure proper fuel flow as a first thing. Could be the carb fills up slowly, runs itself empty and fills up again slowly.
Re: 1998 Bayou 220 wont stay running [Re: kenwin30] #4582845
11/23/17 12:26 PM
11/23/17 12:26 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Drain the gas and pour into one of the vehicles. Put fresh Gas into it along with some Techron, Gumout or B12 etc and run it.
Re: 1998 Bayou 220 wont stay running [Re: kenwin30] #4583047
11/23/17 05:01 PM
11/23/17 05:01 PM
Canada
boraticus Offline
boraticus  Offline
Canada
i'd bypass the existing fuel system and hook up a line to the carburetor from an alternative fuel supply.
I usually use a squeeze bottle with gasoline in it and four or five feet of fuel line. I suspend it higher than the carb to ensure gravity flow. Fire up the engine and see how long it will run using secondary fuel supply. I it keeps running, the problem may be the vacuum powered fuel pump if it has one.
If it has gravity flow fuel supply, check the entire system for debris. Pull the line off the carb and see how much fuel comes out of the line. If not a good, solid flow, there could be blockage in the tank?
If spark and fuel are both good, I'd look at valve adjustment, and potential air intake, exhaust restriction.
