MANNOL ATF Multivehicle
by Ether. 03/25/19 01:17 PM
Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
128 registered members (4WD, 69Torino, 2012AccentSE, 97K15004WD, AndyB, 64bawagon, 14 invisible), 2,251 guests, and 69 spiders.
Topics286,401
Posts4,907,649
Members67,614
Most Online2,967
Mar 10th, 2019
Correct lube for Detroit Tru-Trac #4579500
11/19/17 09:58 PM
11/19/17 09:58 PM
Great Bend, KS
code5coupe Offline OP
Great Bend, KS
The instruction sheet said to use only conventional lube, not synthetic. The guy I talked to at Eaton said synthetic is "too slippery" to use in this limited-slip differential. Several YouTube vids said they are using synthetic lube with no issues. I have about 1000 miles on my Tru-Trac with synthetic lube.
Anyone here actually know the truth on the Tru-Trac??
1996 Corvette LT4
2012 Grand Cherokee SRT
Re: Correct lube for Detroit Tru-Trac [Re: code5coupe] #4579532
11/19/17 10:24 PM
11/19/17 10:24 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
I think what they are talking about is the limited slip additive in pretty much all synth lubes. Problem is, its getting to where its being put in conventional lubricants as well. I think the only way to avoid it now is to go to some specialty manufacturer or a heavy duty lube like Mobil Delvac 75W90
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Correct lube for Detroit Tru-Trac [Re: code5coupe] #4579539
11/19/17 10:31 PM
11/19/17 10:31 PM
Elizabeth. Colorado
c502cid Offline
c502cid  Offline
Elizabeth. Colorado
Don't know why you can't use synthetic. There are no clutches in a True Trac.
16 Ford F150 2.7 Ecoboost 4x4
15 Chev Trax AWD
02 GMC 3500 8.1/Allison Dually 4x4
00 Blazer 4.3 4x4
97/98 Honda Civics
84 Chev K30 454EFI/T400/NP205 Dually 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
Re: Correct lube for Detroit Tru-Trac [Re: c502cid] #4579579
11/19/17 11:10 PM
11/19/17 11:10 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Like he said, Eaton says no synthetic to be used, but will give no info on what is causing an issue besides "too slippery". Likely because it would single out one or a couple manufacturers and they can't legally do that. Its very frustrating. Theres a lot of theorizing on the intertubes and the limited slip additive angle is what I percieve to be the most likely, given their "too slippery" statement. It has no clutches, so obviously it doesnt need the additive, but its being added to almost all gear lubes.
-Colton
Re: Correct lube for Detroit Tru-Trac [Re: code5coupe] #4579584
11/19/17 11:21 PM
11/19/17 11:21 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Per the TrueTrac Operation Manual......
"High quality mineral gear lubes are required for use in Detroit Truetrac differentials. Regardless of the lube
type, alwys use a GL5 rated lube with the least amount of friction modifier. Mineral lubes lacking friction modifiers (limited-slip additives) were historically recommended for all Truetrac applications because friction modifiers can slightly reduce the bias ratio (limited-slip aggressiveness) of Truetrac differentials. However, to address the continually increasing power outputs of modern powertrains, many vehicle manufacturers have switched to synthetic lubricants as a counter measure for increased axle temperatures and prolonged service intervals. In general, consult the vehicle owner's manual for the manufacturer's recommendations for lubrication type, weight and fill volume. This will ensure lube compatibility with the seal materials and bearings used in the axle."
2001 Chevy Camaro L92/4L80E
Re: Correct lube for Detroit Tru-Trac [Re: code5coupe] #4579604
11/19/17 11:43 PM
11/19/17 11:43 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
They've updated it then, and I was right on with the limited slip additive.
A few years ago the language was much more firm for "No synthetic."
I guess they've realized pretty much everything is using it now and had to lighten up.
code5, what viscosity does your vehicle call for? Maybe we can find a synth oil with no LS additive.
-Colton
Re: Correct lube for Detroit Tru-Trac [Re: code5coupe] #4579616
11/19/17 11:53 PM
11/19/17 11:53 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I have a TrueTrac in my daily driver. I'm using Conventional lube based on Eaton's recommendations. However if I were to use a synthetic it'd likely be Redline 75w90 NS which is made without any limited slip friction modifiers.
I'm so pleased with how well my TrueTrac works with a conventional lube I'm unlikely to switch to a synthetic. I just change the lube more frequently. Which is easy since my differential has a drain and fill plug.
Luke
Re: Correct lube for Detroit Tru-Trac [Re: Colt45ws] #4579625
11/20/17 12:08 AM
11/20/17 12:08 AM
Texas
4WD Online confused
4WD  Online Confused
Texas
Think we had been through this before and an example was using Delvac 1 instead of Mobil 1 with LSD additives
The axle builders & OEM truck company are also getting a vote in the process too ~ considering the multifaceted job the oil has to do
Re: Correct lube for Detroit Tru-Trac [Re: code5coupe] #4579644
11/20/17 12:47 AM
11/20/17 12:47 AM
Long Beach CA
lbhsbz Offline
lbhsbz  Offline
Long Beach CA
The tru-trac provides the limited slip function using the friction created by driving the helicals and side gears into the case body. Using a "slippery" lube will result in the unit not locking up to the extent it would with a less slippery lube. Why not use what Eaton recommends?
Re: Correct lube for Detroit Tru-Trac [Re: code5coupe] #4579667
11/20/17 03:06 AM
11/20/17 03:06 AM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
Robert
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Correct lube for Detroit Tru-Trac [Re: lbhsbz] #4579896
11/20/17 10:48 AM
11/20/17 10:48 AM
Great Bend, KS
Great Bend, KS
Because I don't buy into the theory that synthetic gear lube is "more slippery" than conventional lube. I DO know that it has other properties that make it more desirable than conventional lubes, and want to take advantage of that. AND because my vehicle's manufacturer calls for 75W90 synthetic gear lube..... that's what I put in (Valvoline SynPower, "for limited slip and conventional differentials".
Thank you, each and every one, for your insights and opinions so far. I'd like to hear from more of you guys who have some experience with this differential and its lubricant requirements.
1996 Corvette LT4
Re: Correct lube for Detroit Tru-Trac [Re: DuckRyder] #4580317
11/20/17 07:00 PM
11/20/17 07:00 PM
Great Bend, KS
Great Bend, KS
Thanks, Duck. I just finished reading both threads in their entirety and came to the same conclusion that this thread led me to: Using synthetic gear lube will probably hurt neither the longevity nor the functionality of the Tru-Trac. Using synthetic or conventional oils with a friction modifier will not hurt the longevity of the Tru-Trac, but might affect its functioning to some unknown/unpredictable degree.
1996 Corvette LT4
Re: Correct lube for Detroit Tru-Trac [Re: code5coupe] #4580355
11/20/17 07:43 PM
11/20/17 07:43 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
You got it!!!
I have a Eaton TrueTrac in the Dana 60 in my Camaro, I ran Valvoline 80w90 GL5 to break in the gears for 250 miles then switched to Redline 70w90NS because it was the ONLY synthetic GL5 gear lube I could find local (Summit Racing) without LS additive.
Re: Correct lube for Detroit Tru-Trac [Re: code5coupe] #4580380
11/20/17 08:00 PM
11/20/17 08:00 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
https://www.fcsdchemicalsandlubricants.c...20Lubricant.pdf
Motorcraft 75w140 is GL-5 and has no modifiers.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Correct lube for Detroit Tru-Trac [Re: code5coupe] #4580457
11/20/17 09:05 PM
11/20/17 09:05 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Mobil Delvac 75W90 as well, has no modifiers. Does come in one gallon jugs, but you might have to look around.
-Colton
