When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
119 registered members (01rangerxl, A1O, 2015_PSD, 2009Edge, 2whlgeezer, 15 invisible), 2,055 guests, and 61 spiders.
Topics286,160
Posts4,903,325
Members67,569
Most Online2,967
Mar 10th, 2019
Partial o/c on older car #4572491
11/13/17 09:22 AM
11/13/17 09:22 AM
central ga
urrlord Offline OP
urrlord  Offline OP
central ga
I am curious about something and would like to get some feedback.I recently purchased a 94 Plymouth Acclaim with 63 k miles that had sat for about 3-4 years,I bought it from a guy who had purchased it from a charity.After he purchased it he had an o/c done at a Valvoline lube shop.Valvoline 5w30 conventional and a Service Champ filter .I am now a little over 2000 miles into the scheduled 3000 mile run,the oil is now about a half qt low.The oil appearance is dark brown at this time.
Should I just top off and change at the 3000 mile mark?
OR
Should I change out the filter and top off,then run it to 5000 miles.
The car runs smooth and does not smoke.However the mitsu/chrysler v6 is known to leak oil.This model year had the updated valve seals that cured the oil burning issues of this engine.
I have Chevron Supreme 10w30 which has a similar add pack to top it off.
What is your thoughts ?
Re: Partial o/c on older car [Re: urrlord] #4572500
11/13/17 09:29 AM
11/13/17 09:29 AM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
The oil is 3 or 4 years old? If this is true I would change the oil and filter.
If you do not have the money, top it up and drive until you can afford to change the oil and filter.
Re: Partial o/c on older car [Re: urrlord] #4572504
11/13/17 09:31 AM
11/13/17 09:31 AM
DFW
JustN89 Offline
JustN89  Offline
DFW
For me personally, I'd top it off and dump at 3k miles.
Yes, VWB can easily exceed the 3k mile OCI in a properly working engine, but we don't know enough about your new car to make that assumption. Especially after sitting for so long, and considering our lack of service records, I would feel better about more frequent OCIs with the intent to lengthen them as you learn more about the car.
If you have the money/means to do so, a UOA would help you in this process.
Re: Partial o/c on older car [Re: urrlord] #4572512
11/13/17 09:40 AM
11/13/17 09:40 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
It's not going to do it any harm to continue to 3K, but dumping it now wouldn't be a bad idea either.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Partial o/c on older car [Re: WobblyElvis] #4572532
11/13/17 10:01 AM
11/13/17 10:01 AM
central ga
urrlord Offline OP
urrlord  Offline OP
central ga
[quWobblyElvis]The oil is 3 or 4 years old? If this is true I would change the oil and filter.
If you do not have the money, top it up and drive until you can afford to change the oil and filter.[/quote
Sorry I was not clear.The oil is only a few months old.The car sat up 3-4 years and was then donated to a charity.It was purchased about 2-3 months ago .That man had the o/c done with Valvoline.I purchased the car about 3 weeks ago from that man.
Re: Partial o/c on older car [Re: urrlord] #4572537
11/13/17 10:04 AM
11/13/17 10:04 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
I would change it. Dump any crud that has been cleaned up. Then run a normal OCI here on out.
Re: Partial o/c on older car [Re: urrlord] #4572559
11/13/17 10:21 AM
11/13/17 10:21 AM
Illinois
javacontour Offline
javacontour  Offline
Illinois
Add and drive. It's a 24 year old car.
network down, IP packets delivered via UPS -BOFH
Re: Partial o/c on older car [Re: urrlord] #4572582
11/13/17 10:41 AM
11/13/17 10:41 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Given that you know little of the service history, I'd go a little further. I would treat this run as a test and eval. I'd prolly change the filter and top off with some MMO (Marvel Mystery Oil) and run it out to 3K. Then do a change to Maxlife 5W-30 in the red bottle (syn-blend) because of the age of the seals. A bit of seal softening is prolly in order. Keep the Chevron for top-ups smile
Re: Partial o/c on older car [Re: urrlord] #4572584
11/13/17 10:43 AM
11/13/17 10:43 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
The only way to kill those Mitsu's is to run them without oil or to overheat them. They are quite durable otherwise so you should be just fine. I have a ton of experience with that particular engine and Chrysler products in general thanks to my dad working for Chrysler and having his own shop (licensed mechanic).
Just top-off and keep going and when you do change those engines really like the Max-Life oils.
I would check the age and condition of the timing belt because if it has been sitting it might be dried out and if you snap it the engine is toast. Also do the water-pump if you are in there for the belt because it's a common problem on the 3L's. (Also if it has been sitting, they don't like that)
Steve
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Partial o/c on older car [Re: urrlord] #4572897
11/13/17 03:05 PM
11/13/17 03:05 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
I know a lot of people like to top off oil but, as far as I'm concerned, anywhere between the add and full lines is just fine. I'd just keep an eye on the oil level (check it every fill) and drive it to 3,000. The car likely uses a bit of oil and the rate can increase later in the change interval (I assume it's losing some viscosity).
After that I'd suggest using a good quality oil (probably a 5w-30 SN, whatever your manual recommends) and changing it and filter every 5,000 miles.
There's no reason not to top off oil. I just don't think it's necessary.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: Partial o/c on older car [Re: urrlord] #4573017
11/13/17 05:35 PM
11/13/17 05:35 PM
Indiana
dlundblad Online happy
dlundblad  Online Happy
Indiana
Top it off and drive the heck out of that thing until you change the oil.
That way, you'll (hopefully) be doing some crud collection at the expense of the already installed filter.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Partial o/c on older car [Re: dlundblad] #4573077
11/13/17 06:38 PM
11/13/17 06:38 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
This and I'd top it off with Valvoline Full Synthetic or NAPA Full Synthetic.
2004 Corolla 129987
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Partial o/c on older car [Re: urrlord] #4573088
11/13/17 06:47 PM
11/13/17 06:47 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Top it off. I wouldn't push it hard until you know the timing belt is good. Maybe the charity services it?
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Partial o/c on older car [Re: urrlord] #4573518
11/14/17 09:03 AM
11/14/17 09:03 AM
central ga
urrlord Offline OP
urrlord  Offline OP
central ga
I topped it off
I will change it out in about 800 miles.
Re: Partial o/c on older car [Re: urrlord] #4573577
11/14/17 09:50 AM
11/14/17 09:50 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Oh and take PCV valve out using a wrench and spray brake cleaner through it and put it back in. Common problem for the little ball in there to stick and cause it to use more oil.
