Torque Pro app for iPhone?
by Ed_Flecko. 03/23/19 08:18 AM
Sharpening Drill Bits
by ET16. 03/23/19 08:03 AM
more dumb questions!! infiniti Q50
by Robertslowpoke. 03/23/19 06:23 AM
VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
86 registered members (advocate, BeerCan, Audios, alarmguy, 4WD, Astro14, 4 invisible), 1,583 guests, and 53 spiders.
Topics286,273
Posts4,905,725
Members67,589
Most Online2,967
Mar 10th, 2019
Getting an axle seal out #4571053
11/11/17 05:30 PM
11/11/17 05:30 PM
WI
HoosierJeeper Offline OP
WI
Having an awful time getting a CV axle seal out of my Liberty.
I've chipped away most of the inner band of the seal lip, but it's still not budging. Any ideas? I've tried a two ended seal puller and a small ply bar but am weary of damaging something. If I can't figure out out, I'm going to shove a plastic bag in the hole and have it towed.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Getting an axle seal out [Re: HoosierJeeper] #4571058
11/11/17 05:36 PM
11/11/17 05:36 PM
USA
mk378 Online content
mk378  Online Content
USA
Use a flat screwdriver to pry around the outside, between the seal's metal flange and the transmission case.
Re: Getting an axle seal out [Re: HoosierJeeper] #4571059
11/11/17 05:39 PM
11/11/17 05:39 PM
WI
WI
I thought about doing that, I'm worried about nicking the aluminum. I put an arrow on the part I was thinking about trying to pry off.
Re: Getting an axle seal out [Re: HoosierJeeper] #4571067
11/11/17 05:47 PM
11/11/17 05:47 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
You gotta jam a screwdriver where your arrow is. A scratch here wont matter as it seals on the inside.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Getting an axle seal out [Re: Chris142] #4571075
11/11/17 05:58 PM
11/11/17 05:58 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Agree with the scratch info on this flanged seal. Just don't go gorilla on it.
Check out minute 13:30 + of this video:
Re: Getting an axle seal out [Re: HoosierJeeper] #4571079
11/11/17 06:00 PM
11/11/17 06:00 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
If you have the room, and you can find a gasket scraper like this locally, then it'll work much better than a screwdriver. The end is wider and flatter so you are less likely to nick the housing.
Re: Getting an axle seal out [Re: HoosierJeeper] #4571081
11/11/17 06:03 PM
11/11/17 06:03 PM
Cape Cod, MA
RF Overlord Offline
RF Overlord  Offline
Cape Cod, MA
I had a similar problem replacing the factory seal on my 2004 Grand Marquis. This tool made it a snap.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'04 Grand Marquis LS Limited Edition - daily driver
'00 Grand Marquis GS - bad frame/future to be determined
Re: Getting an axle seal out [Re: HoosierJeeper] #4571082
11/11/17 06:04 PM
11/11/17 06:04 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Nicking the face of the housing won't hurt, only a substantial gouge in the bore itself.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Getting an axle seal out [Re: HoosierJeeper] #4571090
11/11/17 06:18 PM
11/11/17 06:18 PM
WI
WI
That video helps a lot. I think I'll give that a shot in the morning.
BTW: Sorry for posting in the wrong section!
Re: Getting an axle seal out [Re: HoosierJeeper] #4571113
11/11/17 07:03 PM
11/11/17 07:03 PM
ME
eljefino Online content
eljefino  Online Content
ME
Can you stick a drywall screw in then pry it out with a claw hammer?
If you nick the aluminum you can fill it with RTV.
Re: Getting an axle seal out [Re: HoosierJeeper] #4571213
11/11/17 08:52 PM
11/11/17 08:52 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
You need to first get the rubber seal and the spring completely out with nose pliers.
Then you need to pull on the seal cage FROM THE INSIDE CENTER HOLE.
Use OTC 6541 Pulling Hook with slide hammer.
Re: Getting an axle seal out [Re: HoosierJeeper] #4571799
11/12/17 02:05 PM
11/12/17 02:05 PM
WI
WI
Thanks everyone! Got it out with a gasket scraper.
Do I need to oil around the outside of the seal before putting it in? Or just the inner part before putting the CV axle back in?
Re: Getting an axle seal out [Re: HoosierJeeper] #4571825
11/12/17 02:34 PM
11/12/17 02:34 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
I apply Red Loctite to the OD. And Trans-gel to the ID....You can use gear oil.
2001 Chevy Camaro L92/4L80E
Re: Getting an axle seal out [Re: HoosierJeeper] #4572072
11/12/17 06:46 PM
11/12/17 06:46 PM
WI
WI
Thanks for the help everyone, really. Couldn't have done it without the help. Went with the gasket scraper and that made quick work of it. Didn't mar the diff at all. Here's to hoping the new one doesn't leak! LOL
Re: Getting an axle seal out [Re: HoosierJeeper] #4572365
11/13/17 04:58 AM
11/13/17 04:58 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
I've always used a small chisel. If you nick it and are worried about sealing, use RTV, then replace the seal over the thin layer of RTV.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
