- Joined
- Jul 2, 2007
- Messages
- 5,294
I'm looking for something a little beyond and better than standard issue 100% ethyl cyanoacrylate. I need to hold the lens in a pair of wire frame sunglasses permanently so the glue needs a wee bit of flexibility and be somewhat tolerant of some flex and bend and still hold strong. They're not bargain rack cheapos, they were bought at an optician shop, designer frames that are long since discontinued but still look sharp and have single vision prescription lenses not much only about a -1.25 left and -1 right but they bring my distance vision from 20/30 to 20/20 and make me look good in the process
They are well worth fixing.
I also have assorted uses "around the house" from time to time for the described upgrade to super glue.
The glue needs to be ready to use and not a two part mix-it-together before use epoxy. And finally, the dispenser needs to keep it from hardening up after use-- every single tubelet of "super Glue" I've ever had always was only good for use the first few times within a month or two then the nozzle would dry solid as diamonds and it's done after having only dispensed maybe 20% of product content.
