New Struts and Springs
by Mathew_Boss. 04/21/19 05:36 PM
Float chargers?
by buck91. 04/21/19 05:32 PM
Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
103 registered members (ammolab, 2015_PSD, alphadog, AdditiveOCD, 53' Stude, 2009Edge, 11 invisible), 2,028 guests, and 28 spiders.
Topics287,854
Posts4,935,613
Members67,865
Most Online2,967
Mar 10th, 2019
Best, 5% Moly Heavy Equipment grease #4568249
11/08/17 08:56 PM
11/08/17 08:56 PM
SW Michigan
earthmover1980 Offline OP
SW Michigan
What brand of 5% moly grease do you use on your excavator, loader or other earthmover? I have tried Conoco Phillips 5% moly, DA lubricants 5% moly, Brad Penn 5% moly, Mobil xhp 322, and others. I find these nlgi 2 greases to be too thin and not tacky enough. What suggestions could you offer me on brand, type, and performance? Our biggest issue with Grease is pound out, especially with older equipment with some hours on it.I guess the best product I have used is the Brad Penn lc5. Opinions????
Re: Best, 5% Moly Heavy Equipment grease [Re: earthmover1980] #4568257
11/08/17 09:04 PM
11/08/17 09:04 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
Schafers is loaded with moly also. John Deere has a moly grease also.
I would recomend replacing pins and bushings if you are having pound out issues. Different grease isn't going fix that and it is only going to get more expensive to repair if you try to work through it.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Best, 5% Moly Heavy Equipment grease [Re: earthmover1980] #4568270
11/08/17 09:14 PM
11/08/17 09:14 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Contact BITOG member Damon. He has heavy equipment lube experience. I "think" that he recommends Schaeffers 238. It has water proof aluminum complex thickener, 5%+ moly, and is available in #3 (thicker) grade.
http://www.schaefferoil.com/documents/123-238-td.pdf
Re: Best, 5% Moly Heavy Equipment grease [Re: earthmover1980] #4568786
11/09/17 12:12 PM
11/09/17 12:12 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
Depending on the nature of poundout, you may want to consider a thinner grease. Micromotion applications, such as universal joints, need thinner grease so the grease can reflow under the surfaces once it has been pushed aside.
Re: Best, 5% Moly Heavy Equipment grease [Re: earthmover1980] #4569423
11/10/17 04:47 AM
11/10/17 04:47 AM
New York
Jddan Offline
Jddan  Offline
New York
I'm still waiting to hear from a couple of neighbors as to their experiences with TRC Moly 800 crown & chassis and Moly Paragon 3000. Maybe this be a good excuse to bust out the backhoe and do a little testing...
Re: Best, 5% Moly Heavy Equipment grease [Re: earthmover1980] #4570306
11/10/17 09:33 PM
11/10/17 09:33 PM
Brighton MI,
Rudy1999 250 Offline
Brighton MI,
TRC MOLY 880 Crown and chassis---yes 5% MOLY.. I have Great luck with my Dixie Chopper and Scag ZTR Riders.
They have a Mousetrap type of thing that they use as a Demonstration for what a grease and how it wound Literally Pound out.
A Salesperson/Problem Solver
Re: Best, 5% Moly Heavy Equipment grease [Re: Rudy1999 250] #4570541
11/11/17 07:46 AM
11/11/17 07:46 AM
Brighton MI,
Brighton MI,
The TRC Demo shows how the others ...will pound out ,,, theirs does not.
Paragpn 3000 and 880 Crown and chassis will not.
Re: Best, 5% Moly Heavy Equipment grease [Re: earthmover1980] #4572572
11/13/17 10:33 AM
11/13/17 10:33 AM
Ct. Usa
Bigbill Offline
Bigbill  Offline
Ct. Usa
Tractor supply offers a moly grease too. Not sure of the %. I been purchasing moly grease from www.tsmoly.com
Beforethe moly grease I was using heavy duty grease for construction equipment. Seeingtie rod wear with standard greases it was time to get a extrame pressure grease.
Re: Best, 5% Moly Heavy Equipment grease [Re: earthmover1980] #4574478
11/15/17 05:48 AM
11/15/17 05:48 AM
Northern, NY
Rob_Roy Offline
Rob_Roy  Offline
Northern, NY
TRC 880 with Moly, or Schaeffers 238. TRC 880 w/ Moly or Schaeffers 274 would be a better choice for winter work than the 238.
We have been using TRC 880 in everything for 10 years, and I do not even remember the last time we replaced pins in anything other than equipment that was purchased used. Have never found it necessary to use the moly version.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: Best, 5% Moly Heavy Equipment grease [Re: earthmover1980] #4574635
11/15/17 09:09 AM
11/15/17 09:09 AM
New York
Jddan Offline
Jddan  Offline
New York
Rob Roy, what equipment you running? I've asks a couple of neighbors bout trying moly or the paragon 3000 after using regular 880. Resonse most of the time is "why?"
Re: Best, 5% Moly Heavy Equipment grease [Re: earthmover1980] #4575645
11/16/17 01:40 AM
11/16/17 01:40 AM
Washington
rossum Offline
rossum  Offline
Washington
Premalube Xtreme by certified labs.
Re: Best, 5% Moly Heavy Equipment grease [Re: earthmover1980] #4578056
11/18/17 02:45 PM
11/18/17 02:45 PM
Northern, NY
Rob_Roy Offline
Rob_Roy  Offline
Northern, NY
A Cat D8T, and D6. Volvo 160 excavator, Bobcat S220 skidsteer.
1999 Ford F350, V10
Re: Best, 5% Moly Heavy Equipment grease [Re: earthmover1980] #4578138
11/18/17 05:18 PM
11/18/17 05:18 PM
Brighton MI,
Brighton MI,
I think that TRC 880 Crown and Chassis with MOLY would work great for you.
Re: Best, 5% Moly Heavy Equipment grease [Re: Rob_Roy] #4594292
12/04/17 07:29 PM
12/04/17 07:29 PM
New York
Jddan Offline
Jddan  Offline
New York
That ought to be adequate for testing!
Re: Best, 5% Moly Heavy Equipment grease [Re: earthmover1980] #4605761
12/16/17 08:16 PM
12/16/17 08:16 PM
MT
Dieselfume1 Offline
Dieselfume1  Offline
MT
Aluminium complex grease is not as waterproof as calcium complex..... just cheaper. TRCs grease is the latter, you can guess what everyone else is... there's a reason their grease costs more, and it's not the because of fancy pamphlets, labels, bottles, hats or merchandice.
Moly 880 ftw, Moly Paragon if you need high temp.
