WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
14 registered (billt460, Farmer, Deltona, 4WD, chainblu, AMC), 793 Guests and 36 Spiders online.
65303 Members
67 Forums
285889 Topics
#4565576 - 11/06/17 06:35 AM Using a smaller oil filter?
Spetz Offline
Loc: Australia
Hi guys,
I am about to do an oil change on my car and deciding on which filter to use.
The problem is options in Australia are somewhat limited and I would prefer a synthetic material.
I can get this filter:
http://www.rycofilters.com.au/products/syntec
However it is not available in the size I need which is:
Seam Diameter 71.00mm
Overall Height 101.00mm
Seal Outside Diameter 66.00mm
But rather in this size:
Seam Diameter 69.50mm
Overall Height 86.00mm
Seal Outside Diameter 64.00mm
Both filters have a bypass valve of 15psi.
I run 6k mile OCI on Shell Helix Ultra oil.
Engine has relatively high miles however is clean inside.
Would I be OK running the smaller filter or should I stick to the designated one?
2003 Mitsubishi Diamante 6G74 3.5L. 5 Speed auto. 150,000 miles. Shell Helix Ultra 5W40 at 6k OCI
#4565635 - 11/06/17 07:57 AM Re: Using a smaller oil filter? [Re: Spetz]
javacontour Offline
Loc: Illinois
Here in the US, this engine would take the Fram 7317 or Fram 6607.
The Fram 7317 has the following specifications:
http://oilfilterdata.com/index.php?view=filter_info&model=PH7317
The height of 3.47" works out to 88mm so maybe they are specifying the Fram 7317 as a replacement.
You don't specify the threads on the filter you wish to use, so before I could say go ahead, I'd check to see if the threads are the same.
I know here in the US, there are many filter makers who don't make all the variants in a thread and BPV range. They may offer the smaller choices in the range.
A filter that has the same seal, but is only about 1/2" (15mm) shorter probably won't make much difference. It's done here all the time and you don't see cars on the side of the road because the quick lube used a smaller filter than the "ideal" choice.
network down, IP packets delivered via UPS -BOFH
#4565767 - 11/06/17 10:44 AM Re: Using a smaller oil filter? [Re: Spetz]
mcwilly Offline
Loc: Canada
I think you'd be okay, really just 1.5cm shorter. At 6k changes as long as youve never had issues filling a filter before I can't see it happening now.
2010 Subaru Sti 71,000km
2001 Toyota Echo 232,000km
#4565791 - 11/06/17 11:15 AM Re: Using a smaller oil filter? [Re: Spetz]
ARCOgraphite Offline
Loc: N.H, U.S.A.
You application is the universal Japanese/Korean auto filter (minus Toyota).
How bout an M1 Ep 110A
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#4565806 - 11/06/17 11:28 AM Re: Using a smaller oil filter? [Re: Spetz]
Loc: N.H, U.S.A.
The Fram TG7317 is good too.
#4565814 - 11/06/17 11:41 AM Re: Using a smaller oil filter? [Re: Spetz]
mcwilly Offline
Loc: Canada
Not sure your thread requirement is, but they have your size needed. Just check the threads.
#4565925 - 11/06/17 01:40 PM Re: Using a smaller oil filter? [Re: Spetz]
Yah-Tah-Hey Offline
Loc: Columbus,Nebraska
Use any filter that has the same thread pitch and diameter as the engine adapter. No sense overthinking this. You continue obsessing over oil filters and you'll wind up with the rest of us on BITOG lying to each other abut minutiae covering the whole gamut of human endeavor. Not to demean other members though. There are some very wise individuals here. smile
#4565957 - 11/06/17 02:12 PM Re: Using a smaller oil filter? [Re: Spetz]
PandaBear Offline
Loc: Silicon Valley
I usually look at wix's online data and check for the thread, gasket diameter, and bypass pressure. If they match I'd just use it.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#4566428 - 11/07/17 04:31 AM Re: Using a smaller oil filter? [Re: Spetz]
Spetz Offline
Loc: Australia
Hi guys,
Yes they have the Z456 which is what I need but it doesn't come in the Syntec range hence why I wanted to know if i could use the smaller one?
The thread sizes are the same so they do interchange.
