Thoughts on this truck and price.
by ls1mike. 09/18/18 08:39 AM
Canadian Tire Lucas Synthetic Motorcycle Oil 20w50
by Snagglefoot. 09/18/18 07:58 AM
Blast from my past
by 53' Stude. 09/18/18 07:25 AM
Happy Birthday USAF!
by Astro14. 09/18/18 06:35 AM
Ever had a total engine failure?
by Exhaustgases. 09/18/18 02:58 AM
What is the take rate for AWD in small crossovers?
by slacktide_bitog. 09/17/18 11:12 PM
W10 driver for laptop HD4500 graphics
by asand1. 09/17/18 10:03 PM
Horizontal bladder type water tank freezing?
by WobblyElvis. 09/17/18 10:01 PM
Looking for a new carburetor for 2002 honda 90cc
by KeithCoates. 09/17/18 09:57 PM
2013 Passat fluid change
by Chuckh. 09/17/18 09:25 PM
Android Auto Recommendation
by JeffKeryk. 09/17/18 08:57 PM
Prestone Full Synthetic Power Steering Fluid
by TheLawnRanger. 09/17/18 08:55 PM
MAG1 website is excellent
by wemay. 09/17/18 08:46 PM
Does anyone know of a good free 2D cad program
by JimPghPA. 09/17/18 07:42 PM
AC DELCO PF 63E CUT OPEN
by 53' Stude. 09/17/18 06:36 PM
Last time you purchased new vehicle.
by littleant. 09/17/18 05:31 PM
$100 USD Of Gasoline
by GrtArtiste. 09/17/18 03:30 PM
Odd matchbook cover
by skyactiv. 09/17/18 03:29 PM
What are these on my snowblower?
by LeakySeals. 09/17/18 03:12 PM
tomkat22, tabar2004, SierraMan, Rennmeister, KeithCoates
66004 Registered Users
70 registered members (ARB1977, Ablebody, Armkb, Bear, ARCOgraphite, 6 invisible), 1,117 guests, and 30 spiders.
Topics290,582
Posts4,846,863
Members66,004
Most Online3,590
Jan 24th, 2017
Can I use 80w90 instead of 75w90? #4562401
11/02/17 07:25 PM
11/02/17 07:25 PM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
I have a 01 Corolla with a 5 spd transmission and I would like to change the transmission oil, the owner´s manual calls for a 75w90 GL4 oil and I can only find a 80w90 GL4 and a 75w90 GL5, I have read that GL5 should not be used in transmissions that call for GL4 oil so my only option is 80w90.
Would it be safe to use this oil? The coldest ambient temp here is 68 °F BTW
Re: Can I use 80w90 instead of 75w90? [Re: Emanuel] #4562403
11/02/17 07:27 PM
11/02/17 07:27 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Emanuel you Toyota sure shouldn't be burning much of that 75w90 but cold starts may be for the birds.
2004 Corolla 124642
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: Can I use 80w90 instead of 75w90? [Re: JohnnyJohnson] #4562415
11/02/17 07:40 PM
11/02/17 07:40 PM
Emanuel Offline OP
Emanuel  Offline OP
grin
Re: Can I use 80w90 instead of 75w90? [Re: Emanuel] #4562419
11/02/17 07:43 PM
11/02/17 07:43 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Use the GL4-I made the mistake of putting GL5 75W90 in the xB in my sig, synchronizers wouldn't work correctly, causing bad shifting. Went back to GL4, problem disappeared.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Can I use 80w90 instead of 75w90? [Re: JohnnyJohnson] #4562447
11/02/17 08:12 PM
11/02/17 08:12 PM
Michigan
khittner Offline
khittner  Offline
Michigan
From what I understand, gear oil and engine oil use different viscosity scales; an 80w gear oil is pretty close in thickness/pourability to a 30w engine oil. I wouldn't use gear oil in an engine, but its viscosity may not be a problem.
Re: Can I use 80w90 instead of 75w90? [Re: Emanuel] #4562459
11/02/17 08:30 PM
11/02/17 08:30 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Yes; in your temperature that will be a good oil.
Thick vs Thin test: 15k / 43k miles complete
Re: Can I use 80w90 instead of 75w90? [Re: khittner] #4562461
11/02/17 08:30 PM
11/02/17 08:30 PM
Emanuel Offline OP
Emanuel  Offline OP
I think he was joking
Re: Can I use 80w90 instead of 75w90? [Re: Emanuel] #4562518
11/02/17 08:59 PM
11/02/17 08:59 PM
Midwest USA
LoneRanger Offline
LoneRanger  Offline
Midwest USA
80W90 GL4 should perform properly in that application.
'09 Subaru Forester ...................(QS HM 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
Re: Can I use 80w90 instead of 75w90? [Re: Emanuel] #4562570
11/02/17 09:56 PM
11/02/17 09:56 PM
VA
Gebo Offline
Gebo  Offline
VA
Absolutely
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Can I use 80w90 instead of 75w90? [Re: Emanuel] #4562571
11/02/17 09:56 PM
11/02/17 09:56 PM
Virginia
mattwithcats Offline
Virginia
Ravenol oil guide
http://www.ravenol.de/en/oil-guide.html
RAVENOL MTF-1 SAE 75W-85
: RAVENOL TGO SAE 75W-90
: RAVENOL VSG SAE 75W-90
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Can I use 80w90 instead of 75w90? [Re: Emanuel] #4562726
11/03/17 06:46 AM
11/03/17 06:46 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
'Strange' that your 01 Toyota doesn't recommend GL5.
A 2004 does.
Anyway, go ahead with 80W90 that provides thicker MOFT for stronger components protection.
Shiftability is an 'unpredictable' animal though, never mind it's GL4.
