What would you guys suggest for starter motor grease? In my case, it is a gear reduction unit with 3 metal planet gears and a plastic ring gear.
The original armature shaft grease appeared to be a very dark green, and it was used both in 2 bronze bushings as well as a steel on steel bushing. The planet assembly had what really, really looked like molybdenum sulfide (moly) grease on it (can't be sure) which surprised me because of the plastic. That was a very dark gray in appearance, but smeared out on paper with an almost brown hue to it.
I live in a pretty cold climate, so I was also looking for stuff that had a pretty good temp range.
Thanks for any advice
