Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
105 registered members (ArrestMeRedZ, aquariuscsm, acme, 69Torino, allgm59, asand1, 6 invisible), 2,037 guests, and 61 spiders.
Topics286,236
Posts4,904,920
Members67,582
Most Online2,967
Mar 10th, 2019
Freaking out about my ATF dipstick #4561692
11/01/17 11:14 PM
11/01/17 11:14 PM
Gatineau QC Canada
TheMidnightNarwh Offline OP
Gatineau QC Canada
Ok, I'm a bit freaking out here. Trying to read my dipstick.. I was checking it periodacally to make sure I didn't get any leaking after my ATF and all was good. After the 1st day I noticed it wasn't fully hitting the hot mark so I added and I thought I was good (after re-checking).
Here are some questionse because I don't understand this.
1. Every time I pull it out to check it and do the first wipe before reinserting, the fluid is all dark and black and it's everywhere on it, but pulling it back out I can clearly see bright red fluid at the hot mark? Why is this like this?
2. I checked today and noticed something, after I reinsert after wipe and take it out, the rear side of the dipstick where the cold mark is almost the whole dipstick is covered in fluid while on the hot mark I can see red fluid up until 1/4 full of the hot mark. Is this normal? This is what got me freaking out here.
Could I possibly have had to much fluid all this time? Surely my transmission would have acted weird or major slip? Every time I put the pedal down it accelerated normally.
Re: Freaking out about my ATF dipstick [Re: TheMidnightNarwh] #4561724
11/01/17 11:59 PM
11/01/17 11:59 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
1. I think dipsticks can become somewhat magnetic and attract small ferrous particulate from the fluid
2. Believe the lower one. The side with fluid all the way up is getting smeared inside the tube somewhere.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Freaking out about my ATF dipstick [Re: TheMidnightNarwh] #4561744
11/02/17 12:19 AM
11/02/17 12:19 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
1) the inside of the tube is dirty for some weird reason
2) make sure fill/dipstick tube isn't cracked
Re: Freaking out about my ATF dipstick [Re: TheMidnightNarwh] #4561746
11/02/17 12:22 AM
11/02/17 12:22 AM
Seattle-ish, WA
Oro_O Online content
Oro_O  Online Content
Seattle-ish, WA
Are you checking it while running, after shifting through all gears?
Also, I find on most cars, the only reliable reading is starting with a stone cold engine (transmission). After driving, there's so much fluid splashed around, it drains down the tube and prevents the dipstick from reading accurately. That may be what you are experiencing. Some units may not be as susceptible to this, but it's worth being aware.
The total system capacity is on average about 10qts. Unless you went wild, you can't have added so much as to cause a problem.
Re: Freaking out about my ATF dipstick [Re: Oro_O] #4561769
11/02/17 02:08 AM
11/02/17 02:08 AM
Gatineau QC Canada
Gatineau QC Canada
Yeah as stated in manual, operating temp, engine idling, shift to all gears then go back to neutral.
I added around the same amount that came out. Re-filled the empty new ATF bottle and came out to about 4 full and bit for a fifth one. Originally I had 4 bottles but 4 wasn't enough had to go back to dealer and I have put maybe 300ml more from the fifth bottle. And that's when after the check some bright red fluid I could see in the hot mark.
I noticed in the service manual to check it they don't explicitly say to wipe dipstick and reinsert but I suppose that is already understood since a dipstick you should do that.
Re: Freaking out about my ATF dipstick [Re: Oro_O] #4561771
11/02/17 02:17 AM
11/02/17 02:17 AM
WA state, USA
NothingNew Offline
NothingNew  Offline
WA state, USA
What does the "average" ATF system capacity have to do with the capacity or ATF level of a specific vehicle? I help service two different vehicles that each have a total system capacity of 7.x quarts. Adding 10 quarts would cause a problem.
Re: Freaking out about my ATF dipstick [Re: NothingNew] #4561776
11/02/17 02:42 AM
11/02/17 02:42 AM
Gatineau QC Canada
Gatineau QC Canada
Right. In the service manual the 06 Tucson capacity is 7.8L . But that's a flush, not a change.
I did put back the same ammount of bottles. At least 4 bottles I was sure the fifth one I had some spillage and added about 300ml.
Re: Freaking out about my ATF dipstick [Re: TheMidnightNarwh] #4561779
11/02/17 03:23 AM
11/02/17 03:23 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I found the most reliable way for me to check ATF is to drive the car about half an hour. Park it on perfectly level ground and let it idle at least three minutes, pull the stick and read it. Reinserting the stick and reading it again and again throws the reading off. I check mine in Park, which is what the service manual states for my automatic transmission vehicles.
I'm not sure why you're seeing dark and black fluid. Fortunately that is not something I've encountered. If I did I would drop the pan replace the filter refill the unit take a short drive and do a good line exchange of the fluid.
God Bless Our Troops
Re: Freaking out about my ATF dipstick [Re: demarpaint] #4561802
11/02/17 05:42 AM
11/02/17 05:42 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Its a Hyundai, I don't think they have pans that are removable. Its setup like a Honda with the magnetic drain plug only.
As others said check the level when its cold and parked on level ground. You may need a fluid extractor to remove some ATF.
When I had my 98 sienna I overfilled the tranny by a litre a few different times and had no issues. If its slightly overfilled you are probably OK.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Freaking out about my ATF dipstick [Re: TheMidnightNarwh] #4561911
11/02/17 08:56 AM
11/02/17 08:56 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
Did you just change your ATF fluid? If so sometimes you get air bubbles in the system when you do this and they work themselves out over a few days, causing the fluid level to drop at the dipstick.
Re: Freaking out about my ATF dipstick [Re: TheMidnightNarwh] #4561917
11/02/17 09:09 AM
11/02/17 09:09 AM
New Jersey
Ursatdx Offline
Ursatdx  Offline
New Jersey
Are the Hyundais' not checked in neutral?
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Freaking out about my ATF dipstick [Re: TheMidnightNarwh] #4561976
11/02/17 10:39 AM
11/02/17 10:39 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
If you're gonna check in cold, make sure you also know what the hot reading when idling is. They can be drastically different. I probably have 1-2" difference between hot and cold. But they are always at those same 2 levels. So I can check either way. I too would be concerned about black or white stuff. The dip stick should only show red or brownish red fluid. Black fluid is long past changing. A mixture of those colors is baffling as they could represent air, water, anti-freeze, power steering fluid, and/or motor oil leakage.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Freaking out about my ATF dipstick [Re: NothingNew] #4561978
11/02/17 10:40 AM
11/02/17 10:40 AM
Seattle-ish, WA
Seattle-ish, WA
It is really quite obvious. If he put in 1/2 qt. More, as he was intimating, it would not be fatal. Not rocket science.
Re: Freaking out about my ATF dipstick [Re: TheMidnightNarwh] #4562021
11/02/17 11:46 AM
11/02/17 11:46 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I always check the fluid cold (engine shut-off over night cold) on level ground, and always the way the manual tells you to check it. Some will require the vehicle to be off, some will require the vehicle to be running in neutral, some will request cycling the shifter from Park to Reverse/Drive/Neutral gears etc. before checking. Some can't be checked without a special measuring tool and a temperature chart.
I have never had luck checking it "hot" because if the transmission isn't fully hot as verified by fluid temperature reading then who knows.
As for the slime on the dipstick this normal. My Santa Fe used to always have a nice coating of gunk on the dipstick on the first pull out, and then none on the second pull. It lasted no problem to 535,000km. It's when the fluid is dark and smells burn't or the transmission is shifting strangely that you might have problems to worry about.
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Freaking out about my ATF dipstick [Re: TheMidnightNarwh] #4562068
11/02/17 01:15 PM
11/02/17 01:15 PM
Utah
CKN Offline
CKN  Offline
Utah
Perfect case example of why there doesn't need to be dipsticks in vehicles......
