7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
100 registered members (aquariuscsm, 1foxracing, Astro14, andyd, Alfred_B, 2004tdigls, 5 invisible), 1,558 guests, and 38 spiders.
Topics295,011
Posts4,925,955
Members66,664
Most Online2,553
Oct 27th, 2018
I used an ACEA C3 oil in an A1/B1 application #4560012
10/31/17 08:44 AM
10/31/17 08:44 AM
London ENGLAND
geetar Offline OP
geetar  Offline OP
London ENGLAND
My Toyota has a 1NZ-FE engine.
Previously, I have read on here to use A1/B1 or A3/B3 oils in this engine - which was good advice that I followed.
Last month, whilst on autopilot, I trusted the parts store catalogue which recommended a Shell ACEA C3 oil for my vehicle. I think this is for diesels with/without a DPF. (The Shell labelling isn't that clear, and in the past, I used Shell oil which was A1/B1 rated and the labels look almost exactly the same)
Obviously, this isn't correct. Should I do another oil change or wait the 6,000 miles that I normally do?
Should I be trying to flush every last drop out or just a quick drain and refill?
Will this cause long-term damage?
Also, the oil I would be getting says both A1/B1 and A5/B5 on it. I think this is OK for my engine, any opinions on this?
Thanks, as always, looking forward to some good replies.
Re: I used an ACEA C3 oil in an A1/B1 application [Re: geetar] #4560017
10/31/17 08:53 AM
10/31/17 08:53 AM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
What exactly does your owner's manual specify for the oil? Is it SM? If so, that Shell C3 oil is likely dual rated for SN and you would be good to go.
Either way your engine isn't going to be damaged by the oil you're now using.
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: I used an ACEA C3 oil in an A1/B1 application [Re: geetar] #4560026
10/31/17 08:59 AM
10/31/17 08:59 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
C3 IS for gasoline , other than diesels with DPF.
It would be fine in 1NZ-FE, which recommends SN/SM in the tropics here.
Edit: I have 'seen' C3 Blotter spot test pictures doing well in Asian engines calling for SN/SM.
Re: I used an ACEA C3 oil in an A1/B1 application [Re: geetar] #4560052
10/31/17 09:23 AM
10/31/17 09:23 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Everything is OK...
EU is pushing 5w30 oils...and they in EU are in 99% acea C3
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: I used an ACEA C3 oil in an A1/B1 application [Re: geetar] #4560073
10/31/17 09:35 AM
10/31/17 09:35 AM
Tn.
CourierDriver Offline
Tn.
If you got mental stress from all those abbreviations and were reaching for your stress meds, here you go..................
ACEA A1/B1 Engine Oil
Purchase ACEA A1/B1 Extended Service Car Engine Oil
Looking for an ACEA A1/B1 Low Friction, High Temperature / Sheer Stable Car Engine Oils? Then you've come to the right place, we've got a great range all at great Opie Prices
ACEA A1 / B1 specification is intended to be used in petrol engines (normally cars and vans) or light-duty diesel engines with an extended service interval. The A1 / B1 specification directly indicates that the oil has low friction, high temperature / high shear characteristics, ideal for the older type engines.
Need Engine Oil / Oil & Filter to service? Why not use our online product lookup.
If you're unsure what ACEA spec is correct for your application or have a modified or unique Vehicle why not ask the Opie Experts for a Custom recommendation.
turn in your old jackets, shirts and other clothes to a Salvation Army or any homeless shelter this year...
Re: I used an ACEA C3 oil in an A1/B1 application [Re: kschachn] #4560153
10/31/17 10:49 AM
10/31/17 10:49 AM
London ENGLAND
geetar Offline OP
geetar  Offline OP
London ENGLAND
Actually, it specifies a bunch of stuff that seems to be aimed at the American market. None of the oils in UK parts stores have any of the things the owner's manual says, I was going off the ACEA A1/B1 recommendation from another post I made on this forum a few years ago.
Here's what the manual says for gasoline engines:
API grade SJ "Energy-Conserving", SL "Energy-Conserving" or ILSAC multi-grade engine oil.
API Service SL SAE 10W-30 Energy Conserving.
They don't mean much to me, I've always used ACEA A1/B1 5W-30 as its impossible to find 10W-30 or anything mentioning API or SAE in the UK.
Not sure why the American stuff is mentioned in a European delivered car which was made in Japan - but yeah...
My understanding is the ACEA C spec is for diesel engines with low SAPS - that's my only concern.
Re: I used an ACEA C3 oil in an A1/B1 application [Re: geetar] #4560213
10/31/17 11:37 AM
10/31/17 11:37 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Re: I used an ACEA C3 oil in an A1/B1 application [Re: geetar] #4560248
10/31/17 12:45 PM
10/31/17 12:45 PM
Upper Midwest
Upper Midwest
C is also for gasoline engines, as I think you already understand.
So it says SJ or SL, and (if that is what you have) Shell Helix is ISLAC rated (SN? SJ?). It will be fine, certainly no need to "be trying to flush every last drop out" nor will it "cause long-term damage."
The 1NZ-FE is not hard on oil like some other Toyota engines. The grade designation (5W or 10W) would be irrelevant in your location.
1994 BMW 530i, 238K
Re: I used an ACEA C3 oil in an A1/B1 application [Re: geetar] #4560254
10/31/17 12:49 PM
10/31/17 12:49 PM
Upper Midwest
Upper Midwest
It doesn't really matter, many Euro oils also list ISLAC specifications. Besides that is a global engine made for many markets. Should I be upset when my US-version BMW manual lists an ACEA specification?
1994 BMW 530i, 238K
Re: I used an ACEA C3 oil in an A1/B1 application [Re: geetar] #4560430
10/31/17 04:41 PM
10/31/17 04:41 PM
USA
slacktide_bitog Offline
USA
Even dino can do 6k in a 1NZ
Re: I used an ACEA C3 oil in an A1/B1 application [Re: geetar] #4560534
10/31/17 05:58 PM
10/31/17 05:58 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
That C3 is fine, leave it in there, it's basically a mid-SAPS A3/B3 oil. Also probably API SN rated. Fine for your car, most of Europe is moving from high-SAPS A3/B3/B4 to mid-SAPS C3 due to the high quality of your fuel.
BTW A1/B1 and A5/B5 are very similar, with the A5/B5 being a bit better. The most recent ACEA sequences have removed A1/B1 anyway, soon only A5/B5 will be around.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: I used an ACEA C3 oil in an A1/B1 application [Re: geetar] #4561051
11/01/17 08:42 AM
11/01/17 08:42 AM
London ENGLAND
geetar Offline OP
geetar  Offline OP
London ENGLAND
OK thanks all, I was just concerned that the C3 spec might be specific for diesels only. Thanks again.
Re: I used an ACEA C3 oil in an A1/B1 application [Re: geetar] #4561072
11/01/17 09:00 AM
11/01/17 09:00 AM
West Yorkshire, UK
NGRhodes Offline
NGRhodes  Offline
West Yorkshire, UK
Toyota UK Okay'ed the use of Mobil 1 mid saps in my old Corolla with a 1ZZ-FE 1.8 engine, where A1/B1 was the recommended fill. You could always contact them from their toyota.co.uk website to clarify.
A5/B5 is a longer life version of A1/B1 and fully compatible, so no worries about both being labelled.
Toyota manual is really vague, but I think that is because their city/regular car engines can run quite a wide range of oils without issue.
Re: I used an ACEA C3 oil in an A1/B1 application [Re: geetar] #4561111
11/01/17 09:59 AM
11/01/17 09:59 AM
London, England
bigjl Offline
bigjl  Offline
London, England
I don't think you can have an A1/B1 oil that meets A3/B3.
I always thought C1 was the Low SAPS equivalent of A1/B1
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
