Please, maintain your tires properly
by 53' Stude. 09/25/18 06:58 AM
Cycling health
by CourierDriver. 09/25/18 06:08 AM
Stupidest thing you've ever done (or not done)
by Speak2Mountain. 09/25/18 06:01 AM
First Time Hyundai Owner - Coolant Confusion
by tony1679. 09/25/18 05:16 AM
European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
82 registered members (Bbonez, bernau, Astro14, advocate, Armkb, Anthony, 7 invisible), 1,332 guests, and 32 spiders.
Topics290,975
Posts4,853,597
Members66,063
Most Online3,590
Jan 24th, 2017
Recommended starter motor grease #4558507
10/29/17 04:00 PM
10/29/17 04:00 PM
US
VincentVega Offline OP
US
What would you guys suggest for starter motor grease? In my case, it is a gear reduction unit with 3 metal planet gears and a plastic ring gear.
The original armature shaft grease appeared to be a very dark green, and it was used both in 2 bronze bushings as well as a steel on steel bushing. The planet assembly had what really, really looked like molybdenum sulfide (moly) grease on it (can't be sure) which surprised me because of the plastic. That was a very dark gray in appearance, but smeared out on paper with an almost brown hue to it.
I live in a pretty cold climate, so I was also looking for stuff that had a pretty good temp range.
Thanks for any advice
Re: Recommended starter motor grease [Re: VincentVega] #4558515
10/29/17 04:08 PM
10/29/17 04:08 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Chassis lube for the gears,just a smidge on the starter drive.. The dark green grease may be a marine grease that might be good. I use whatever grease is handy when assemble a DC motor.
Thick oil is better grin2
Re: Recommended starter motor grease [Re: VincentVega] #4558518
10/29/17 04:11 PM
10/29/17 04:11 PM
Idaho
SubLGT Online content
SubLGT  Online Content
Idaho
Quote:
Starter motors must withstand the elements, temperatures from -40C to 200C, and 50,000 duty cycles or more. Issues of high load and torque, especially during cold crank, also have to be considered. Effectively lubricating the motors’ gears, bearings, and splines requires a careful blend of synthetic oils, additives and gellants. Popular starter motor lubricants feature PAO and ester blends with additives for extreme pressure, corrosion protection, and friction reduction.
https://www.nyelubricants.com/powertrain-components
https://www.dowcorning.com/content/auto/automaterial/electrical-lubricants.aspx
Re: Recommended starter motor grease [Re: VincentVega] #4558638
10/29/17 06:28 PM
10/29/17 06:28 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
+1 to the Dow Corning recommendation. They have an excellent line of application specific greases.
Re: Recommended starter motor grease [Re: VincentVega] #4559933
10/31/17 08:23 AM
10/31/17 08:23 AM
US
US
Thanks!
Re: Recommended starter motor grease [Re: VincentVega] #4560194
10/31/17 12:23 PM
10/31/17 12:23 PM
California
nthach Offline
nthach  Offline
California
The Japanese bearing OEMs as well as many electric motor manufacturers are fond of using "synthetic" polyurea thickened greases like Chevron SRI or Mobil Polyrex EM, those greases are bluish green to green in color.
Dow tends to recommend Molykote 33 for most electric motor uses, it's not an EP grease - it's a silcone-based lithium grease that's friendly to most plastics.
You could get away with SRI/EM grease on all the parts. If the bushings are accessible externally or have an oil reservoir, a light non-detergent oil like Zoom Spout might be a better choice.
Re: Recommended starter motor grease [Re: VincentVega] #4562184
11/02/17 03:25 PM
11/02/17 03:25 PM
US
US
thank you!
