Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
81 registered members (andrewp1998, Artem, 4WD, amblerman, 14 invisible), 2,143 guests, and 40 spiders.
Topics295,106
Posts4,927,910
Members66,688
Most Online2,553
Oct 27th, 2018
Meat Smokers #4558227
10/29/17 08:51 AM
10/29/17 08:51 AM
ohio
whip Offline OP
whip  Offline OP
ohio
I'm looking to get a smoker. I don't know much about them. I've looked at high end units from Weber and Traegger down to entry level units from Chargrill and Charbroil. What are the pros and cons of electric, propane, charcoal or wood pellets? What size do you have?
On the internet, people can be anything they want. Why do so many choose to be stupid?
Re: Meat Smokers [Re: whip] #4558266
10/29/17 09:26 AM
10/29/17 09:26 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I wouldnt go electric. Wood pellet is easy..maintains temp on its own. Start it and walk away. I think the true challenge is practicing and maintaining grill temps i use a weber charcoal bbq. (150$ grill) and use the snake method with charcoal. This requires practice and patience to maintain temps so if you plan to start it and walk away, go with a pellet smoker. I prefer taste of charcoal and wood together. I do plan on buying a pellet smoker down the road. Go read up on this site:amazingribs.com Tons of great info and advice, buying guides on grills etc..personally, if you wana practice do it on a weber charcoal bbq and learn to smoke on it first..after that get a pellet smoker.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Meat Smokers [Re: whip] #4558269
10/29/17 09:38 AM
10/29/17 09:38 AM
Georgia
AVB Offline
AVB  Offline
Georgia
Electric, propane, or pellet are like using an oven. I would consider a pellet grill as a electric. I have used a Traegger and it is really easy to use and makes good food. At home all I use is wood fire to smoke, I like the vertical water smokers, but the cheap ones like I have are hard to control the temp on. A horizontal barrel type grill with a firebox would be better for cooking larger quantities of food though. I have one of the little Acorn Jr.s that is pretty neat, it is amazing how little fuel it needs to cook.
Re: Meat Smokers [Re: whip] #4558272
10/29/17 09:39 AM
10/29/17 09:39 AM
WV
jonnied1 Offline
jonnied1  Offline
WV
I went from a Chargriller SMOKIN' OUTLAW GRILL to a Masterbuilt 40 DIGITAL ELECTRIC SMOKER with Bluetooth.
Love the electric grill, set the temp and forget it. Just add wood chips to the wood tray (don't even have to open the door).
The fire box rusted out on my Chargriller after several years. The Chargriller was also a pain to clean the inside.
Re: Meat Smokers [Re: whip] #4558273
10/29/17 09:41 AM
10/29/17 09:41 AM
Georgia
AVB Offline
AVB  Offline
Georgia
It really depends on what your goals are, how much work you want to put in, how much do you need to cook. Any method can get good results with the right person cooking on it.
Re: Meat Smokers [Re: whip] #4558283
10/29/17 09:56 AM
10/29/17 09:56 AM
Minnesota
leje0306 Offline
leje0306  Offline
Minnesota
Im smoking a 6.5 lb brisket flat on my big green egg at the moment. BGE is expensive, but the results are nothing short of amazing and they last forever.
Natural lump charcoal burns longer and hotter. Ceramic kamado style grills trap moisture and maintain a perfectly even temp.
Re: Meat Smokers [Re: whip] #4558295
10/29/17 10:24 AM
10/29/17 10:24 AM
out there
spasm3 Online content
spasm3  Online Content
out there
I have a masterbuilt electric smoker. I don't get enough of a good smoke with it. I smoke my turkeys on an off set grill for an hour, then they go into the masterbuilt smoker.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: Meat Smokers [Re: whip] #4558334
10/29/17 11:08 AM
10/29/17 11:08 AM
Texas,USA
ATex7239 Offline
ATex7239  Offline
Texas,USA
We have the Pitt Boss 700 and love it.
Present situation...
'12 Buick Enclave 150,xxx
Valvoline ML SynBlend 5w30
ACDelco PF63E
'17 Ford Fusion (Company Lease) 54,xxx
Oil � Don't know
Filter � Don't care
Re: Meat Smokers [Re: whip] #4558340
10/29/17 11:16 AM
10/29/17 11:16 AM
TX
KJSmith Offline
KJSmith  Offline
TX
I am a BGE/lump charcoal guy also.
I will never go back.
However, whatever you get take the time to learn how to use it to your best advantage.
I am sure everyone who has responded is happy with the results they are getting and have taken the time to learn their grill/smoker and method.
Re: Meat Smokers [Re: KJSmith] #4558344
10/29/17 11:26 AM
10/29/17 11:26 AM
out there
out there
Very true, whatever you go with, there will be a learning curve.
Re: Meat Smokers [Re: whip] #4558374
10/29/17 12:14 PM
10/29/17 12:14 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I have an electric smoker. Much like the one pictured above. It works best when loaded up. Tons o smoke and mighty tasty meats.
No, the flavor is not the same flavor as my charcoal unit. (Charcoal rules! ) but its easy and different is not worse or in any way a bad thing. The electric does not get hot enough to melt fat, so I find I like lean meats in it.
Re: Meat Smokers [Re: whip] #4558386
10/29/17 12:33 PM
10/29/17 12:33 PM
Warner Robins, GA
nwjones18 Offline
nwjones18  Offline
Warner Robins, GA
I've had a side firebox smoker in the past and have a masterbuilt electric now. While the electric won't make bark that is quite as good as charcoal the ease of use outweighs whatever minor negatives there may be. I'm electric for life now.
1988 F-150. 4.9 I6 247k. 10w-40 Castrol Syn-blend ACDelco UPF2.
2005 Cadillac STS N* 108k. 5w-30 Castrol Magnatec ACDelco Classic PF61
Re: Meat Smokers [Re: whip] #4558441
10/29/17 01:22 PM
10/29/17 01:22 PM
CA
raytseng Offline
raytseng  Offline
CA
if you do get a masterbuilt, you should hold judgement and only consider it with the external smoke attachment which is only $60extra. dont even consider it if you're trying to smoke with only the main unit alone.
i think a big decision point on what setup depends on if youre going for brisket and need 10hrs+ of cook time,
so if you plan on waking up 4times a night to check and feed the unit, or if you want to set it and forget it and sleep so you can actually entertain and have fun on your sunday party.
Re: Meat Smokers [Re: ATex7239] #4558493
10/29/17 02:31 PM
10/29/17 02:31 PM
Northern Arizona
funflyer Offline
funflyer  Offline
Northern Arizona
That's the same one I have. Great grill. The only downside I can see is it has a cheap burn pot. Mine is starting to corrode after three seasons and will probably have to be replaced within the next two. I plan on fabricating a new one using stainless steel.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Meat Smokers [Re: whip] #4558500
10/29/17 02:44 PM
10/29/17 02:44 PM
Michigan
Spartanfool Offline
Spartanfool  Offline
Michigan
If you decide to go charcoal, be sure to look at the Weber Smokey Mountain cooker. It comes in three sizes and is bulletproof. I've had mine for 22 years and never replaced a part.
Here's a fan website. http://virtualweberbullet.com/
