CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
69 registered members (alarmguy, antik, Amenhotep, Anthony, 2015_PSD, 4WD, 8 invisible), 840 guests, and 31 spiders.
Topics287,675
Posts4,932,065
Members67,838
Most Online2,967
Mar 10th, 2019
MC FL910S, 8000 miles #4556974
10/28/17 09:36 AM
10/28/17 09:36 AM
New England
Peter_480 Offline OP
New England
Took this off my Fusion after 8K. Oil was MC semi-syn 5W20. I used a sawzall to open it so some small bits of metal ended up in the bottom of the can, so that's what you're seeing. When I first opened and drained it, it was totally clean and had no sludge or metal particles whatsoever.
It appears to me that the 910S is a rock solid filter and not subject to any quality issues.
'10 Ford E250 4.6L
'11 Ford Fusion 2.5L
Re: MC FL910S, 8000 miles [Re: Peter_480] #4556985
10/28/17 09:49 AM
10/28/17 09:49 AM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Id say it looks great smile. Thanks for c&p
Re: MC FL910S, 8000 miles [Re: Peter_480] #4557004
10/28/17 10:02 AM
10/28/17 10:02 AM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
Looks real good, I'm sure that'll disappoint some members here grin. That's what I use with the 2.3 EB in our Explorer. I ran it for 7,000 miles using Mobil 1 5W-30 and the insolubles were .2%, a good reading indicating the filter is doing it's job from what I observe. It's a much smaller filter than the FL820S so maybe it's less prone to tearing.
Whimsey
Re: MC FL910S, 8000 miles [Re: Whimsey] #4557030
10/28/17 10:26 AM
10/28/17 10:26 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
2.3 EB uses a 3/4"-16 thread filter?
Not 22mm like the FL500S uses?
Re: MC FL910S, 8000 miles [Re: Whimsey] #4557059
10/28/17 10:47 AM
10/28/17 10:47 AM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
Whimsey
This. This one does look good.
2004 Ford Ranger 4.0L V6
Valvoline Advanced Full Synthetic HM 5W30 + WIX 51372
Re: MC FL910S, 8000 miles [Re: Peter_480] #4557095
10/28/17 11:22 AM
10/28/17 11:22 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Looks excellent at a substantial 8k miles. As for the other topic of discussion, 'generally speaking' with the exception of the 820S, the MC post use anecdotes have looked good. Though not all posted here are, the 820 seems to be the weak link.
Thanks for c&p.
Re: MC FL910S, 8000 miles [Re: Linctex] #4557100
10/28/17 11:25 AM
10/28/17 11:25 AM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
Yes, some say it's interchangeable with the slightly larger FL400S. It gets confusing coming from the same vehicle manufacture, some metric some imperial. As I understand the FL500S is a slightly smaller version of the FL820S (metric) and will work in it's place. In fact it appears to have replaced the FL820S on engines that originally used the 820S. The FL910S is a small filter but I guess if you start with a clean engine and maintain it it'll do just fine.
Whimsey
Re: MC FL910S, 8000 miles [Re: Peter_480] #4557109
10/28/17 11:35 AM
10/28/17 11:35 AM
New England
New England
Totally forgot to mention - vehicle has 114K on it. Thanks for the feedback so far. I was a little worried what I might find based on what I have read here, but was very pleasantly surprised. The media was still very firm and intact. It certainly could not be damaged by just finger pressure.
'10 Ford E250 4.6L
Re: MC FL910S, 8000 miles [Re: Sayjac] #4557117
10/28/17 11:39 AM
10/28/17 11:39 AM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
Thanks for c&p.
Agreed.
I believe Ford or Motorcraft is aware the FL820S design is weak and is migrating to a smaller diameter filter in more recent engines. The pleat spacing of the smaller diameter filters is closer/better as observed by cut&posts on BITOG.
Re: MC FL910S, 8000 miles [Re: Peter_480] #4557676
10/28/17 08:03 PM
10/28/17 08:03 PM
New England
New England
I have an 820S off my truck to cut open soon. It only has 2K miles on it so probably not a good example of typical 820S problems, but will still be interesting.
'10 Ford E250 4.6L
Re: MC FL910S, 8000 miles [Re: Peter_480] #4557693
10/28/17 08:15 PM
10/28/17 08:15 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
It will likely do well in 2000 miles. It will likely have the wide pleat spaces near the media seam. This is the location where the tears form. The filter has to load sufficiently so that delta p can put stress on the media. You might also see some rust on the end caps.
Re: MC FL910S, 8000 miles [Re: Peter_480] #4557726
10/28/17 08:35 PM
10/28/17 08:35 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
Very well stated Peter_480! ALL MC oil filters are top quality oil filters!
(I'm getting this strange feeling we will start seeing pics of "supposed" MC oil filter failure pics! shrug )
2007 F150, 4.2 V6
Havoline HM 5W20, NAPA GOLD FIL-1516 MC FL-400S
Re: MC FL910S, 8000 miles [Re: BlueOvalFitter] #4557765
10/28/17 09:05 PM
10/28/17 09:05 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
BOF, you still think it never happened or can't happen?
Re: MC FL910S, 8000 miles [Re: Peter_480] #4557887
10/28/17 10:51 PM
10/28/17 10:51 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
I've used MC FL910s for several years and they all looked fine. My 2007 Fusion takes the MC FL2017 Cartridge. I have tried other brands(Fram, M1, etc) in the 2007 Fusion and they all seemed to collapse and twist a bit. The MC has never done that. Am due for an oil change soon, so perhaps I will post a pic if I can still figure out how it's done.
2007 Ford Fusion 240,000 miles
M1 0-20 EP
2017 Ford Fusion 69K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: MC FL910S, 8000 miles [Re: tig1] #4557916
10/28/17 11:26 PM
10/28/17 11:26 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Just upload the photos through the Post window. Click the icon in the red circle to upload photos from your computer.
