SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
83 registered members (aba4430, 28oz, A310, Alfred_B, 9 invisible), 1,886 guests, and 42 spiders.
Topics294,988
Posts4,925,508
Members66,660
Most Online2,553
Oct 27th, 2018
Using very fine steel wool on windshields #4556038
10/27/17 08:04 AM
10/27/17 08:04 AM
NJ
JLawrence08648 Offline OP
NJ
There's a number of YouTube videos using very fine steel wool on your windshield. The problem with any windshield after a period of time you get all these little nicks and micro fine scratches and it's never really super clear. By using very fine steel wool it removes these fine scratches. I have used very fine sandpaper on discolored headlight lenses to remove the discoloration and it came out perfect then I coated with a liquid coating to maintain it. If you can use sandpaper on headlights, why can't you use very fine steel wool on windshields?
Re: Using very fine steel wool on windshields [Re: JLawrence08648] #4556089
10/27/17 08:52 AM
10/27/17 08:52 AM
Iowa
Iowegian Offline
Iowegian  Offline
Iowa
Did a quick google on it. Some say okay some say not to.
0000 only. Definitely not 000.
Definitely not on the inside.
I would think that even if 0000 was safe, i would not trust the quality control factor.
Sure there are plenty of other stuff out there that IS safe and will clean it off.
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: Using very fine steel wool on windshields [Re: JLawrence08648] #4556127
10/27/17 09:26 AM
10/27/17 09:26 AM
SE Michigan
MichiganMadMan Offline
SE Michigan
I use Bon Ami 1886 formula (and ONLY the 1886 formula, it's a red label can) and a moist micro fiber towel and buff lightly. You'll be amazed what comes off when you first start.
2015 Chevrolet Impala
2008 Subaru Impreza STI
2004 Suzuki Hayabusa
1987 Honda VFR700F2
2011 Jonsered 2188 Chainsaw-The Judge.
Re: Using very fine steel wool on windshields [Re: JLawrence08648] #4556136
10/27/17 09:30 AM
10/27/17 09:30 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
I use Ajax cleanser and cotton towel and plenty of water. Tempered glass is hard enough that all you will remove is rain/water spotting, etc.
Other glass can be scratched. Go slow, do out of the way area first, etc.
There are plenty of times when folks have tried tooth paste. Sometimes it works well, others not so much ...
Re: Using very fine steel wool on windshields [Re: JLawrence08648] #4556142
10/27/17 09:34 AM
10/27/17 09:34 AM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
I've used a clay bar on auto glass to get rid of hard water spots. Might try the steel wool on a corner/passenger side/top first and see if causes any glare problems.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Using very fine steel wool on windshields [Re: JLawrence08648] #4556148
10/27/17 09:40 AM
10/27/17 09:40 AM
Virginia Beach
Astro14 Online content
Astro14  Online Content
Virginia Beach
I wouldn't. Too coarse and you risk scratching the glass.
Cerium oxide is hard enough to polish glass while being fine enough to avoid visible scratches.
Griots for example, has a good set of products, and I've used them with good success, using my Griots polisher, on high mileage windshields. They make a difference and as a bonus, the wipers work better after polishing.
Griots fine glass polish
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Using very fine steel wool on windshields [Re: MichiganMadMan] #4556168
10/27/17 09:56 AM
10/27/17 09:56 AM
n.c.
gman2304 Offline
gman2304  Offline
n.c.
This ^
Re: Using very fine steel wool on windshields [Re: JLawrence08648] #4556212
10/27/17 10:53 AM
10/27/17 10:53 AM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
The Ford Escape I purchased from a body shop had some what seemed to be speckles of paint overspray on it. I went back, and asked if there was a solution. They told me to use 0000 steel wool. Well, it worked great! It doesn't even require hard scrubbing, just gently rubbing with a little pressure, and except for the spots I missed cleaning it is effective and didn't scratch my windshield.
2010 Ford Escape 2.5~91K Miles: AMSOIL SS 5W-30, AMSOIL SS FE ATF.
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30, AMSOIL OE MV ATF.
AMSOIL
Re: Using very fine steel wool on windshields [Re: JLawrence08648] #4556291
10/27/17 12:22 PM
10/27/17 12:22 PM
North TEXAS
oldoak2000 Offline
oldoak2000  Offline
North TEXAS
0000 only and DRY only.
Works GREAT!
Awesome on home windows too!
OUTSIDE only (on both).
Re: Using very fine steel wool on windshields [Re: JLawrence08648] #4556393
10/27/17 02:39 PM
10/27/17 02:39 PM
Upstate NY
Wheel Offline
Wheel  Offline
Upstate NY
Glass has a Brinell hardness around 1550 HB, steel is around 120 HB. I don't see an issue using it dry on the outside and cleaning the cowling with a vac after. Inside, windshields usually have a plastic layer which would be scratched with steel wool.
I've used it with success removing overspray. Clay works for that as well without worrying about fines.
2009 Subaru Legacy (N/A)
Castrol Edge and Subie (Fram) filter
Re: Using very fine steel wool on windshields [Re: JLawrence08648] #4556432
10/27/17 04:07 PM
10/27/17 04:07 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
000 will not harm automotive glass. 0000 is obviously fine too, it probably just takes more work.
Re: Using very fine steel wool on windshields [Re: JLawrence08648] #4556503
10/27/17 05:26 PM
10/27/17 05:26 PM
connecticut
CT Rob Offline
CT Rob  Offline
connecticut
I detailed new and used cars for 15yrs and used 0000 steel wool on all of them inside and out and the glass never got scratched.Yes if there is dirt or sand on the wool sure you could scratch it but this after washing so all was clean.
2017 Toyota Tundra SR5 Crewmax 4x4 Trd offroad.Inferno Orange.All stock for now....
Re: Using very fine steel wool on windshields [Re: JLawrence08648] #4556509
10/27/17 05:31 PM
10/27/17 05:31 PM
UT
BHopkins Offline
BHopkins  Offline
UT
I've used 0000 steel wool to clean windshields for a few years now. I use it with Sprayway glass cleaner. It does a great job of cleaning the windshield of all the dirt that doesn't come off with only a paper towel or such. But I honestly don't think it does anything to clear up all the little micro scratches in a windshield. Maybe it does. But I have never noticed any difference.
And contrary to the naysayers, 0000 steel wool does not scratch the windshield. The only risk is scratching paint that surrounds the windshield. It takes care to not touch the paint. But the same is true of Bon Ami or any of the other similar cleaners.
2013 Subaru Outback 2.5i - Idemitsu 0W-20 & Mobil 1 filter
2007 Mercedes SL550 - M1M 5W-40 & MB OEM filter
