Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
109 registered members (16HC, 380SLbenz, 1978elcamino, 1WildPig, 2012AccentSE, ABerns, 9 invisible), 2,118 guests, and 130 spiders.
Topics286,197
Posts4,904,032
Members67,576
Most Online2,967
Mar 10th, 2019
Fastener humor - special screws #4555283
10/26/17 03:59 PM
10/26/17 03:59 PM
Where the wind comes sweepin'
Reddy45 Offline OP
Reddy45  Offline OP
Re: Fastener humor - special screws [Re: Reddy45] #4555391
10/26/17 05:58 PM
10/26/17 05:58 PM
Northern Ontario, Canada
Danno Offline
Danno  Offline
Wow, someone had a lot of free time on their hands ....
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: Fastener humor - special screws [Re: Reddy45] #4555427
10/26/17 06:20 PM
10/26/17 06:20 PM
USA
SOHCman Offline
SOHCman  Offline
USA
Don't read this thread at work or you'll be screw'd! wink
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Fastener humor - special screws [Re: Reddy45] #4555455
10/26/17 06:32 PM
10/26/17 06:32 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
And I thought I was screwed. Who knew! LOL
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Fastener humor - special screws [Re: Reddy45] #4555463
10/26/17 06:35 PM
10/26/17 06:35 PM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
some good ones there! 903 would be a hot seller im sure!
2013 escape 2.0 awd mobil 1 10w30ep
2008 fusion 2.3 mtx redline 0w20
1996 f150 4.9 2wd mtx mobil 1 10w30hm
1999 kaw zrx 1100 redline 10w40
many husqvarnas
Re: Fastener humor - special screws [Re: justintendo] #4555465
10/26/17 06:36 PM
10/26/17 06:36 PM
Reddy45 Offline OP
Reddy45  Offline OP
As long as it isn't used for a blind hole...and the chips from drilling/tapping don't clog the threads...then it might actually work!
Re: Fastener humor - special screws [Re: Reddy45] #4555584
10/26/17 08:25 PM
10/26/17 08:25 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Whacking screw for unthreaded screwing LOL.
Nearly died laughing on that one.
Re: Fastener humor - special screws [Re: Reddy45] #4555698
10/26/17 10:04 PM
10/26/17 10:04 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Some of these actually exist, like DIN 903 .... but are very expensive
Re: Fastener humor - special screws [Re: justintendo] #4555699
10/26/17 10:04 PM
10/26/17 10:04 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
They are real - just very expensive
Re: Fastener humor - special screws [Re: Reddy45] #4555846
10/27/17 02:42 AM
10/27/17 02:42 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
898...flatmate in Uni wanted to hang something on a vertical wooden post...told him to grab my toolbox, and found him hammering woodscrews in...he graduated first class honours in engineering.
881 - used in British Steam turbines.
887 - used in british turbines (there's another one called a "cheese head", which has a ridiculously large "cheese" head so that the flat bladed screwdriver is less likely to mangle it.
891, 892, 896, 897 - when we built Mount Piper, the HVAC company had a lot of ductwork stuff manufactured off site, and installed on site. The inspector noticed that only 1/3 of the bolts and nuts were installed, climbed a ladder and checked...the holes were misaligned (and needed an 875 really). Two days later, they told him it had been fixed.
Expecting them to have slotted the holes, and weakened the joint, he found them to be really good looking. But the back didn't match the front...they epoxied heads on one side and cut off bolts with nuts the other.
894, you can get structural lock washers like that, anti run back and can check crush for right pre-tension.
900, you can get torque limiting screws...usually snap off
893 - sort of already exist, in aerospace.
910, drawer handles come with those, break off to length.
905, with LH thread and right hand thread are used in rigging levelling equipment.
But the loser is the "superbolt"...When I was in turbines, the salesmen for these would be around all the time...
Design of steam turbine casing joints is quite specific, the bolt is installed at 0.15% strain, and the joint integrity relies on the effective length of the bolt being known, and the nut being a solid, square anchor point/end stop...we tension them by induction heating the stud (or hydraulic stretch), then rotating the nut through a specified rotation to get the strain correct.
These introduce "ease", but include additional elastiicity, and misalignment potential...I feel sorry for those fooled into them.
Re: Fastener humor - special screws [Re: Shannow] #4557269
10/28/17 01:33 PM
10/28/17 01:33 PM
WV
jonnied1 Offline
jonnied1  Offline
WV
Super Bolts are great when used for the right application. We used them to bolt the flanges (3in. dia. studs, 48 in. dia. flanges) to the universal joints on large rolling mills. Prior to that, we had to use a hydraulic torque wrench suspended from an overhead crane.
