Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
87 registered members (arowbat, Astro_Guy, addyguy, 928, a2gtinut, 3311, 8 invisible), 1,895 guests, and 63 spiders.
Topics286,183
Posts4,903,727
Members67,574
Most Online2,967
Mar 10th, 2019
Fogging cylinders for winter storage #4554288
10/25/17 03:28 PM
10/25/17 03:28 PM
Danh Offline OP
Danh  Offline OP
When storing a car for the winter does anyone fog the cylinders?
I store my MX5 in an unheated garage in a cold part of the country. It will be untouched from about now until Mid-May. I've stored it for a number of years without trouble but have always fogged the cylinders as part of the winterization process. Is this a waste of time? Do others not do this and also have trouble-free springs? Any value or just a placebo?
Thanks!
Re: Fogging cylinders for winter storage [Re: Danh] #4554303
10/25/17 03:45 PM
10/25/17 03:45 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
People do this with boats to fight corrosion from moisture. Has your Mazda seen much water? laugh
Not sure how to add the fogging spray on a fuel injected engine other than removing the spark plug and giving them a spray.
I would add some fuel stabilizer and run the engine on the highway and until hot and call it good.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Fogging cylinders for winter storage [Re: dlundblad] #4554308
10/25/17 03:51 PM
10/25/17 03:51 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I would do the same. I'd top off the tank with gas on the way home and connect it to a battery maintainer as well.
Re: Fogging cylinders for winter storage [Re: Danh] #4554321
10/25/17 04:07 PM
10/25/17 04:07 PM
Danh Offline OP
Danh  Offline OP
Done the full tank, gas stabilizer and long run before storage. Battery is removed and stored in a heated basement. And yes, fogging the cylinders involves removing spark plugs and spraying into the cylinders. Not a ton of work, just not sure I'm accomplishing anything worthwhile.
Not a lot of moisture exposure. Well, except it was out in a brief rain shower in August...
Re: Fogging cylinders for winter storage [Re: Danh] #4554335
10/25/17 04:21 PM
10/25/17 04:21 PM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
fogging spray on a car is overkill IMHO. A liberal dose of fuel stabilizer in your fuel is easily enough to accomplish the desired upper lubricant your looking for.
Usually you'll know you've added enough stabilizer, when there's a noticeable difference in performance (less power).
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Fogging cylinders for winter storage [Re: Danh] #4554339
10/25/17 04:24 PM
10/25/17 04:24 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
I worked for a guy once that tried to fog a 3208 Cat with Marvel Mystery Oil. Thing took off on him. He stuffed a pillow from the sofa in the boat into the air intake to stop it.
Re: Fogging cylinders for winter storage [Re: NYEngineer] #4554346
10/25/17 04:37 PM
10/25/17 04:37 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Fogging a diesel ! LOL LOL LOL duh duh duh crackmeup crackmeup crackmeup crackmeup crackmeup crackmeup crackmeup crackmeup crackmeup crackmeup crackmeup crackmeup crackmeup crackmeup crackmeup
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Fogging cylinders for winter storage [Re: Danh] #4554456
10/25/17 06:29 PM
10/25/17 06:29 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Boats typically get fogged through the carb often with 2 cans of stabilizer at once. The goal is to stall the engine.
I could see the fogging oil not being good for a cat in the car.
2015 Ford F250 w/Powerstroke
Re: Fogging cylinders for winter storage [Re: Danh] #4554476
10/25/17 06:46 PM
10/25/17 06:46 PM
NY
demarpaint Offline
demarpaint  Offline
NY
What I've done in lieu of fogging the engine in my son's car prior to his deployments is have him pour in a quart of MMO along with a few ounces of Stabil Marine in the gas tank at the gas station and fill it up. Then drive to where it is going to be parked, park it and do any final preparation. It will not foul plugs, and it won't kill the cat converter. It will leave a residual film of MMO on the cylinder walls.
You can also do it with TCW3 which would probably leave a better film, although I'm not sure of a safe dose. I'd probably use a pint to a 20 gallon tank of gas for storage purposes. We've used TCW3 for this purpose in 4 cycle boat engines with good results, I'd have to check with my brother on the dose.
God Bless Our Troops
Re: Fogging cylinders for winter storage [Re: Donald] #4554480
10/25/17 06:48 PM
10/25/17 06:48 PM
Danh Offline OP
Danh  Offline OP
The idea here (per the aerosol can) is to introduce fogging spray with the engine off and cold, leaving an anti-corrosion coating on the surfaces of the cylinder and piston rings. But maybe this is already taken care of with residual engine oil.
Don't think this method would have any effect on the cat, but may not do any good either.
Re: Fogging cylinders for winter storage [Re: Danh] #4554510
10/25/17 07:26 PM
10/25/17 07:26 PM
Chicago Suburbs
Nitronoise Offline
Nitronoise  Offline
Chicago Suburbs
ok my question is why would you fog it then run it until its hot and burn off the fogging oil ??????
I have always fogged when shut down pull the plugs spray your fogging agent into the cylinders and rotate a few turns to ensure even coating and put the plugs back in or am I doing something wrong here for the last 35 years of storing small engines and summer cars
07 Ford Freestyle 135K
06 Honda Acord EX 115K
04 Hyundai Sonata 290K sold
03 Hyundai Santa Fe 165K
02 Ford Tarus 98K
00 Buick Regal SC 135K
95 Goldwing 28K
Re: Fogging cylinders for winter storage [Re: Nitronoise] #4554553
10/25/17 08:08 PM
10/25/17 08:08 PM
Danh Offline OP
Danh  Offline OP
I don't run after fogging, it's the last step in the process just as you have been doing.
Re: Fogging cylinders for winter storage [Re: Nitronoise] #4554811
10/26/17 04:58 AM
10/26/17 04:58 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Exactly. After you fog it don't start it, you want that fogging oil to remain not burn it off. I fog small engines exactly the same way as you do. IMO you're not doing anything wrong.
Re: Fogging cylinders for winter storage [Re: Danh] #4554843
10/26/17 06:13 AM
10/26/17 06:13 AM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
I don't know if you should fog or not. I will say this, people with boats (even fresh water boats) fog. And tbh, the environment of a inboard motor on a boat is really no different than that of your car. The moisture levels inside the engine bay are very similar (your car drives through rain storms...right?). So either the boat people are un-necessarily fogging or the car people are not fogging enough.
On my boat I used to fog by spraying fogging oil in the carb. About 20 seconds and then shut it down. One year I pulled the plugs and sprayed directly. I think the idea of using 2 stroke oil is pretty good except I don't want to pollute a full take of gas with it. I would do it with an almost empty tank, run it, shut it off, then fill the tank with clean gas.
Re: Fogging cylinders for winter storage [Re: Danh] #4554943
10/26/17 09:04 AM
10/26/17 09:04 AM
MN
Tundragod Offline
Tundragod  Offline
MN
Fog it and fogget about it! lol.
I sprayed fogging oil thru the spark plug hole for 10 seconds, per can direction. Turned the ignition to cycle the cylinder for 1 second with spark plugs out. Put the plugs back and store it.
For over 20 years, I fogged and not fogged my motorcycle. Didn't see any difference.
12 Highlander limited, 08 Accord EXL 4, 04 MDX Tour, 02 CRV EX, 1995 Virago.
