Originally Posted By: justintendo
i have a few medical "one time use only" hypodermic needles...the ones with the screw on tips. with a large needle they suck up whatever lube you want and place it exactly where you like. i use this to lube motorcycle cables and a surprising amount of stuff.
this way im not limited to what packaging a product i like comes in, altho i do like sea foam "deep creep" for most any light viscosity lubing.
Snag with that is many oils and most solvents will attack the rubber piston gasket. You can avoid that by using two syringes in tandem. First syringe with piston all the way out, second syringe cable tied to the first ones piston plunger, with its needle through the first ones gasket.
Since IV HDMO is contra-indicated for most conditions, I file the point off the first syringe needle, if I can be bothered.
