Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
72 registered members (ammolab, Bandito440, aquariuscsm, Auae85, 4WD, 5 invisible), 1,294 guests, and 33 spiders.
Topics290,917
Posts4,852,482
Members66,055
Most Online3,590
Jan 24th, 2017
Furnace check up #4548116
10/19/17 10:29 AM
10/19/17 10:29 AM
n.c.
gman2304 Offline OP
gman2304  Offline OP
n.c.
Trane NG furnace 23 years old. Last winter flame would cycle on and off during a heat cycle so I cleaned the flame sensor and all was well. It is a little chilly this morning so I started the furnace and flame would light extinguish then relite after a minute or so. I ordered a new OEM flame sensor from Amazon for $7 shipped. Just a reminder, you might want to make sure your furnace is working as it should before it gets too cold.
Re: Furnace check up [Re: gman2304] #4548118
10/19/17 10:32 AM
10/19/17 10:32 AM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
Yeah my 5 year old furnace needed a new gas pressure switch because it would intermittently stop firing up and then error out. Luckily it was under warranty but it is always good advice to test it early! thumbsup
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Furnace check up [Re: gman2304] #4548155
10/19/17 11:10 AM
10/19/17 11:10 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
I wish I had gas but I have an oil burner. Sacrilege on this site!
30+ years old Burnham Boiler.
Tough these days keeping that old guy going!
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Furnace check up [Re: gman2304] #4548191
10/19/17 11:36 AM
10/19/17 11:36 AM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
My old furnace before this gas one was oil but it cost us $2500 one winter and so that was a no brainer to replace. Gasoline here is about $4 a gallon and home heating fuel (similar to diesel) is not much better than that.
My natural gas bills now are about $300 for the same amount of time that the $2500 would cover.
thumbsup
Re: Furnace check up [Re: gman2304] #4548200
10/19/17 11:42 AM
10/19/17 11:42 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
LOL planning ahead isn't that a lot to expect these days?
2004 Corolla 124831
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: Furnace check up [Re: gman2304] #4548216
10/19/17 11:56 AM
10/19/17 11:56 AM
California
nthach Offline
nthach  Offline
California
My parents had to wait a month for a new control board on their Trane XV95 and while the installer gave us a break(free part, paid the labor to slap it in), they said annual check-ups are a prereq for warranty service.
Speaking of which, I need to schedule a call with them for a checkup.
Re: Furnace check up [Re: gman2304] #4548219
10/19/17 11:58 AM
10/19/17 11:58 AM
Alberta, Canada
Smokescreen Offline
Smokescreen  Offline
Alberta, Canada
My 1978 Clara natural gas furnace got the annual "vacuum out, clean the flame light, oil the motor bearings, vacuum out all the vents for at least 10 feet in" it ritual a couple of weeks back. It hasn't gotten cold here yet, but slightly after it changes to regular operations cycles, I'll complete the process with its 1st new filter. The second one will be put in around Jan 1st.
The Clara is old school with no electronics other than the digital programmable thermostat I installed 11 years ago. The whole system works great and has never had any issues. Our gas bill (hot water heater included) is about $110 per month from November to February. Simple and effective.
13 Civic Si 2.4L- 69Kkms(43Kmi)-PP,Wix
09 Corolla 1.8L-380Kkms(237Kmi)-PP,Denso
05 LeSabre 3.8L-210Kkms(134Kmi)-PP,Wix
03 Sierra 2500 6.0L-204Kkms(127Kmi)-PP,Wix
All with mpg > EPA
Re: Furnace check up [Re: Smokescreen] #4548239
10/19/17 12:13 PM
10/19/17 12:13 PM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
I hope the manifold has been inspected. That could be dangerous being that old.
Re: Furnace check up [Re: Smokescreen] #4548259
10/19/17 12:30 PM
10/19/17 12:30 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
Your natural gas supplier will generally check the heat exchanger for cracks for free. That's important on an older gas furnace. A cracked heat exchanger could be the source of carbon monoxide poisoning.
I always kept a spare thermocouple clipped to the furnace cover (so even I could find it). I ended up using it last spring when the home inspector found an unexpected problem with the furnace. The natural gas company guys will generally change it for you if it's required and you have a new part handy. One less trip for them and makes for a happy customer.
Nowadays I have a heat pump system. Not much to check - just replace or clean air filters and clean the outside unit's screen.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: Furnace check up [Re: gman2304] #4548290
10/19/17 12:56 PM
10/19/17 12:56 PM
Canada
i_hate_autofraud Offline
Canada
My first house had an oil furnace, that seemed to go thru lots of oil.
On a lark I borrowed a pyrometer from the lab and checked the flue temp
After reading a good Audel book on oil burners! She was cranking 350F+
at the flue! That sure looked like a fire risk and $$$ going straight up the chimney.
Long story short, changed to a smaller oil nozzle (3/4 US Gal/hr rate) reset the air band
for a clean flame with smaller air flow to keep gas in the heat exchanger longer,
flue temp dropped to 150F.
Cleaned soot out of the exchanger filled 4 old style paper shopping bags! The oil guy wondered
why I wasn’t order tank fulls like the past owners! It’s possible the ‘service’ side of his biz
had messed with the furnace for the ‘great’ results! No more!
Re: Furnace check up [Re: gman2304] #4548293
10/19/17 12:59 PM
10/19/17 12:59 PM
North TEXAS
oldoak2000 Offline
oldoak2000  Offline
North TEXAS
also good time to put NEW batteries in CO detector (or REPLACE if it's more than ~5 years old - YES, they wear out and become in-effective.
IF your co detector is older than 2009, TRASH and replace immediately - http://www.kidde.com/home-safety/en/us/s...ide_alarm_.aspx
Re: Furnace check up [Re: gman2304] #4548320
10/19/17 01:22 PM
10/19/17 01:22 PM
Indiana
Phishin Offline
Phishin  Offline
Indiana
I got an older Clare Megasaver furnace. High efficiency from the early 1990's.
I was told never to replace this furnace, and keep it running. I guess I need an inspection. It's been 5 years since anyone's looked at it.
2018 Chevy Silerado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: VSP 0w20/MaxLife 10w30 + LG BioTech HD
2014 CR-V LX K24: M1 0w30
Re: Furnace check up [Re: gman2304] #4548330
10/19/17 01:32 PM
10/19/17 01:32 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Get oil boilers and furnaces serviced by an independent service guy.
2015 Ford F250 w/Powerstroke
Re: Furnace check up [Re: gman2304] #4548430
10/19/17 03:32 PM
10/19/17 03:32 PM
Deep in the heart of Jersey
BigCahuna Offline
BigCahuna  Offline
Last month I replaced my 30 year old oil fired stem boiler with a new Weil -Mclain gas fired steam boiler. The old one developed a leak in the cast iron, and was leaking into the firebox. Had a company do the conversion. I still have about 60-70 gallons of oil left in the tank I can't seem to give away. The tank at least is in the basement and easy to get to. Hopefully we will save enough on the price of not paying for oil, to cover the conversion after a few seasons.,,
Re: Furnace check up [Re: Donald] #4548433
10/19/17 03:38 PM
10/19/17 03:38 PM
ecotourist Offline
ecotourist  Offline
In Alberta the gas company's service staff are very reliable, well trained, etc. I'd trust them as much as any independent service guys. If they say your furnace is unsafe (which they would if it has a CO leak) and must be replaced (which might be the case if you can't get parts), they gain nothing. At that point you'd have to go to the independents.
In any case it's important to get an old (5 years old or more) gas furnace checked for CO leaks. I always had my fingers crossed and mine always passed with flying colours. My oldest hot air gas furnace was 25 years old and my oldest hot water (originally coal, then fuel oil converted to) gas furnace was 70 years old.
2000 BMW 528i 5MT
