Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
69 registered members (69Torino, avi1777, 2015_PSD, 87sammy, 97K15004WD, ArrestMeRedZ, 6 invisible), 776 guests, and 53 spiders.
Topics286,105
Posts4,902,667
Members67,563
Most Online2,967
Mar 10th, 2019
Tire Pressure adjustment #4545523
10/16/17 08:10 PM
10/16/17 08:10 PM
Somewhere
itguy08 Offline OP
itguy08  Offline OP
Somewhere
Just got the new shoes for the truck installed today - Cooper Discoverer AT3. Quite the upgrade from the junk Hankook Dynapro HT's that were on there. However, have a question on determining the best inflation pressure, especially when towing our trailer.
The truck is a 2011 F150 Ecoboost with the Max Tow package and 1820 lbs of payload. It specifies a 114T tire @ 35 PSI.
We wow a 9900 lb GVWR travel trailer with probably 1100-1200 lbs of tongue weight (875 "from the factory") so we're near the max when we tow.
The Coopers are Load range 116T so I gained a little more capacity.
With the previous Hankooks I'd air up to 40 PSI all around as we found the ride too bouncy at 35 PSI. They had a max pressure of 51 PSI.
The Coopers' max is 44 PSI. So I'm wondering if it would be good to go to 40 or shoot straight to 44 PSI?
Thoughts?
Re: Tire Pressure adjustment [Re: itguy08] #4545541
10/16/17 08:31 PM
10/16/17 08:31 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
What's the max. weight capacity of the tire?
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Tire Pressure adjustment [Re: itguy08] #4545630
10/16/17 09:29 PM
10/16/17 09:29 PM
Somewhere
itguy08 Offline OP
itguy08  Offline OP
Somewhere
2756lbs @ 44 PSI
Re: Tire Pressure adjustment [Re: itguy08] #4545728
10/17/17 12:12 AM
10/17/17 12:12 AM
Maryland USA
rubberchicken Offline
Maryland USA
I would have to fall back and say "go with what the manufacturer specs". My 97 Suburban has 2 specs: for comfort and non-towing, use 40 in the front tires and 50 in the rear. For towing, use 50 in the front and 80 in the rear. 2500 4x4.
Re: Tire Pressure adjustment [Re: itguy08] #4545740
10/17/17 12:55 AM
10/17/17 12:55 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
Try the door placard 35 psi and see how it tows. Auto tires are not supposed to be run at the max pressure on the sidewall. Tires will heat up when towing and the hot pressure will increase. You run the tires at 44 max and they will exceed the max when towing. Stay safe.
Re: Tire Pressure adjustment [Re: FZ1] #4545777
10/17/17 04:15 AM
10/17/17 04:15 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I think "A tire's maximum inflation pressure is the highest "cold" inflation pressure that the tire is designed to contain", so this seems to be irrelevant. If they are designed to take that pressure cold, they'll take the corresponding hot pressure too. May not be optimal for the particular vehicle and service though.
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=196
Re: Tire Pressure adjustment [Re: itguy08] #4545830
10/17/17 06:08 AM
10/17/17 06:08 AM
Somewhere
itguy08 Offline OP
itguy08  Offline OP
Somewhere
Problem is Ford just specifies 1 pressure. With the previous tires it was a little bouncy when hooking up the trailer. Adding some extra air not only made the tires look better but seemed to lessen the bounciness. Seems that with a large load you'd want to air them up a little bit to restore some of the shape to the tire.
I'm picking up the trailer today and they're at 35 so we'll see how it goes and up to 40 if need be.
Re: Tire Pressure adjustment [Re: itguy08] #4545848
10/17/17 06:41 AM
10/17/17 06:41 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
On my F150 the rated psi on the tires is also 44; I run 42 front and 40 rear unloaded; for towing, the rear goes to 44.
Nice, even wear all around and no stability issues towing ~6000# trailer.
Tires are Michelin LTX 2.
Thick vs Thin test: 15k / 43k miles complete
Re: Tire Pressure adjustment [Re: itguy08] #4545915
10/17/17 08:13 AM
10/17/17 08:13 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
itguy08,
Is the tire you referred to of standard load rating or extra-load rating ?
Re: Tire Pressure adjustment [Re: zeng] #4546102
10/17/17 10:50 AM
10/17/17 10:50 AM
Somewhere
itguy08 Offline OP
itguy08  Offline OP
Somewhere
Originally Posted By: zeng
itguy08,
Standard 116T load rating.
Re: Tire Pressure adjustment [Re: itguy08] #4546176
10/17/17 11:55 AM
10/17/17 11:55 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
itguy08,
116T tire at 32 psi carries equivalent load as 114T tire at 35 psi.
At 32 psi, you could travel upto 62 mph at designed vehicle load.
At 40 psi, you could travel upto 74 mph .
If you wish, you could go for max 44 psi with no further advantage as you are still limited to the same max load at 74 mph max.
Re: Tire Pressure adjustment [Re: zeng] #4546344
10/17/17 03:12 PM
10/17/17 03:12 PM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
itguy08,
Whoa, whoa, whoa!! You have to be very careful here.
First, do we know what the tire size is? (OK, I did some research and the only 2011 Ford F150's that have a 114T Service Description come with P275/65R18's.)
So I looked up the Cooper Discoverer A/T3 - and the tire is a 275/65R18 116T - NO P !! That means it is either a Eurometric or .... ah ..... Let's call it a Japanese metric.
Looking up a Eurometric 275/65R18 IN ETRTO, I find it has a Load Index of 116 - and the rated pressure on that tire is 250 kPa ~ 36 psi. At 240 kPa (~ 35 psi), the load carrying capacity is 1210 kg ~ 2668#.
Oh, and a P275/65R18 114T has a load carrying capacity of 2601# at 35 psi. (I don't know how the other value was obtained, but it is wrong.)
Those 2 values are very close and with rounding, they could be considered the same.
So use 35 psi just like the placard says.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Tire Pressure adjustment [Re: itguy08] #4546617
10/17/17 08:06 PM
10/17/17 08:06 PM
Somewhere
itguy08 Offline OP
itguy08  Offline OP
Somewhere
Thanks for the tips. Yes, it's the 275/65R18 116T.
I towed the camper home tonight and it did good @ 35PSI. Seemed to handle the highway and getting passed by semis just fine. But the ride did feel a little bouncy. And when I got home the tires looked like they were carrying a good load.
Still thinking of bumping to 40 for the trip - would it necessarily hurt anything?
Re: Tire Pressure adjustment [Re: itguy08] #4546692
10/17/17 09:41 PM
10/17/17 09:41 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Whoa, whoa, whoa!!
Each OEM spec'ed P275/65R18 114T at 35 psi carries 2513 lbs (1140 kg) load.
This is the load requirement per tire from vehicle OEM (Ford).
Now, Cooper Discoverer AT3 275/65R18 116T with a similar load of 2513 lbs (1140 kg) load requires only 32.26 psi tire pressure , rounding off to 32 psi., and not 35 psi....... at OEM designed load per tire .Not that one cannot exceed 32 psi on an AT3.
Hence my statement quoted above, after rounding off!
This AT3 275/65R18 116T at a tire pressure of 35 psi would each carry a load of 2667 lbs (1210 kg) i.e 154 lbs more than OEM designed load 2513 lbs per tire .
This AT3 has a maximum load of 2756 lbs (1250 kg) per tire , btw.
Note: 1 kg = 2.2046 lbs.
Yes, bump up to 40 psi.
No, it won't hurt anything ..... other than a 'harsher' ride whilst gaining better FE.
Re: Tire Pressure adjustment [Re: itguy08] #4546745
10/17/17 11:45 PM
10/17/17 11:45 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Oops, 160 km/hr = 100 mph, not 62 mph (100 km/hr) .Hence 62 mph in previous post #4546176 should read 100 mph.
190 km/hr = 119 mph, not 74 mph (62mph/160 kmh x 190 kmh).Hence 74 mph in previous post #4546176 should read 119 mph.
Apologies for wrong conversion from metric > imperial.
