And They Say Spelling is Not Important.
by PimTac. 09/22/18 12:06 PM
Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
by gordond. 09/22/18 08:37 AM
Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
52 registered members (BAJA_05, 4WD, Anduril, 53' Stude, BrianF, BigCahuna, 3 invisible), 1,894 guests, and 32 spiders.
Topics290,821
Posts4,851,009
Members66,040
Most Online3,590
Jan 24th, 2017
Mixing Oils #4542301
10/13/17 03:32 PM
10/13/17 03:32 PM
Arizona
Ruby2013Elantra Offline OP
Arizona
Long story short, bought a case of Schaeffer 0W-20 oil that I don't really want to use anymore and I've already used 4 quarts of it, so can't return it. I want to start using a dexos1 gen 2 oil in my CR-V, protect against LSPI. It takes 3.7 quarts per change, and was wondering if I could use 3 quarts of a dexos oil and then put 0.7 quarts of Schaeffer to top it off and finish off the case. That cool?
V
2006 F150 "Pearl"
2017 CR-V "The Ron"
2013 Elantra "Ruby" - RIP
Re: Mixing Oils [Re: Ruby2013Elantra] #4542318
10/13/17 03:59 PM
10/13/17 03:59 PM
North Carolina
6starprez Offline
6starprez  Offline
North Carolina
It's cool like that.
Only 3.7 quarts? Does it have a 1.5T?
'12 Impreza Sport Limited 157K - Moil 1 EP 0W20
Re: Mixing Oils [Re: Ruby2013Elantra] #4542324
10/13/17 04:02 PM
10/13/17 04:02 PM
Arizona
Arizona
Yup, one of those newish turbo engines. Was hesitant in getting the turbo due to LSPI, but the CR-V for the family is pretty sweet. Probably upgrade before we even see any issues, but till then I want a dexos1 gen2 oil in it.
2006 F150 "Pearl"
2017 CR-V "The Ron"
Re: Mixing Oils [Re: Ruby2013Elantra] #4542334
10/13/17 04:10 PM
10/13/17 04:10 PM
TX
parshisa Offline
parshisa  Offline
TX
Thy are all mixable, no problem at all. I have the same engine but in Civic and running no -LSPI oil - no issues at all. Although planning to go higher on the grade to offset fuel dilution and make it sound better. So far my leaning towards new Amsoil formulation 5w30
2016 Honda Pilot 3.5V6 PP 0W20
2017 Honda Civic 1.5T Amsoil SS 5W30
Re: Mixing Oils [Re: Ruby2013Elantra] #4542345
10/13/17 04:18 PM
10/13/17 04:18 PM
Arizona
Arizona
I've thought about that too, but then I worry about deviating from what Honda recommends. I'm always a stick to the rules kind of guy.
2006 F150 "Pearl"
2017 CR-V "The Ron"
Re: Mixing Oils [Re: Ruby2013Elantra] #4542350
10/13/17 04:23 PM
10/13/17 04:23 PM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
You need to do the special ritual and prayer to the oil gods before mixing them. Then send BITOG a donation. That's how it works. LOL
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Mixing Oils [Re: Ruby2013Elantra] #4542360
10/13/17 04:29 PM
10/13/17 04:29 PM
Arizona
Arizona
Haha, I'll get right on that.
2006 F150 "Pearl"
2017 CR-V "The Ron"
Re: Mixing Oils [Re: Ruby2013Elantra] #4542391
10/13/17 04:56 PM
10/13/17 04:56 PM
Chicago, IL
dparm Offline
dparm  Offline
Chicago, IL
It is a requirement of API oils that they mix with other API oils, so yes, you are fine.
2017 Chevrolet Corvette Grand Sport
Re: Mixing Oils [Re: dparm] #4542446
10/13/17 05:59 PM
10/13/17 05:59 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Yes, it's a requirement that they can be mixed without blowing chunks or splitting like salad dressing...after that, all bets are off.
Re: Mixing Oils [Re: Shannow] #4542453
10/13/17 06:04 PM
10/13/17 06:04 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
thumbsup
Most any engine oil will mix with any another engine oil.
After mixing, additive compatibility may be an issue with some oils.
Reading is fundamental; understanding is not a given ability.
Re: Mixing Oils [Re: Ruby2013Elantra] #4542589
10/13/17 08:27 PM
10/13/17 08:27 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
As long as they don't blow chunks, I'm good laugh
Re: Mixing Oils [Re: Ruby2013Elantra] #4542802
10/14/17 01:21 AM
10/14/17 01:21 AM
NC
Vladiator Offline
Vladiator  Offline
NC
I just witnessed how 33 different oils (syn, semi syn, mineral) in different viscosities (from 0w20 to 10w60) got all mixed in to a 8qt sump on a supercharged Land Rover. UOA is coming after 3k miles. I'll post it here once I have access to it. Mixing oils WILL NOT kill your engine. It will just create an oil that is adequate enough for a 5k mile run. Extended OCI is where you would start seeing issues though.
2000 Lexus GS300-361k
1999 Lexus GS400-213k
2006 Toyota Camry-187k
2006 Toyota Highlander Hybrid-125k
2009 Scion xB-120k
2013 VW Tiguan-120k
2009 Toyota Tacoma-60k
Re: Mixing Oils [Re: Vladiator] #4542843
10/14/17 05:05 AM
10/14/17 05:05 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
And what would that mix have done at -30 to -40 degrees ?
And As I've demonstrated before through SAE papers, sometimes, not very often, but sometimes, really bad things happen due to the interactions of PPDs and VIIs...oh, and it killed the engines.
Re: Mixing Oils [Re: Ruby2013Elantra] #4542860
10/14/17 06:14 AM
10/14/17 06:14 AM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Don't mix. Topping off with a random quart is one thing. Dumping all your leftover half bottles into the crankcase for a short oci is probably fine and I understand the reasoning there. Thinking you can outdo professional engineers in designing a lube package by mixing finished oils is arrogant and ignorant. You don't know what you are ending up with in your mix.
There are many excellent oils on the shelf with certifications that prove they perform to those standards. Pick one that suits your application and use it.
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: Mixing Oils [Re: Ruby2013Elantra] #4542984
10/14/17 09:05 AM
10/14/17 09:05 AM
OH
fdcg27 Offline
fdcg27  Offline
OH
You're making the assumption that a dexos licensed oil would offer better resistance to LSPI than would the Schaeffer's.
Schaeffer's makes good oil, so this assumption may not be warranted.
If your assumption is correct, then why would you want to contaminate the dexos oil with one more prone to LSPI?
I'd personally use the Schaeffer's, but if you really don't want to then sell it.
If I lived anywhere near you, I'd consider buying it from you since I have two 0W-20 engines ATM and neither is DI or turbo.
17 Forester 12K MSS 0W-20
12 Accord LX 92K PP 5W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
