Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
109 registered members (53' Stude, 4WD, 2015_PSD, AmoryBlaine, Arctic388, 16 invisible), 1,834 guests, and 38 spiders.
Topics296,966
Posts4,962,564
Members67,009
Most Online2,821
Yesterday at 01:32 PM
Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) #4540729
10/11/17 08:54 PM
10/11/17 08:54 PM
West Michigan
Bvanderhaar Offline OP
West Michigan
1. 2011 GMC Terrain 3.0L V6 LFW build date 8/13/2010, currently has 84K miles.
2. Owners manual says dexos only, but indicates if dexos is unavailable to use oil with "API Starburst symbol and of SAE 5W-30". Owners Manual.
3. Michigan lower peninsula, gets cold (0 degrees F, sometimes negative).
4. Easy and slow mostly, since it's the wife's car; when I take it about once a month and it's warmed up, I drive it harder/faster to increase oil pressure, etc.
5. Short trip to work (less than 10 mins); we do take it on 300-500 mile road trips once or twice a year
6. No known mechanical problems, always had dealer serviced oil changes according to the OLM.
I found some early blackstone analysis on the forum:
Oil Analysis 1
Oil Analysis 2
My concerns are around this being an early DI engine, the mostly short trips and temperature fluctuation/cold winter we have in Michigan. I believe the engine/powertrain warranty has expired (I'm not concerned about dexos) and I've heard good things on this forum about 0w40 from Castrol and M1. But the M1 site recommends 5W-30's.
I already buy Catrol 0w40 (LL-01) from walmart for the BMW, but I only change that oil every 15-16K, so having another oil for these short OCI's isn't a huge deal. I've heard the ZDDP content of the Castrol is good for the BMW, but may not be beneficial for this engine. I'd prefer to go full synthetic, but I'm open to any suggestions (and especially experience of those who have same/similar engine), thanks!
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: Bvanderhaar] #4540763
10/11/17 09:52 PM
10/11/17 09:52 PM
MN
oil_film_movies Offline
MN
If you don't burn much oil, say less than a quart per 4,000 miles or so, then the ZDDP content in the 0w40 would not be a problem, since its the phosphorus in ZDDP (the 'P' part) that can foul catalytic convertors if it gets into the combustion chamber too much. You could use any 0w40. I'd use Mobil1 AFE 0w30 in that engine, as it has some Mg detergents replacing some Ca detergents which may keep it from LSPI. I had experienced LSPI in a 2011 Chevy 3.6L DI engine, similar to your engine, as its compression ratio and DI, coupled with the engine mapping and transmission shift points, caused some occasional light LSPI.
Use a Fram Ultra XG10575 oil filter from walmart or amazon.com for best filtering.
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: Bvanderhaar] #4540792
10/11/17 10:24 PM
10/11/17 10:24 PM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
I have one as well, 2011 V-6.
Central Wisconsin.
5W-30 works fine. I've tried 0W-30 a time or two and
saw no real benefit.
Of late, I'm using Valvoline synthetic.
Seems slightly thinner than other brands.
My 2
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: Bvanderhaar] #4540819
10/12/17 12:15 AM
10/12/17 12:15 AM
Pennsylvania
K23Turbo Offline
K23Turbo  Offline
Pennsylvania
Googling dexos 5W30 produced all the usual suspects. The big main major players. Id go Castrol Magnatec in 5W30 due to low price.
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: Bvanderhaar] #4540941
10/12/17 06:47 AM
10/12/17 06:47 AM
Michigan
64bawagon Offline
64bawagon  Offline
Michigan
I buy whats on sale or has a rebate, as cheap as full syn is (and almost all are at least Dexos 1) I cant see using anything else. I would stick with the 5W30 or 0W30 if available. I changed the oil in my equinox (4 cyl) for less than $15 using Mobil super syn I got at A.Z. and a AC filter I found priced incorrectly.
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: oil_film_movies] #4540959
10/12/17 07:01 AM
10/12/17 07:01 AM
West Michigan
West Michigan
Thanks for the detailed response - looks like M1 AFE 0w30 is available at my local walmart. Sounds like LSPI is low speed knocking...not sure I've experienced it, but I don't drive the car often.
I actually ordered the XG10575 right before posting based on my reading in the filter forum and was going to ask that question. Thanks for providing that info as well.
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: Bvanderhaar] #4540968
10/12/17 07:20 AM
10/12/17 07:20 AM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
I think the M1 0W-30 would be good, also.
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: Bvanderhaar] #4540969
10/12/17 07:20 AM
10/12/17 07:20 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
I would personally try PP or PUP and a Fram Ultra filter. Change it according to the OLM or yearly
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: Bvanderhaar] #4541065
10/12/17 09:15 AM
10/12/17 09:15 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I don't have a fave oil, its whatever that engine seems to like. I put PP and Edge in my my sisters 2010 eqx because the UOA's on here suggest PP and Edge have lowest/least wear metals in samples for that engine. But she complained the engine was vibrating, getting sluggish half way through an OCI. So I moved on to M1 5w30 which is what my 06 6.0L likes. She said it felt peppier, smoother throughout the OCI (in her opinion). So thats what it gets. I suppose another engine could be different, but both GM engines I come in contact with seem smoother on M1.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: LeakySeals] #4541229
10/12/17 12:54 PM
10/12/17 12:54 PM
West Michigan
West Michigan
Looks like 'regular' M1 5w30 is dexos1 gen2 certified, while 0w30 AFE is dexos1 gen1. They both are available and the same price in my area. Probably doesn't matter, but dexos gen2 seems to help with LSPI - http://www.centerforqa.com/dexos-brand2015/.
I tried to find calcium comparison numbers from oil analysis on the board, but haven't found a 'regular' M1 5w30 sample that has the dexos1 gen2 formula.
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: Bvanderhaar] #4541289
10/12/17 02:24 PM
10/12/17 02:24 PM
West Michigan
West Michigan
OK, I did find some:
M1 0w20 AFE, 4.6K use - Ca 1245, Mg 609 - Link
M1 0w20 AFE, 10K use - Ca 1094, Mg 757 - Link
M1 5w30, 7K use - Ca 1025, Mg 544 - Link
M1 5w30, 10K use - Ca 924, Mg 639 - Link
Looks about the same. Maybe slightly more Ca and Mg in AFE. I will probably go with regular M1 5w30 since the formula seems more updated due to dexos1 gen2; unless there are other numbers I should be looking at for this particular engine.
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: Bvanderhaar] #4541496
10/12/17 06:22 PM
10/12/17 06:22 PM
bigj_16 Offline
bigj_16  Offline
The AFE 0W-30 might be a little better in the cold. The calcium levels are essentially the same. Within the range of the spec. The 0W-30 probably won't show the Gen.2 rating unless GM uses that particular grade.
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: Bvanderhaar] #4541744
10/12/17 10:38 PM
10/12/17 10:38 PM
Western usa
Ammofirst Offline
Ammofirst  Offline
Western usa
I would definitely run Dexos 1 gen 2 full synthetic and not exceed 5000 miles for your oil change interval.
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: bigj_16] #4541955
10/13/17 07:28 AM
10/13/17 07:28 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Regarding M1 brands, there are a few posts on here that show M1 5w30 is actually thinner thinner than M1 0w30 AFE in cold weather. Until you get to -20,-30F where the 0w30 AFE is thinner again. So the 0 does not necessarily mean thinnest depending on viscosity (0w30,0w40), depending on temps, depending on brand.
Re: Oil for Equinox/Terrain 3.0L V6 LFW (updated LF1) [Re: LeakySeals] #4541992
10/13/17 08:31 AM
10/13/17 08:31 AM
bigj_16 Offline
bigj_16  Offline
The -20 to -30 range was what I was specifically referring to. smile
