Employer Exit Interview.
by JustinH
9 minutes 51 seconds ago
Ceratec vs. Archoil 9100
by Phishin
13 minutes 27 seconds ago
Acclaim radiator ?
by urrlord
15 minutes 41 seconds ago
Understanding Idle Control Circuit
by artbuc
Today at 07:59 AM
Annual drain on Mobil1 5w20 high mileage?
by ryan2022
Today at 07:36 AM
Best Oil For Late Model Toyota V6 Engines ?
by ChrisD46
Today at 06:58 AM
Ford 4.6L Durability?
by Auae85
Yesterday at 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
Yesterday at 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
Yesterday at 10:01 PM
Fireworks Stores
by Warstud
Yesterday at 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
Yesterday at 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
Yesterday at 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
Yesterday at 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
Yesterday at 08:49 PM
My FIL in hospice
by fdcg27
Yesterday at 08:41 PM
Spraying Polyurethane
by Texican
Yesterday at 08:37 PM
Dehumidifier icing
by Kestas
Diesel lube in Petrol Engine
by Ducked
Yesterday at 07:46 PM
New key programming cost
by 92saturnsl2
Yesterday at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Yesterday at 07:09 PM
ronw1309, Suth31, yamahaboy125, Turboholic, TrpNY
65284 Registered Users
87 registered (Alex_V, 2004tdigls, ARCOgraphite, andyd, A310, ArrestMeRedZ, 10 invisible), 1381 Guests and 38 Spiders online.
65284 Members
67 Forums
285691 Topics
Page 1 of 2 1 2 >
#4539116 - 10/10/17 01:22 PM New Brake Discs Thickness issue
slybunda Offline
Loc: UK
hey all i forgot to take a photo but will get one up tomorrow. the new brake discs i received (vented ones) have a thicker plate on one side and thinner on the other. is this normal or a manufacturing issue? its the same on both of the discs in the box.
iv seen this on some pagid discs for the aygo and its now happened with the fremax discs i bought for the ford fiesta.
how can this happen from 2 different brands of discs for different cars?
i thought with brake discs the plates should be even thickness on each side?
1995 Ford Fiesta 1.6i 16v Si
2000 Toyota Celica 1.8 VVTL-i
2007 Toyota Aygo+ 1.0i
#4539119 - 10/10/17 01:28 PM Re: New Brake Discs Thickness issue [Re: slybunda]
The Critic Offline
Loc: CA
This is normal- some applications will have one side that is thicker than the other.
2011 Toyota Prius - 168k - ServicePro Dexos 0W-20
2007 Honda Accord 2.4 - 128K - Idemitsu 5W-20
#4539175 - 10/10/17 02:24 PM Re: New Brake Discs Thickness issue [Re: slybunda]
Kamele0N Online   sick
Loc: Slovenia
Never seen discs like that.... They must be even on both sides...
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4539180 - 10/10/17 02:30 PM Re: New Brake Discs Thickness issue [Re: The Critic]
slybunda Offline
Loc: UK
Thats odd would it cause vibration or other issues?
#4539227 - 10/10/17 03:14 PM Re: New Brake Discs Thickness issue [Re: slybunda]
Char Baby Offline
Loc: ROCHESTER, NY
I have rotors like that. I believe(I'd have to look) the inside(piston side) is thicker than the outside.
"Retired"
'06 Mazda 3i 2.0L
'15 Nissan Altima 2.5 SV
#4539240 - 10/10/17 03:27 PM Re: New Brake Discs Thickness issue [Re: slybunda]
slybunda Offline
Loc: UK
I just checked and yes the caliper piston side is thicker. Very odd
#4539246 - 10/10/17 03:32 PM Re: New Brake Discs Thickness issue [Re: slybunda]
Dave9 Offline
Loc: Cincinnati, USA
Check your old rotors. If they wore evenly on both sides then unequal thickness replacements will have a shorter service live. If they wore more on the piston side then that would suggest the new ones are Just Right for the application.
#4539260 - 10/10/17 03:41 PM Re: New Brake Discs Thickness issue [Re: slybunda]
LeakySeals Offline
Loc: Hudson, NH
pics?
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
#4539334 - 10/10/17 04:29 PM Re: New Brake Discs Thickness issue [Re: slybunda]
PandaBear Offline
Loc: Silicon Valley
It actually make sense as the piston side is more likely to wear out faster, especially if they use different material between inside (more bite) and outside (low dust).
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#4539763 - 10/11/17 02:51 AM Re: New Brake Discs Thickness issue [Re: slybunda]
slybunda Offline
Loc: UK
iv attached some pics. overall disc thickness iv measured with the vernier caliper is 20mm at different points so it is in spec for overall thickness. however one plate is around 7.4mm thick and the other plate is around 6.5mm thick.
the plate thats caliper piston side is the thicker one.
#4541040 - 10/12/17 09:36 AM Re: New Brake Discs Thickness issue [Re: slybunda]
WyrTwister Offline
Loc: Texas
Never seen that either .
Are you saying one side of the rotor is thicker than the other ?
Wyr
God bless
Wyr
God bless
#4541060 - 10/12/17 10:05 AM Re: New Brake Discs Thickness issue [Re: slybunda]
UG_Passat Offline
Loc: NJ
Considering that most cars uses 1-piston calipers, being thicker on the piston side makes sense, provided that the rotors are balanced properly at the factory
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
#4541403 - 10/12/17 05:31 PM Re: New Brake Discs Thickness issue [Re: WyrTwister]
slybunda Offline
Loc: UK
Wyr
God bless
yes one side is thicker
#4541417 - 10/12/17 05:57 PM Re: New Brake Discs Thickness issue [Re: slybunda]
WyrTwister Offline
Loc: Texas
Wondering it was intended to be that way or if the center line of the casting is off ?
That way on both sides of the car ?
Best wishes , :-)
Wyr
God bless
#4541784 - 10/13/17 01:46 AM Re: New Brake Discs Thickness issue [Re: WyrTwister]
user52165 Offline
Loc: CA
All you guys saying you never saw this either:
Have not seen many different model discs, or
Saw it but didn't pay attention and did not notice. Not a huge difference but always measureable.
Very common and also very common that pads do not wear evenly inner vs outer.
Page 1 of 2 1 2 >
