ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
O2 sensor B1S1 no voltage??
by David1. 12/18/18 03:43 PM
Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
110 registered members (97prizm, A310, Al, 28oz, AdditiveOCD, 11 invisible), 2,141 guests, and 42 spiders.
Topics295,226
Posts4,930,484
Members66,716
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
SUV Starting To Use Oil #4537341
10/08/17 04:11 PM
10/08/17 04:11 PM
N.C.
RHALL Offline OP
RHALL  Offline OP
N.C.
My wifeís 2004 Trailblazer is starting to use around a quart of oil between changes. Itís got 200,000 miles on its 4.2 liter I-6, so I guess itís been a good one.
What Iím considering is using heavier weight oil than the 5w 30 itís always used, and would like some advice on what to use. Iíve thought about 10w 30 or 10w 40 to slow down the oil use. What do yíall think?
"Stupid Is As Stupid Does"- Forrest Gump
Re: SUV Starting To Use Oil [Re: RHALL] #4537346
10/08/17 04:13 PM
10/08/17 04:13 PM
ME
eljefino Online content
eljefino  Online Content
ME
ok
Re: SUV Starting To Use Oil [Re: RHALL] #4537359
10/08/17 04:27 PM
10/08/17 04:27 PM
California
Kool1 Offline
Kool1  Offline
California
I believe carbon buildup around the top of the pistons and ring lands causes ring seating problems with higher mileage engines. You may want to try some Seafoam in your intake to clean out your combustion chambers to free up stuck rings (if they are stuck) before you up the oil viscosity.
Re: SUV Starting To Use Oil [Re: RHALL] #4537360
10/08/17 04:27 PM
10/08/17 04:27 PM
Michigan
Oil_Flunky Offline
Oil_Flunky  Offline
Michigan
Try a bottle of Rislone concentrate in it.
Oil, you need it. Oil snobbery, you don't need it.
Re: SUV Starting To Use Oil [Re: RHALL] #4537370
10/08/17 04:44 PM
10/08/17 04:44 PM
Maryland
chemman Offline
chemman  Offline
Maryland
What is your oil change interval?
92 Olds 88 Hav 5w30 PL/L24011
99 Buick Century Hav 5w30 PL/L24011
99 Silverado 5.3L Hav 5w30 PL/L25288
04 TrailBlazer 4.2L Hav 5w30 PL/L25288
Re: SUV Starting To Use Oil [Re: RHALL] #4537378
10/08/17 04:59 PM
10/08/17 04:59 PM
PimTac Offline
PimTac  Offline
This just started? Check for leaks.
Cannot see signatures any longer so it doesn’t matter.
Re: SUV Starting To Use Oil [Re: RHALL] #4537392
10/08/17 05:16 PM
10/08/17 05:16 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
Clean out the throttle body, intake, and PCV lines with some carb cleaner. After that I would use a high mileage 10w30. I am surprised you have not used more oil sooner. Those larger inline GM motors seemed to use a little oil not to long after new.
yup
Re: SUV Starting To Use Oil [Re: RHALL] #4537396
10/08/17 05:29 PM
10/08/17 05:29 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Try some Castrol Magnatec Blend 10w30 and Liqui Moly anti-friction engine treatment.
Re: SUV Starting To Use Oil [Re: RHALL] #4537397
10/08/17 05:29 PM
10/08/17 05:29 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
Addressing ring issues has greatly helped consumption in an suv I have. I soaked the rings with MMO.
I use M1 10w-30 HM and that Helps a lot too. Until the end of the month, it is on a $10 a jug rebate. That makes it under $13 for 5 quarts at Walmart. Give that a try.
Re: SUV Starting To Use Oil [Re: RHALL] #4537405
10/08/17 05:43 PM
10/08/17 05:43 PM
Texas
FZ1 Offline
FZ1  Offline
Texas
The quart usage is not going to hurt it. First try a thicker 5w-30 or a 5w-30 high mileage oil before going up a grade.
Re: SUV Starting To Use Oil [Re: RHALL] #4537413
10/08/17 05:51 PM
10/08/17 05:51 PM
NY
demarpaint Offline
demarpaint  Offline
NY
If there aren't any leaks, I'd replace the PCV valve and see if that helps. Then maybe give Kreen, MMO, or Rislone a shot.
God Bless Our Troops
Re: SUV Starting To Use Oil [Re: PimTac] #4537416
10/08/17 05:53 PM
10/08/17 05:53 PM
VA
Gebo Offline
Gebo  Offline
VA
+1
Are you a maintenance freak or a regular guy?
On my GS300 and my 4Runner they both had leaks and that was the culprit.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: SUV Starting To Use Oil [Re: chemman] #4537423
10/08/17 06:01 PM
10/08/17 06:01 PM
N.C.
RHALL Offline OP
RHALL  Offline OP
N.C.
5000 Miles, Iíve always used synthetic oil and a quality filter.
Re: SUV Starting To Use Oil [Re: RHALL] #4537427
10/08/17 06:05 PM
10/08/17 06:05 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Put some flexseal in there. It will stop the leak. LOL!
Re: SUV Starting To Use Oil [Re: RHALL] #4537430
10/08/17 06:06 PM
10/08/17 06:06 PM
Minnesota
bmod305 Offline
bmod305  Offline
Minnesota
200k on the clock and using 1 quart every 5k. What are you worried about? Keep using whatever you have been using.
Just my two cents,
Dave
Page 1 of 3 1 2 3
