Originally Posted By: RHALL
I use Seafoam I’m my gas every couple months. How do you put it in the intake?
Find a vacuum hose or port that leads into the intake manifold - just preferably not the PCV hose. With the engine running and (assuming it's an electronic throttle body, not cable-actuated to where you can do this under the hood) take one of those vacuum lines, with an extra length of small hose if necessary, and put it in the bottle or another small container of Seafoam while an assistant revs the engine a bit to keep it from dying. If you've ever used carb. cleaner in a carbureted engine, the effect will be similar - more combustible substance than necessary will try to flood out the engine and moderate use of throttle to bolster RPM's will be necessary. I'd run about half the 16 oz. can through it this way, giving the engine a minute to breath and stabilize between doses of an ounce or two. Do this outside as there will be a lot of white smoke come out, which is normal and may persist for a minute after you stop feeding the Seafoam.
At least, that's my technique and I've yet to blow one up doing it that way.
