Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
by gordond. 09/22/18 08:37 AM
Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
72 registered members (A310, beanoil, aquariuscsm, 2015_PSD, BeerCan, 11 invisible), 1,828 guests, and 52 spiders.
Topics290,821
Posts4,850,952
Members66,040
Most Online3,590
Jan 24th, 2017
Multimeter Alligator Clips ? #4535851
10/06/17 11:18 PM
10/06/17 11:18 PM
Clovis, CA
Merkava_4 Offline OP
Clovis, CA
I watched a YouTube video that told me how to check for a parasitic battery drain. All I have to do is unhook the Negative battery cable from the battery and hook my Ampmeter in series with the Negative battery cable. I do this by hooking the Positive multimeter lead to the Negative battery cable and then hook the Negative multimeter lead to the Negative battery post. But what I need is a hands-free way to attach the multimeter leads and have them stay hooked up while I pull the fuses one at a time. Right now all I have are the two leads with the sharp points.
Will these work ?
Re: Multimeter Alligator Clips ? [Re: Merkava_4] #4535858
10/06/17 11:53 PM
10/06/17 11:53 PM
San Diego, California
Jim_Truett Offline
Jim_Truett  Offline
Will these work ?
Yes, if your test leads have male banana plugs at each end. If not, you will need a set of leads to go with them.
2008 F250 6.4 PowerStroke 43k
2005 Honda CR-V 193k
2005 Honda Pilot 235k
1963 Nova SS 84k
2015 Civic Si 23k
2013 Mahindra 3016HST 99hrs
Re: Multimeter Alligator Clips ? [Re: Merkava_4] #4535862
10/07/17 12:07 AM
10/07/17 12:07 AM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
You can get alligator clips designed to slip onto the multi-meter leads. Mine came with them.
Here: https://www.amazon.com/Push-Alligator-Cl...+for+multimeter
Not sure if those $25 Fluke clips you pictured are the slip-on type. Pricey though, Fluke is good stuff.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Multimeter Alligator Clips ? [Re: AZjeff] #4535874
10/07/17 01:11 AM
10/07/17 01:11 AM
Clovis, CA
Clovis, CA
I'd have to get the separate TL224 leads that plug into them.
My other option is the AC175 alligator clips that screw onto my TL75 leads, but they have smaller jaws.
Re: Multimeter Alligator Clips ? [Re: Merkava_4] #4535884
10/07/17 02:01 AM
10/07/17 02:01 AM
Texas
Neely97 Offline
Neely97  Offline
Texas
Be careful not to smoke your meter.
6.7 cummins, Toyota 4 runner
FUMOTO
Re: Multimeter Alligator Clips ? [Re: Neely97] #4535898
10/07/17 04:26 AM
10/07/17 04:26 AM
wv
krismoriah72 Offline
wv
i made my own before with Butt Connectors on the leads of the multimeter and a cheap set of alligator clips from napa or harbor freight. Just slip the butt connector on the lead and crimp on the bare wire end of the alligator clip and you have a $3 set of clips.
Re: Multimeter Alligator Clips ? [Re: Merkava_4] #4536029
10/07/17 08:59 AM
10/07/17 08:59 AM
Northern Arizona
funflyer Offline
funflyer  Offline
Northern Arizona
If you have a set of jumper cables you can clip the multimeter leads using them and not need additional alligator clips.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Multimeter Alligator Clips ? [Re: Merkava_4] #4536046
10/07/17 09:25 AM
10/07/17 09:25 AM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
So you have a Fluke multi-meter? Go figure. We have Fluke meters in the QC lab that get certified calibration. Haven't found anything my $30 Craftsman meter won't do adequately around the house (with my limited electrical abilities).
Re: Multimeter Alligator Clips ? [Re: Merkava_4] #4536047
10/07/17 09:26 AM
10/07/17 09:26 AM
Great Lakes
Quattro Pete Offline
Great Lakes
Those clips should work. I got similar ones on ebay. Another option would be to get a DC clamp meter. They are about $30-$40.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (FF)
Re: Multimeter Alligator Clips ? [Re: Merkava_4] #4536098
10/07/17 10:27 AM
10/07/17 10:27 AM
MI
doitmyself Offline
doitmyself  Offline
MI
For jobs that I am only going to do once in blue moon, I usually cobble something together. You could gently squeeze your meter leads to the battery connections with vise grips or go out and spend $4 on a pair squeeze clamps to hold things together.
Re: Multimeter Alligator Clips ? [Re: AZjeff] #4536120
10/07/17 10:59 AM
10/07/17 10:59 AM
Clovis, CA
Clovis, CA
Yes, but I was only using it because my Harbor Freight meter had one it its leads pull out of the probe. I was trying to figure out how to reattach the bare wire on the end of the lead back into the probe, but it looks like the probe doesn't come apart to allow for reattaching the bare wire.
Re: Multimeter Alligator Clips ? [Re: AZjeff] #4536144
10/07/17 11:32 AM
10/07/17 11:32 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Pomona is owned by Fluke and are equivalent quality at a lower price.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Multimeter Alligator Clips ? [Re: Johnny2Bad] #4536431
10/07/17 06:49 PM
10/07/17 06:49 PM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
Never heard of them and thanks for the heads up.
Re: Multimeter Alligator Clips ? [Re: Neely97] #4536997
10/08/17 10:35 AM
10/08/17 10:35 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
There should be a 10A fuse on the circuit he is using, but you're absolutely right... Id want to verify loads via clamp on first to determine if there are inrushes, and if so, parallel another jumper.
Re: Multimeter Alligator Clips ? [Re: JHZR2] #4537036
10/08/17 11:27 AM
10/08/17 11:27 AM
Texas
Neely97 Offline
Neely97  Offline
Texas
By disconnecting grnd from vehicle, and replacing said wire with a meter, the odds of something going poof are very high, imho.
The readings will be “all over the place”, as things seek out the ground.
Hope you find the phantom, best of luck, and be carefull, dc voltage can be oh so unforgiving.
FUMOTO
