1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
30 registered members (billt460, citationxeleven, anndel, c502cid, Ag76, 3 invisible), 952 guests, and 31 spiders.
Topics296,903
Posts4,961,304
Members66,997
Most Online2,688
Jan 19th, 2019
308 to punch paper off hand #4535489
10/06/17 02:06 PM
10/06/17 02:06 PM
Michigan
stockrex Offline OP
stockrex  Offline OP
Michigan
I bought a PSA AR10, I want some plinking ammo to shoot off hand at 100
Wolf? fmj? soft core?
I am fine with steel, don't like picking up cases at range, the leaves make it hard to find anything.
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: 308 to punch paper off hand [Re: stockrex] #4535520
10/06/17 02:36 PM
10/06/17 02:36 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
If you don't like to pick up cases, wolf and their steel cases are excellent solution. Just bring a magnet.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 104K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 37k Idemitsu 0w20, 57047
Re: 308 to punch paper off hand [Re: stockrex] #4535523
10/06/17 02:37 PM
10/06/17 02:37 PM
Glendale, Arizona
billt460 Online content
billt460  Online Content
Glendale, Arizona
I would look for the cheapest brass stuff I could find. With one exception. Stay away from Malaysia stuff. There were a few M1-A's that let go shooting it some time ago. Sometimes you can get some good deals on Berdan primed brass .308 at good prices.
Re: 308 to punch paper off hand [Re: stockrex] #4535622
10/06/17 04:47 PM
10/06/17 04:47 PM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
I ran 1000 wolf through a 9mm with zero problems
Re: 308 to punch paper off hand [Re: stockrex] #4535725
10/06/17 07:19 PM
10/06/17 07:19 PM
Canada
i_hate_autofraud Offline
Canada
Yeah, I got buckets of Mil 308, but I never set my zero with it, I use the 'good stuff'
for deer season to set or check my zero, punches harder, but more accurate!
Originally I was looking for 308 my rifle 'liked' turns out it does happen when the groups get
tighter and you've changed nothing else but the ammo.
At the time, in my 30's I switched from mil to my deer loads, the groups tightened right up but
1 1/2" high with a bit of scope-bite, not expecting much of a change in recoil! But there was! dang
Re: 308 to punch paper off hand [Re: stockrex] #4536407
10/07/17 05:12 PM
10/07/17 05:12 PM
Michigan
stockrex Offline OP
stockrex  Offline OP
Michigan
Thanks for the vote for the mil surp/cheapo rounds
I bought few boxes of 150 fmj and 150 sp wolf.
I read they are dirty sobs, but hey they were cheap,
I might get some German surplus too for the brass but I have mucho 308 brass from a buddy who had a machine gun he sold. Nice once fired sized, cleaned and primed.
The wolf was 33 cents while the German stuff if 55 cents I believe, worth the diff if I use the brass but again, it is a P-A-I-N to pick up the brass at my range with gas guns.
I just realized my PSA AR 10 did NOT come with a mag, seriously, I thought the lower would come with a mag,
I need 4 10 round mags for the high power matches. Which one should I go for? pmags?
Re: 308 to punch paper off hand [Re: stockrex] #4536436
10/07/17 05:53 PM
10/07/17 05:53 PM
Glendale, Arizona
Glendale, Arizona
I would go with P-Mags. They're cheap, function well, and the feed lips won't bend or get out of shape. I've never had a bad one.
Re: 308 to punch paper off hand [Re: stockrex] #4536547
10/07/17 08:12 PM
10/07/17 08:12 PM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
All the steel case stuff I've run (mostly Wolf) has been perfectly fine.
One caveat ... Don't run a lot of it in a high-cycle fashion, getting the chamber hot, and then leave a round in. It's true what is said; the anti-trust lacquer will bond to the chamber and make the cases want to stick. I've had to clear friends' mistakes a few times. As long as you run the rounds with some cool down time between mags, and not go all "Rambo" with it, they work great.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 308 to punch paper off hand [Re: stockrex] #4536635
10/07/17 09:51 PM
10/07/17 09:51 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
I've shot a metric S-load of Wolf .308 through some guns. Cheapest blasting ammo I can find, always works great. I ACTUALLY like it in .308, where as I cant stand the .223 version.
I usually keep at least 1000 rounds of the Wolf .308 on hand. I trust it and would use it during the apocalypse.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: 308 to punch paper off hand [Re: billt460] #4542104
10/13/17 11:02 AM
10/13/17 11:02 AM
Michigan
stockrex Offline OP
stockrex  Offline OP
Michigan
Thanks, I bought 4 10 round pmags from Brownells for 14$ with free shipping :-)
Re: 308 to punch paper off hand [Re: dnewton3] #4542132
10/13/17 11:47 AM
10/13/17 11:47 AM
Michigan
stockrex Offline OP
stockrex  Offline OP
Michigan
Thanks, lol, no Sir, no mag dump here,
rapid fire:
1 round to sight, then 10 in 1 min max, open chamber, put in flag, check the target.
So there is ample time for the barrel and chamber to cool down plus I shoot when it is 50F or cooler.
I bought some Tula, which has bullets with a bi-metal jacket, hope this is not going to wear the barrel out (??)
https://www.bulkammo.com/bulk-308-win-ammo-308150fmjtulablack-500
Re: 308 to punch paper off hand [Re: bubbatime] #4542135
10/13/17 11:48 AM
10/13/17 11:48 AM
Michigan
stockrex Offline OP
stockrex  Offline OP
Michigan
ok, I have shot the 223 and it is smells different and is bit dirty but works.
Thanks,
Re: 308 to punch paper off hand [Re: stockrex] #4542152
10/13/17 12:08 PM
10/13/17 12:08 PM
Glendale, Arizona
Glendale, Arizona
The main thing I don't care for with most any steel cased ammunition, is the cases do not obturate as well as brass cases. The result is a lot more powder blow by, and a much dirtier weapon. Especially in a direct impingement semi auto rifle. Compared to the same amount of brass cased ammunition fired through the same gun. I know a lot of people don't care about that, because you have to clean your gun anyway. I am also of the belief it's harder on extractors. On a AR-15 extractors are easy to find. And even easier to replace. But on other guns they can be a PITA.
But considering all of the above, and adding in the fact I reload. I have zero reason to mess with steel. The only exception is with my AK-47's. They are designed for steel cased ammunition.
Re: 308 to punch paper off hand [Re: stockrex] #4542221
10/13/17 01:12 PM
10/13/17 01:12 PM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
I've put several hundred rounds of CBC 7.62x51 through my DPMS, even at my LGS prices, it's about .70/round. Then I discovered on-line ammo shopping...
I've put a few hundred rounds of ZQI ammo (Turkish, bought from SGammo.com for 0.44/round) through it as well.
Just bought 1,000 rounds of surplus German ammo from SGammo for about 0.45/round.
http://www.sgammo.com/catalog/rifle-ammo-sale/308-win-762x51-ammo
With prices between steel case Russian and decent brass ammo varying by only a few cents, I would rather not put steel case ammo through my rifle. Personal preference, I suppose, but even with 1,000 rounds, the savings of steel over brass (feel free to peruse SGAmmo's site) is small, and it just isn't worth it.
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: 308 to punch paper off hand [Re: Astro14] #4542902
10/14/17 06:37 AM
10/14/17 06:37 AM
Michigan
stockrex Offline OP
stockrex  Offline OP
Michigan
Astro,
I missed these german surplus, wow, I mean that is a good deal,
only thing is the corrosion,
how bad was it on the surface, did it eat through the brass?
