New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
48 registered members (DaHen, d00df00d, Astro_Guy, chance, Bud, 4 invisible), 989 guests, and 32 spiders.
Topics290,748
Posts4,849,496
Members66,033
Most Online3,590
Jan 24th, 2017
2010 Mazda 3 2.0, 5w20 full syn, 14910 mi #4534462
10/05/17 09:56 AM
10/05/17 09:56 AM
Virginia
JamesMontana Offline OP
Virginia
I did my first UOA with Blackstone. Interesting results! confused
1. It seems that 15K is a fine OCI for full-syn in my Mazda3. I used Castrol GTX Magnatec with a FRAM Ultra filter.
2. Too much aluminum wear, according to Blackstone. (See below for their full comments.) Any thoughts from other Mazda3 owners or UOA veterans? I have a broken motor mount (to be replaced this week, just found it) which may have caused some extra vibration. I do not see any leaks in the air filter or intake, and the air filter is changed regularly (every 15K).
Comments from Blackstone:
Aluminum and iron are above average in this first sample. Universal averages show typical wear levels for Mazda 2.0L engines on the oil. A longer run makes the iron level okay, but doesn't really excuse the extra aluminum. Silicon might be to blame if it's abrasive dirt. Check the air filter and intake for any cracks and leaks. This may just be a normal amount of piston / bearing wear for your engine, but only trends will make that clear. The TBN was okay at 1.2, showing some active additive left. Try ~15,000 again next.
OIL Castrol Magnatec Full Syn 5w-20.
MILES IN USE 14.9k
MILES 111K
SAMPLE TAKEN 09/20/2017
ALUMINUM 8 Universal average: 3
CHROMIUM 1
IRON 33 Universal average: 11
COPPER 14
LEAD 22
TIN 0
MOLYBDENUM 6
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
Re: 2010 Mazda 3 2.0, 5w20 full syn, 14910 mi [Re: JamesMontana] #4534493
10/05/17 10:33 AM
10/05/17 10:33 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Would be interesting to see what pool they pull from for that little engine for the specs as that engine is used in 13 models of Mazda and Ford.
I have it in a Ford Transit and had the engine replaced when a valve lifter went bad and was cheaper($400) to get a low miles engine from salvage yard than try and rebuild the head and have the rest of the engine at 180k. Tranny was shot too.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: 2010 Mazda 3 2.0, 5w20 full syn, 14910 mi [Re: JamesMontana] #4534535
10/05/17 11:25 AM
10/05/17 11:25 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
How long did it take for the 15K? If one year Id do 2x year OCI = late fall / early spring. What was the viscosity?
Was the engine getting noisy near the end of the OCI?
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: 2010 Mazda 3 2.0, 5w20 full syn, 14910 mi [Re: ARCOgraphite] #4534576
10/05/17 12:49 PM
10/05/17 12:49 PM
Virginia
Virginia
About 1 year, yes. Thanks for the tip re 2x per year!
Re: 2010 Mazda 3 2.0, 5w20 full syn, 14910 mi [Re: JamesMontana] #4534728
10/05/17 04:06 PM
10/05/17 04:06 PM
Bend, Oregon
Oregoonian Offline
Oregoonian  Offline
Bend, Oregon
Personally....I would reduce my OCI to 12,000 or so....just to be safe. After all, oil is cheap, especially many synthetics which have rebates going for them.
03' Ford Focus SE(2.3L Duratec PZEV)/ 140K +
Pnz. Ultra 0w20 / Fram 'Ultra'/ OCI: 8000 +/-
ATF: Mercon V w/Lubegard Red
Re: 2010 Mazda 3 2.0, 5w20 full syn, 14910 mi [Re: JamesMontana] #4534801
10/05/17 05:45 PM
10/05/17 05:45 PM
Soviet State of Washington
PimTac Offline
PimTac  Offline
Is Magnatec a good choice for a 15k oci? I would think Castrol Edge Gold would be the obvious pick here.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
Re: 2010 Mazda 3 2.0, 5w20 full syn, 14910 mi [Re: PimTac] #4534813
10/05/17 05:57 PM
10/05/17 05:57 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Well it maybe but looking at the numbers I'd cut the cars OCI back to 10K and see what happened.
The TBN was barely good at 1.2.
2004 Corolla 124770
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
