Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
97 registered members (addyguy, 2012AccentSE, Aichiguy, 92saturnsl2, 2009Edge, 53' Stude, 14 invisible), 2,072 guests, and 58 spiders.
Topics286,204
Posts4,904,153
Members67,576
Most Online2,967
Mar 10th, 2019
How much is to much - metal flakes in ATF #4532758
10/03/17 08:55 AM
10/03/17 08:55 AM
Houston,Tx
Tom777 Offline OP
Tom777  Offline OP
Houston,Tx
Experts, I need your opinions! I did 2 D&F back in August and got the third one done last week on my 2015 Ford Edge. Long story short, at first drain (13k miles) I found 2~3 curved metallic derbies about finger nail size and some very small metal bits in the drain pan. Fast forward to last week, I did another D&F at 15k (2000 miles later) and I found one tiny gold color flake in the drain pan but thats it. it was pretty clean on the 3rd drain. I already scheduled with service to have it take a look but due to Hurricane it got postponed till later this month. I would like to hear your thoughts on this. Transmission shifts ok for the most part except having a small flare (500rpm went up to 1000rpm) when down shifting from 2nd to 1st. Much thanks in advance!
Re: How much is to much - metal flakes in ATF [Re: Tom777] #4532784
10/03/17 09:12 AM
10/03/17 09:12 AM
southeast US
friendly_jacek Offline
southeast US
i saw similar things in my drain pan when i switched to a different drain plug with aluminum washers. the flakes were non-magnetic and likely from a washer. use a magnet and see if magnetic.
I also had an instance where metallic particles showed up on a tranny dipstick, turned out notches on the dipstick scratched the dipstick tube. apparently checking fluids too much can be harmful too.
Re: How much is to much - metal flakes in ATF [Re: Tom777] #4532794
10/03/17 09:20 AM
10/03/17 09:20 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
If the transmission is working fine, don't worry about it. I didn't bother to drop the transmission pan on my 1995 Escort until it had around 165K miles in it, and the magnets in the transmission pan were filthy. I cleaned them up and reinstalled them and I now have over 241K miles in that transmission.
Re: How much is to much - metal flakes in ATF [Re: Tom777] #4533155
10/03/17 05:47 PM
10/03/17 05:47 PM
Ohio
hallstevenson Online content
hallstevenson  Online Content
Ohio
You're asking them to look for a problem that likely doesn't exist ?
This may be completely "normal" (to Ford, or as designed). I'd check that first before presuming it's wrong.
Re: How much is to much - metal flakes in ATF [Re: Tom777] #4534082
10/04/17 06:08 PM
10/04/17 06:08 PM
Vancouver, Canada
dubber09 Offline
dubber09  Offline
Vancouver, Canada
I beg to differ, any 'chunks' are not normal. 'Dust' that's stuck to drain plug is normal depending on amount and how coarse it is.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: How much is to much - metal flakes in ATF [Re: Tom777] #4542708
10/13/17 10:30 PM
10/13/17 10:30 PM
NJ, USA
davison0976 Offline
davison0976  Offline
NJ, USA
Tom777, what you saw in terms of amount and size of debris is perfectly normal. Check out the image below to see what I had at first D&F. Unfortunately a blurry image, but you get the idea. If I were you I wouldn't bother going to a dealer. Like Hallstevenson said you'll be asking them to look for a problem that doesn't exist.
7AT on 2013 G37 first D&F at 22,xxx miles. Currently at 42,xxx and shifts perfectly.
