4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
68 registered members (allgm59, 97prizm, ad_infinitum, ammolab, 5 invisible), 1,317 guests, and 58 spiders.
Topics286,042
Posts4,901,395
Members67,551
Most Online2,967
Mar 10th, 2019
gunk on coolant sensor? #4532000
10/02/17 12:03 PM
10/02/17 12:03 PM
Indiana
OpenClose Offline OP
Indiana
I recently had problems with my coolant light staying on despite my coolant level being high.
I got a new coolant level sensor and it seemed to have worked for about a month. Then it would say "low coolant" until the engine warmed up. (I already bled the air out of the line). Now, it just says "low coolant" all the time again.
It makes me wonder if I have some sort of oil or gunk in my coolant that is clogging the sensor. You figure if gunk accumulates on there, it would wash off when the coolant starts cycling again (when the engine is warm) and over time would build up until it said "low coolant" all the time.
I was going to go in and check the connection and maybe clean the connector and add some connector grease (unless that stuff is snake oil). Anything else I can check?
1999 Buick Regal GS SC 115k
Pennzoil Platinum w/ PurePlus
FRAM Ultra Synthetic
TransGo Shift Kit
Re: gunk on coolant sensor? [Re: OpenClose] #4532012
10/02/17 12:21 PM
10/02/17 12:21 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Have you verified the electrical connections?
Re: gunk on coolant sensor? [Re: OpenClose] #4538100
10/09/17 02:10 PM
10/09/17 02:10 PM
Indiana
Indiana
To a limited degree, yes. Mostly just checked power getting to the sensor. Not as intensive of a check as I would like but I've been busy the past week or so.
TransGo Shift Kit
Re: gunk on coolant sensor? [Re: OpenClose] #4538631
10/10/17 12:09 AM
10/10/17 12:09 AM
CA
user52165 Offline
user52165  Offline
CA
When was the last time the coolant was changed and system flushed?
If you are referring to dielectric grease, that is surely not snake oil.
Re: gunk on coolant sensor? [Re: OpenClose] #4540171
10/11/17 12:44 PM
10/11/17 12:44 PM
Indiana
Indiana
I'd say about 2 years ago, I did basically as good of a flush as I could do. Ran some prestone cleaner in the coolant leading up to the flush, emptied it out, removed the thermostat, ran a hose through it will the car was running, put in some distilled water and prestone cleaner, ran on that for a few days, ran a hose again, then refilled with distilled water and dex-cool and a new thermostat.
I did all that because when I had done a flush a year prior when I got the car, it was pretty gunked up like someone had used non-dex-compatible coolant or something.
Also, I bought a bunch of the dielectric grease a while back and used it on my LED and HUE bulbs and connectors throughout the house. It wasn't a few months later I was already seeing oxidation on some of the bulbs. So it seemed like it sped up the oxidation process if anything. That's why I was asking.
TransGo Shift Kit
Re: gunk on coolant sensor? [Re: OpenClose] #4540738
10/11/17 10:06 PM
10/11/17 10:06 PM
CA
user52165 Offline
user52165  Offline
CA
Not sure about your car and year, but GM had terrible problems when Dexcool was mixed with clay pellets in 90's cars. Tons of cyberink on this subject. Does your block have drain plugs to get all the coolant out? Ever had problems with heater core? Radiator condition? May need a better flush and cleaning.
Notice you have 115K miles on an 18 year old car or only 6300 miles per year. Either lots of short trips or lots of no trips - may be part of the problem.
Re: gunk on coolant sensor? [Re: OpenClose] #4540794
10/11/17 11:26 PM
10/11/17 11:26 PM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
I know later Northstar Cadillacs had that low coolant light issue. If drained the float sticks. You can smack the reservoir with a rubber mallet or buy a new one. Regal might have same set up.
2001 F150 5.4L 140k miles
2013 Nissan Juke Nismo 80k
2000 Honda S2000 183k
1998 BMW 328i 170k
Re: gunk on coolant sensor? [Re: OpenClose] #4541997
10/13/17 09:35 AM
10/13/17 09:35 AM
Indiana
Indiana
Thanks for the info. What is the best DEX replacement you guys would recommend? I'll keep my eye out in google searches and the like.
I'll also have to see if the dealer or Raben can do the flush, clean, and refill since I don't have a garage anymore. Which would you recommend between a dealer and a shop? I feel like a dealer would be like "naw we can't do anything but DEX."
Side note, my car is up to 133,333mi as of today. I'll have to update the sig. I bought it at about 103k miles back in 2014. I'm pretty sure the previous owner was some old guy using it to get to church on sundays. Low mileage and all the problems it had were aesthetic, not mechanical. But also when my dad and I test drove it, the muffler literally exploded leaving rusty shrapnel. Lots of evidence this car did a lot of sitting. So I flushed and replaced all the fluids regardless of condition, replaced rusted or dry-rotted parts. Got a new exhaust and put in a trans-go shift kit. Thing runs like a dream. Easy to drive and definitely fast. No cooling problems really beyond the level sensor and generally muddy coolant.
TransGo Shift Kit
Re: gunk on coolant sensor? [Re: OpenClose] #4542088
10/13/17 11:31 AM
10/13/17 11:31 AM
Colorado
AntsinmyEyes Offline
Colorado
zerex g05 would work
1987 mazda rx7
2004 mazda rx8
1995 miata
2005 dodge ram
