M1 0W20 EP Good To At Least 10K Miles ?
by ChrisD46. 12/16/18 03:29 AM
Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
21 registered members (Dave9, BigRich954, Char Baby, bfleeman, 3 invisible), 900 guests, and 40 spiders.
Topics295,136
Posts4,928,384
Members66,691
Most Online2,553
Oct 27th, 2018
Sinking brake pedal... #4525780
09/25/17 12:15 PM
09/25/17 12:15 PM
Canada
Lolvoguy Offline OP
Lolvoguy  Offline OP
Canada
Recently I noticed that the brake pedal on my Focus seems to sink to the point of almost contacting the floor mat. It seems to happen once every few months, and only occurs once.
In terms of maintenance, the only thing I've replaced are the front pads and rotors. Everything else is OEM from 2007 (car has 100k miles currently).
Any idea of what could be causing it? I recently checked the drivers side floor mat and didn't notice any leaks (from the master cylinder). I've never encountered this issue on any car I've owned before.
thanks in advance
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Sinking brake pedal... [Re: Lolvoguy] #4525790
09/25/17 12:24 PM
09/25/17 12:24 PM
Illinois
javacontour Offline
javacontour  Offline
Illinois
Master cylinder is probably on the way out...
Fluid doesn't leak out of the MC, but it does get past the seals inside the MC and the pedal sinks.
network down, IP packets delivered via UPS -BOFH
Re: Sinking brake pedal... [Re: Lolvoguy] #4525791
09/25/17 12:25 PM
09/25/17 12:25 PM
NC
ruhroh Offline
ruhroh  Offline
NC
A good start would be to borrow a brake bleeder tool from Autozone or AAP and replace the brake fluid. If the fluid is that far gone, the master cylinder is probably going to follow soon.
Re: Sinking brake pedal... [Re: Lolvoguy] #4525824
09/25/17 01:04 PM
09/25/17 01:04 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
Sounds like a master cylinder to me. I had a Chevy Vega a long, long time ago that had a brake pedal that would occasionally sink to the floor. I didn't think much of the problem until the master cylinder failed completely when I was in heavy northern New Jersey traffic. Then had to drive home with NO BRAKES.
Have that problem looked after immediately.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Sinking brake pedal... [Re: Lolvoguy] #4525846
09/25/17 01:21 PM
09/25/17 01:21 PM
MA
Wolf359 Online content
Wolf359  Online Content
MA
If the fluid level hasn't changed, as others said, probably the master cylinder.
Re: Sinking brake pedal... [Re: Lolvoguy] #4525850
09/25/17 01:27 PM
09/25/17 01:27 PM
Canada
Lolvoguy Offline OP
Lolvoguy  Offline OP
Canada
Just checked the fluid level...seems the same as before (just below Max).
Spoke with a reputable shop I usually work with. They said that unless it's dropping the pedal consistently, they'd just be throwing parts at it randomly with the hopes of fixing the problem eek
So where do I go from here? I really don't mind getting someone else to replace it as it's kinda outta my expertise level. I really don't mind getting another master installed.
I live in an area with VERY steep mountains/hills and high speed braking that's part of my daily commute. My brakes are VERY important to me.
thanks in advance
Say "no" to Turbo!
Re: Sinking brake pedal... [Re: javacontour] #4525856
09/25/17 01:35 PM
09/25/17 01:35 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: javacontour
Master cylinder is probably on the way out... Fluid doesn't leak out of the MC, but it does get past the seals inside the MC and the pedal sinks.
This is generally the most common and typical issue.
Re: Sinking brake pedal... [Re: Lolvoguy] #4525863
09/25/17 01:43 PM
09/25/17 01:43 PM
Illinois
javacontour Offline
javacontour  Offline
Illinois
It probably happens when the weather gets colder. Once the MC heats up, the seals expand and you don't experience the problem again.
Re: Sinking brake pedal... [Re: Lolvoguy] #4525873
09/25/17 01:50 PM
09/25/17 01:50 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
You should try turkey basting the MC a few times, let it marinate then bleeding brakes. That helped reverse the sinking pedal problem once for me. Black crud was preventing MC from sealing. Got that cleaned out, was fine for another 75k and traded away
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Sinking brake pedal... [Re: javacontour] #4525923
09/25/17 02:39 PM
09/25/17 02:39 PM
Canada
Lolvoguy Offline OP
Lolvoguy  Offline OP
Canada
Mine is the opposite. As the MC heats up from use, is when it starts to fail.
Cold and it's fine.
Say "no" to Turbo!
Re: Sinking brake pedal... [Re: Lolvoguy] #4525973
09/25/17 03:46 PM
09/25/17 03:46 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Rear drum brake shoes need adjusting?
Thick oil is better grin2
Re: Sinking brake pedal... [Re: andyd] #4525998
09/25/17 04:13 PM
09/25/17 04:13 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
This. The biggest clue is it's happening once, and the second time you apply brakes it's working fine. Adjust the rear brakes and make sure your parking brake isn't adjusted too tight. Of course, this is considering you have rear drum brakes.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Sinking brake pedal... [Re: Lolvoguy] #4526635
09/26/17 10:14 AM
09/26/17 10:14 AM
Canada
Lolvoguy Offline OP
Lolvoguy  Offline OP
Canada
yup, I sure do have rear drums.
thanks for the tip thumbsup
Say "no" to Turbo!
