Thoughts on new AMAZON branded oil...?
by PantherFan88. 09/25/18 10:47 PM
Clutch kit?
by andrewp1998. 09/25/18 10:34 PM
Galaxy S8+ weird app when clearing storage
by KrisZ. 09/25/18 10:18 PM
Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
FRAM ULTRA XG 3593A CUT OPEN
by 53' Stude. 09/25/18 04:51 PM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
43 registered members (bdcardinal, Bailes1992, AndyB, bernau, 10WSmuckers, 5 invisible), 720 guests, and 38 spiders.
Topics291,026
Posts4,854,647
Members66,070
Most Online3,590
Jan 24th, 2017
Hard time bleeding rear brakes - Mazda 6 #4525667
09/25/17 10:57 AM
09/25/17 10:57 AM
PA
Chester11 Offline OP
PA
Folks:
I'm having tough time bleeding my rear brakes.
The rear bleeders are different than the front. The rears take a 10mm wrench (8mm in front) - but the clear tube that fits on the front won't seal on the back. I even tried a zip tie to tighten it up, and using a 5/32nd vacuum hose. Really made a mess.
I have the attachments from a cheap vacuum kit, and I can't get the plastic attachments to seal on the bleeders either.
Any advice here would be appreciated. I'm on attempt number three and getting tired of taking the wheels off.
Re: Hard time bleeding rear brakes - Mazda 6 [Re: Chester11] #4525676
09/25/17 11:07 AM
09/25/17 11:07 AM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
Do you have a second person to help? If so, just do it the old fashioned way. UP! DOWN! repeat...
If you don't have any help, you can crack open the bleeders and let it sit while gravity takes care of it for you.
Re: Hard time bleeding rear brakes - Mazda 6 [Re: Chester11] #4525677
09/25/17 11:08 AM
09/25/17 11:08 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I guess I must admit to being a Red Neck . I have bleed brakes since about the 70's . Never used the rubber hose .
When you get through , just clean up properly .
Be sure to close off the bleeder valve completely , before your partner raises their foot from the brake petal , otherwise , it will suck air back into the system .
Best of luck , :-)
Wyr
God bless
Re: Hard time bleeding rear brakes - Mazda 6 [Re: cpayne5] #4525694
09/25/17 11:34 AM
09/25/17 11:34 AM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Re: Hard time bleeding rear brakes - Mazda 6 [Re: Chester11] #4525702
09/25/17 11:44 AM
09/25/17 11:44 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Yeah, I'd let it gravity bleed. Even with one other person pressing down on the brake pedal can often cause Master Cylinder piston scoring on the inside of the bore. I have even used the 2 oz syringe and pulled the fluid that way.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Hard time bleeding rear brakes - Mazda 6 [Re: Chester11] #4525704
09/25/17 11:45 AM
09/25/17 11:45 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
You have to put in your bleeder kit AND then pump the brakes at least a little to get it started.
Re: Hard time bleeding rear brakes - Mazda 6 [Re: Chester11] #4525818
09/25/17 01:58 PM
09/25/17 01:58 PM
Vancouver, Canada
dubber09 Offline
dubber09  Offline
Vancouver, Canada
I use clear fish tank air line to do this. There is video on YouTube by ChrisFix on how to do it by self.
Re: Hard time bleeding rear brakes - Mazda 6 [Re: dubber09] #4525827
09/25/17 02:08 PM
09/25/17 02:08 PM
PA
PA
that's exactly how I made mine. the problem is I can't get the tubing to seal over the bleeder screw. (the rear is a different size) works fine on the front, but not the back. even the attachments from the vacuum bleeder don't work.
it's turning into an erector set - I have three tube sizes....
I like the gravity bleed idea, but it makes a mess. I'm trying to keep the fluid off the driveway. Do you just crack the bleeder and let it drip into a pail?
Re: Hard time bleeding rear brakes - Mazda 6 [Re: Chester11] #4525946
09/25/17 04:00 PM
09/25/17 04:00 PM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
Yep, just let it dribble out.
Re: Hard time bleeding rear brakes - Mazda 6 [Re: Chester11] #4526005
09/25/17 05:16 PM
09/25/17 05:16 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
speed bleeders are awesome smile
Re: Hard time bleeding rear brakes - Mazda 6 [Re: slacktide_bitog] #4526071
09/25/17 06:27 PM
09/25/17 06:27 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
Yes they are. Plus I use those little bleeder cups with the fittings that fit on pretty much any size bleeder.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Hard time bleeding rear brakes - Mazda 6 [Re: Chester11] #4526144
09/25/17 07:48 PM
09/25/17 07:48 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Throw some cheap ( dollar store ) kitty litter on spills .
Or use a water hose , brake fluid seems to be at least partially water soluble .
Or soap and water .
Best wishes , :-)
Wyr
God bless
Re: Hard time bleeding rear brakes - Mazda 6 [Re: WyrTwister] #4527158
09/26/17 09:58 PM
09/26/17 09:58 PM
PA
PA
Or soap and water .
Best wishes , :-)
Driveway looks like a cat box with all the fluid I spilled. I half expect to see a herd of cats around the car.....
Re: Hard time bleeding rear brakes - Mazda 6 [Re: Chester11] #4527637
09/27/17 02:04 PM
09/27/17 02:04 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Well , I suggest you eventually sweep it up and toss it into the dumpster ! :-)
Best wishes , :-)
Wyr
God bless
Re: Hard time bleeding rear brakes - Mazda 6 [Re: Chester11] #4527774
09/27/17 05:45 PM
09/27/17 05:45 PM
ME
eljefino Offline
eljefino  Offline
ME
Stuff an ice scraper (or similar 20 inch long stick) between your seat cushion and brake pedal. Adjust the seat for proper tension. Then go around back and get squirted in the face. One man brake bleed!
