AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
58 registered members (ArrestMeRedZ, 2003f7, Aero540T, 2010Civic, agpatel, alphadog, 3 invisible), 1,210 guests, and 66 spiders.
Topics286,439
Posts4,908,174
Members67,622
Most Online2,967
Mar 10th, 2019
Use conventional oil, but top off with synthetic? #4525661
09/25/17 10:50 AM
09/25/17 10:50 AM
Southeast
EchoThat300K Offline OP
Southeast
Is there an advantage to using synthetic to top off conventional oil as needed?
My 2002 Echo sedan has 275k suburban miles. I have changed the oil consistently at 5k intervals since I got the car used in 2005 at 61k miles.
I used synthetic exclusively for a long time until I began consuming more of it than I was comfortable with. Currently, I burn about 10 ounces of 5-30 conventional per 1000 miles, which is roughly five weeks of driving.
Re: Use conventional oil, but top off with synthetic? [Re: EchoThat300K] #4525663
09/25/17 10:52 AM
09/25/17 10:52 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
No advantage, no disadvantage (aside from cost).
Do you just have a bunch of synthetic laying around? Otherwise just use conventional.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Use conventional oil, but top off with synthetic? [Re: blupupher] #4525665
09/25/17 10:55 AM
09/25/17 10:55 AM
Southeast
Southeast
Thanks.
Driving, but wish I were on a bicycle.
Re: Use conventional oil, but top off with synthetic? [Re: EchoThat300K] #4525668
09/25/17 10:59 AM
09/25/17 10:59 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
What brand filters are you running? Frams are very good fyi.
Re: Use conventional oil, but top off with synthetic? [Re: EchoThat300K] #4525687
09/25/17 11:19 AM
09/25/17 11:19 AM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I'd just use synthetic. Burning some oil means you top it off every once in a while and replenish the additives, which means you can stretch the oil change interval out a little bit.
10 ounces in 1,000 miles isn't anything to worry about, that's about 1 quart in 3,000 miles.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Use conventional oil, but top off with synthetic? [Re: EchoThat300K] #4525690
09/25/17 11:27 AM
09/25/17 11:27 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
I would try rotella T4 triple protect 10w30 in there. The old Triple protect 10w30 used to be THE GO-TO OIL for older engines or stressed engines and ODPE in a 30 grade. Haven't tried the T4 but I would give it a shot.
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Use conventional oil, but top off with synthetic? [Re: EchoThat300K] #4525693
09/25/17 11:32 AM
09/25/17 11:32 AM
MN
oil_film_movies Offline
MN
To slow oil consumption, use Mobil1 High Mileage 10w30. Its a bit thicker than normal 5w30 or other 10w30 oils. HTHS=3.5 which is high for a 30 weight.
Also, its extra seal conditioners will keep the seals flexible to prevent future leaks.
Re: Use conventional oil, but top off with synthetic? [Re: oil_film_movies] #4525732
09/25/17 12:20 PM
09/25/17 12:20 PM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
or Valvoline Maxlife...
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30 + Wix 51348
2008 Ford Crown Vic P71 4.6 ~167K Miles: AMSOIL SS 0W-30 + Wix 51372
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30 + ACDelco PF52
Re: Use conventional oil, but top off with synthetic? [Re: EchoThat300K] #4525741
09/25/17 12:31 PM
09/25/17 12:31 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
I would use the M1 10W-30 HM, like suggested above. It is relatively inexpensive, and stout oil.
Re: Use conventional oil, but top off with synthetic? [Re: bigj_16] #4525748
09/25/17 12:39 PM
09/25/17 12:39 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
I get the least oil consumption with this oil of various major brands I have tried (including maxlife products). In the Southeast, it can be year-round for you. It's on rebate now and as mentioned, pretty inexpensive in comparison.
With the small sump size in that, I'd set one of my trip odometers to zero at my oil change, then check the oil every 500 miles and top up, and no less often than that. I have a vehicle with higher consumption than yours(but a larger sump), and I top it up every 400 miles. It helps reduce consumption.
Re: Use conventional oil, but top off with synthetic? [Re: Nick1994] #4525851
09/25/17 02:32 PM
09/25/17 02:32 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Correct. Just add whatever is cheap, it will still replenish additives. Change oil at 15,000.
Re: Use conventional oil, but top off with synthetic? [Re: EchoThat300K] #4525915
09/25/17 03:32 PM
09/25/17 03:32 PM
Fairfax, VA
TinyVoices Offline
TinyVoices  Offline
Fairfax, VA
I'd probably use MaxLife red bottle. Great oil and has slowed usage in all the engines I use it in. Plus it's quite cheap.
2010 Mazda RX8 Sport - 37k miles - ????
2006 Toyota Matrix XR AWD (Wife) - 130k miles - Valvoline Max Life 5w30
Re: Use conventional oil, but top off with synthetic? [Re: EchoThat300K] #4526206
09/25/17 08:59 PM
09/25/17 08:59 PM
burlington ,ontario, canada
ndfergy Offline
ndfergy  Offline
I would try a little thicker 10W30 dino oil first. Failing that, Mobil HM, as others have mentioned, sounds good.
2015 Toyota Yaris 5spd Manual
Summer: Mobil Super 1000 10w30
Winter: Mobil Super 1000 5w30
OEM Filter
Re: Use conventional oil, but top off with synthetic? [Re: EchoThat300K] #4526738
09/26/17 01:21 PM
09/26/17 01:21 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
Many years ago I would make my own FrankenBrew oil. I would sometimes mix half and half dino oil with synthetic. I would also mix different weight oils of dino and synthetic. There are quite a few members here that have, and some still are, mixing oils. So, yes, you can top off your dino oil with synthetic oil all day long. smile
Re: Use conventional oil, but top off with synthetic? [Re: EchoThat300K] #4526783
09/26/17 02:19 PM
09/26/17 02:19 PM
SE Pa
cmhj Offline
cmhj  Offline
SE Pa
time for another beer run
No PC fees paid to Amsoil dealers!
2018 Buick Enclave Essence
2013 Fiat 500
2012 Equinox LS
2016 Subaru Forester 2.5i Touring
A slug of old stuff
