Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
25 registered (citationxeleven, clinebarger, Black, bbhero, ctechbob, boom10ful, 3 invisible), 942 Guests and 36 Spiders online.
65282 Members
67 Forums
285683 Topics
#4524124 - 09/23/17 03:30 PM Flush or drain coolant
jimbrewer Offline
Loc: New Mexico, USA
Can't seem to dial up what must be a dozen old threads, sorry.
First coolant change coming up on Ford 3.7L. I could have sworn that Ford didn't like flush--only drain. Can't find it in the manual though.
What say you? Drain or flush and drain?
#4524128 - 09/23/17 03:35 PM Re: Flush or drain coolant [Re: jimbrewer]
CT8 Offline
Loc: Idaho
First determine if a flush is needed? What does the coolant look like and peer into the radiator, Probably it has a degas bottle though.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4524129 - 09/23/17 03:36 PM Re: Flush or drain coolant [Re: jimbrewer]
slacktide_bitog Offline
Loc: USA
Drain the radiator, and use the Lisle funnel when refilling smile
There is no need to flush it unless you went like 300k without ever changing it and it's sludged, or if you used the wrong coolant, or deathcool. But in 99% of cases there is no need to flush.
#4524135 - 09/23/17 03:42 PM Re: Flush or drain coolant [Re: slacktide_bitog]
jimbrewer Offline
Thanks. I'm on schedule for the first change--60K miles. Don't quite know why the first is twice as long as subsequent changes.
#4524165 - 09/23/17 04:37 PM Re: Flush or drain coolant [Re: jimbrewer]
JC1 Offline
Loc: Oshawa, Ontario Canada
I would just do a drain and fill.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
#4524206 - 09/23/17 05:27 PM Re: Flush or drain coolant [Re: jimbrewer]
SilverSnake Offline
Loc: Florida
Trade it in on a Dodge. Coolant is 10 year/150K mile OAT.
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
#4524223 - 09/23/17 05:57 PM Re: Flush or drain coolant [Re: jimbrewer]
bdcardinal Offline
Loc: Santa Barbara, CA
They cannot guarantee the quality of coolant being added. In the factory it is controlled.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#4524257 - 09/23/17 06:31 PM Re: Flush or drain coolant [Re: jimbrewer]
Loc: USA
Yup! A car that new definitely doesn't need a flush smile
#4524325 - 09/23/17 08:41 PM Re: Flush or drain coolant [Re: SilverSnake]
Ethan1 Offline
Loc: 'murica
Dodge coolant changes are free with all major engine work hornets
#4524408 - 09/23/17 10:34 PM Re: Flush or drain coolant [Re: jimbrewer]
JFAllen Offline
Loc: Albury, NSW
Since a fair amount of coolant hides in the heater core and in other coolant lines I always find a flush is better value. It ensures that 100% of the old coolant is gone, and that there is 0% chance of any weird coolant chemistry happening.
Chrissfix did a good video on youtube. my technique is slightly different.
After draining the coolant, I then run the garden hose into the bottom radiator hose and have the car run with the heater on until the discharge coming out the bottom of the radiator is clear. If your coolant system is dirty, disconnect the top radiator hose and have it discharge directly from here. Take the rad out and clean it.
Once you're confident it's all clean, you can then choose to do a 'chemical flush.' If you do repeat the previous step to ensure all the flushing agent is removed, after following the directions of the chemical flush.
Afterwards, fill with distiled water and run for a short while.
Dump that.
Refill with a coolant of your choice that meets the manufacturer specifications. (I personally like Nulon coolants here in Australia.)
guaranteed 100% clean. No old coolant. But does make a mess from running a total loss coolant system during the cleaning phase smile
Regards
Jordan
Edited by JFAllen (09/23/17 10:36 PM)
#4524566 - 09/24/17 07:33 AM Re: Flush or drain coolant [Re: Ethan1]
SilverSnake Offline
Loc: Florida
Let see, in the last 50+ years I have owned 87 cars and trucks almost all GM, Ford, or Chrysler products. Never had any major engine issues except with Fords (specifically Ford trucks). Had a lot of transmission issues with GM trucks. Have had no major engine or transmission issues with Dodge or Ram products and I don't have to worry much about coolant changes! One man's experience.
#4524657 - 09/24/17 09:47 AM Re: Flush or drain coolant [Re: jimbrewer]
cb_13 Offline
Loc: Missouri
Most important part of coolant flush or even drain and fill is to use distilled water. The premix should come already mixed with distilled. The concentrate still comes out to be significantly cheaper when mixed with an 88 cent gallon of great value distilled water.
#4524902 - 09/24/17 02:14 PM Re: Flush or drain coolant [Re: jimbrewer]
Merkava_4 Offline
Loc: Clovis, CA
Flush the coolant with the engine running ?
Guys here tell me it's safe because the water pump has a sealed bearing, but in the old days if you tried to run the water pump with straight water, it would burn the pump up. The coolant, being as slippery as it is, was the oil for water pumps back in the day before sealed bearings came about. I'm still too scared to do it; I just drain and fill.
