Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
22 registered members (avi1777, Black_Thunder, carlprop, Bailes1992, chance, 1 invisible), 559 guests, and 51 spiders.
Topics286,171
Posts4,903,546
Members67,572
Most Online2,967
Mar 10th, 2019
VOA Red Line 15w40 HDEO #4521580
09/20/17 07:02 PM
09/20/17 07:02 PM
MD
claluja Offline OP
claluja  Offline OP
MD
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
2018 Jeep Rubicon, Pentastar 3.6L
Re: VOA Red Line 15w40 HDEO [Re: claluja] #4521591
09/20/17 07:14 PM
09/20/17 07:14 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Nice Zinc!
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
Re: VOA Red Line 15w40 HDEO [Re: claluja] #4521600
09/20/17 07:25 PM
09/20/17 07:25 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
Curious RL now indicates 15w-40 diesel is appropriate for gas engines; years ago they specifically indicated for diesel only.
2004 Prius; 110K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: VOA Red Line 15w40 HDEO [Re: claluja] #4521615
09/20/17 07:51 PM
09/20/17 07:51 PM
NorCal
Seventh Offline
Seventh  Offline
NorCal
Looks solid. Thanks for posting this
Re: VOA Red Line 15w40 HDEO [Re: claluja] #4521654
09/20/17 08:51 PM
09/20/17 08:51 PM
pa
benjy Offline
benjy  Offline
pa
thanks! wondering about moly in my shared motorcycle oil, like other HDEO it should be good but actually better being Ester based oil
Re: VOA Red Line 15w40 HDEO [Re: claluja] #4521661
09/20/17 09:00 PM
09/20/17 09:00 PM
Stewartstown PA
spiderbypass Offline
Stewartstown PA
This redline oil definitely uses less moly compared to most other redline viacosities which are usually close to 600 ppm. I think Redline focused on meeting ash level of an apo cj4 oil with this application. Most of redline oils have higher saps additive package over and above specifications with the exception of the two European 5w30 507.00 type oil and the 5w40 European acea c3 Mercedes 229.51 type oil which both could easily meet actual certifications based on notably lower additive packages.
Insecurity with overcompensation are the root of evil deeds.
Re: VOA Red Line 15w40 HDEO [Re: claluja] #4521894
09/21/17 06:38 AM
09/21/17 06:38 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Wow, just goes to show, in this case, hopefully there are some magic elements in the Red Line that do not show up on the UOA.
Its quite possible as the additive package is so weak that I would think it was a mistake by Blackstone, yet I know its not as the zinc/phos/calcium match up.
More or less, what i am saying is, where on earth is the Magnesium or Boron in this oil?
Most HEDOs have one or the other of both and match up with the numbers of the zinc 1000 or more.
For an HEDO its completely missing the traditional Magnesium and Boron, never saw anything like this before. (not that that means anything ha ha)
BLACKSTONE IS WRONG, THESE ARE NOT TYPICAL ADDITIVES OF AN HEDO OIL, AS THE ADDITIVES IN THIS RED LINE OIL DO NOT EXIST. (im not yelling :o)
Just go to the Diesel/HEDO UOA section and compare additives or go to my own UOA on Mystic 15w50 in the motorcycle UOA section, first page.
Dont misunderstand my post, if this Red line oil is any good, it just goes to show the VOA means nothing because the Red Line additive package is weak at best.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: VOA Red Line 15w40 HDEO [Re: alarmguy] #4523002
09/22/17 09:16 AM
09/22/17 09:16 AM
Georgia
DeepFriar Offline
DeepFriar  Offline
Georgia
I tend to agree with you on this. The Blackstone (or other consumer level) test has always seemed to me to be of limited value as a comparison tool. It can confirm initial viscosity, TBN, particle count and such. But as to how it might work in use Blackstone, et al, stop short of "deconstructing" the oil presumably due to, I'm guessing here, the legal battle with the oil companies that would ensue. The cost of going to that level is also a constraint.
The dirty little secret though is that even if the test went to that level, each time it was tested the results could, or probably would be, different. Why? We have noted here before that the formulations change all the time in response to a variety of things not least of all the cost of oil components at any given time. This is why oil companies clamor to meet a "specification" rather than competing on the bases of the recipes. They don't want you to know what is in the oil at any given time so that it can not be compared to someone else's recipe. This allows the competition to stay on a marketing claims level.
This, to me, is what makes it slightly ludicrous to argue for one motor oil of a given type over another. As I'm sure others will point out, if the oil meets a given spec, that's really all you need to know. In fact it's all you CAN know. By design.
Re: VOA Red Line 15w40 HDEO [Re: DeepFriar] #4523817
09/23/17 08:49 AM
09/23/17 08:49 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Originally Posted By: DeepFriar
[quote=alarmguy]
Agree, well said and I have said it before too. Choose the API class oil recommended in the owners manual and you are good to go/ really no more thought then that required other then the fun of doing what we think best.
07 Suzuki C50
