Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
92 registered members (Ag76, Armkb, anndel, ABomb369, 14Accent, -SyN-, 14 invisible), 1,801 guests, and 32 spiders.
Topics290,954
Posts4,853,160
Members66,062
Most Online3,590
Jan 24th, 2017
Gear oil temp tolerance? #4518204
09/16/17 09:30 PM
09/16/17 09:30 PM
West Michigan
buck91 Online content OP
buck91  Online Content OP
West Michigan
Related to the below discussion about Ford PTU's but does anybody have any idea when type of operating temp ranges a GL-5 gear oil is designed for? Specifically a 75w140... more specifically Amsoils SG 75w140?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Gear oil temp tolerance? [Re: buck91] #4518275
09/17/17 12:12 AM
09/17/17 12:12 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Adequate operating viscosity range is more appropriate than temperature range (not that it's irrelevant) in this PTU application.
Anything xxW140 may be inadequate here, and one should seriously consider and adopt a xxW190 or xxW250 gear oils with higher [email protected]*C, within the confines of system parameters.
JMHO.
Re: Gear oil temp tolerance? [Re: buck91] #4518492
09/17/17 11:07 AM
09/17/17 11:07 AM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
More info is needed in this case.
I.e, What is the peak operating temperature of Ford's PTU?
For most lubes, any sustained temps above above 70% of the flash point is going to severely degrade the lube. So for this fully synthetic 75W140, any temp > about 280F is detrimental.
As others have stated, the Ford PTU design suffers from two main issues: 1) the low volume of fluid, 2) insufficient heat rejection.
Without an external cooler, short OCI's would be in order.
Reading is fundamental; understanding is not a given ability.
Re: Gear oil temp tolerance? [Re: buck91] #4518984
09/17/17 09:13 PM
09/17/17 09:13 PM
West Michigan
West Michigan
Haven't had a long trip to check yet but in local driving the ptu seems to closely correspond to the trans temp. Vehicle doesn't ever tow but does see occasional road trips.
2011 F150 4x4 5.0L
Re: Gear oil temp tolerance? [Re: MolaKule] #4519125
09/18/17 04:52 AM
09/18/17 04:52 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Could your comment be taken as 30% below the flash point too?
Easy math.. say the flash point is 100*F, you mean anything 70*F+ is detrimental?
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: Gear oil temp tolerance? [Re: dlundblad] #4519137
09/18/17 05:30 AM
09/18/17 05:30 AM
Texas
4WD Offline
4WD  Offline
Texas
308F for Redline - any downside?
Re: Gear oil temp tolerance? [Re: dlundblad] #4519294
09/18/17 10:30 AM
09/18/17 10:30 AM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
Yes. Say FP is 400F.
0.30 X 400F = 120F. 400F - 120F = 280F.
0.7 X 400 = 280F, but with fewer keystrokes.
This only applies to a full synthetic gear lube.
